Question about GE Spacemaker JVM1640SJ Microwave Oven
SpaceMaster Model #564.8755380 was running during power outage, and went out. Now doesn't come back on, I want to check that a fuse is blown. It is installed under cabinets, how do I take it off the wall, and where is the fuse?
  • 619 Answers
SOURCE: Microwave installation under cabinet, no rear wall
Hi , I would like to suggest to visit near appliance center to purchase hanging for oven . ace hardwares.
Posted on Jan 18, 2008
MicrowaveSvc
  • 9098 Answers
Your model weighs 41 pounds empty.
That - plus maybe adding another 8-10 pounds for safety - us what your installation needs to be able to handle.
I would think the average cabinet could handle that, but it may be better to add a small steel plate or large washer surrounding the mounting screws to help disperse the weight load.
The owner's manual describes the installation kit you can use to mount it in a cabinet or in the wall, etc. That may be helpful.
If you don't still have your manual you can download it here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 18, 2008
hiltonjug
  • 612 Answers
SOURCE: GE model JE2160BF03 no power. Blown fuse.
They are put out when something metal is put inside and cooked for a few min. They are also put out with power surge. It protects your mag tube. Plus they just go bad sometimes. Could be a number of reasons but these are the most common.
Posted on Nov 17, 2009
heatman101
  • 43501 Answers
SOURCE: I have a GE Microwave/Oven
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 [[]
Posted on Aug 10, 2011
caroldon
  • 17130 Answers
SOURCE: Unit has been working perfectly. Now
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean,solder and reset the board.
Now identify the parts by clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had deposited
then it must be checked or replaced.
See link: http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Now keeping clear of the microwave, switch on, use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues, you can use the microwave safely
Thank You for using FIXYA.
Posted on Aug 24, 2011
Why does the fan keep running on a kenmore spacemaster 300?
Check those 3 micro switches in the door latch assembly. A bad microswitch can blow the main fuse. This usually ruins the microswitch.
Nov 13, 2017 | Kenmore Microwave Ovens
Replaced 20amp fuse that was blown. new fuse did not blow, but oven is still dead.
see this causes and fix it. God bless you
If your microwave oven doesn't seem to work at all, check these: Fuses Door switch Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it. Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work
Sep 22, 2012 | Cuisinart CMW-100 Microwave Oven
GE microwave over the range, model #jvm1740sm1ss has no power.it's only two year old.what could be the cause?
the problem of this unit is power related.
First, remove the unit's power cord from the wall, wait for about 30mins, then plug it back in. It may cool by then and might power on. If it doesn't power on, plug it into another outlet, to make sure there electricity entering into the unit.
If plugging into another power outlet doesn't power it on then the unit is most likely having a power problem.
When electric current comes from the power outlet into the cooker, it goes straight into the power supply board which then circulates the current into the unit. So if the cooker doesn't power on, the first thing is to make sure there is power entering into the machine.
So check the power cord, if it is a 3-pin plug, it must have a fuse in it. check the fuse if it is not blown. if fuse is intact, then power supply board should be checked.
If any machine or electronics device doesn't power on, it means its having a power problem. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter and continuity tester in order to read the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Regards.
Nov 08, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Lost power due the storm' when power was restored micro. never came back on
Possible that during the power outage there was fault in the mains supply and with the oven being plugged on it is possible that the power supply or the main board is damaged.
Unless you are able the top cover it is difficult to confirm if this can be silly fault like a fuse blown which is on the mains circuit or a Step down transformer or the processor board.
Nov 06, 2011 | Maytag MMV1153A Microwave Oven
Ge spacemaker jvm1650sh01 has no power after power outage
Regards.
Nov 02, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Ge microwave JVM1350BW-003 went totally dead. The door switches check good and main fuse is good.
Regards.
Oct 31, 2011 | GE JVM1350BW/WW/AW/SY Microwave Oven
Emerson microwave 1100 watt microwave keeps running even when timer stops bought about 7 months ago
Regards.
Oct 18, 2011 | Emerson MW8168B Microwave Oven
Microwave-doesn't warm anything anymore
Hello rarms1965... chances are that your microwave was the recipeint of a power surge during the power outage you mentioned.. there is no way of knowing what component took the brunt of a surge and it could very well be your magnetron tube, filament transformer of any number of control logic components.. The problem is that anytime you open the case to check things.. unless you know what to look for or even more so.. what NOT to touch ( High Voltage Capacitor comes to mind) you don't know what you are up against. If it isn't a real expesive model ( you didn't provide a brand or model with your inquiry).. then the cost to diagnose & repair could very well exceed teh cost to replace.. Your call.. but whatever you do.. be sure you KNOW what you are doing..
Good Luck my friend..
Sep 24, 2008 | Microwave Ovens
Just stop working
A microwave can be dead for many reasons.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can probably find an exploded view by entering your FULL model number here: http://www.searspartsdirect.com
Jun 07, 2008 | Kenmore Microwave Ovens
Microwave has no power
Is the outlet ok? Can you plug somethng else into the outlet to see if the fuse or breaker controlling the outlet is ok? If there is power at the outlet, unplug the unit and remove the outside cover.
Look for a blown fuse on the motherboard. Replace it with the EXACT value of the original fuse. You can purchase a new fuse at Radio Shack or hardware store or auto parts store. Try powering up the unit again and see if it works now or whether the fuse blows again. If it blows again, the power supply may have been damaged. Was this a power outage or surge? Was anything else in your home affected?
- Jim
Jan 29, 2008 | Goldstar MV-1526 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
