Question about Emerson EWF2703 27" TV
Picture is stretched on top and bottom of screen
The picture is stretched on top and bottom of screen, including the channel numbers and the closed captioning. There are no options on my tv remote to adjust that. What can I do? What happened?
    Sergeant:
    Champion:
  • 346 Answers
You have a vertical linearity problem. change the vertical output and components.you need a qualified tv technician to solve this problem
Posted on Nov 16, 2008
Top and bottom of screen are cut off how do we adjust to get screen to fit
Press the "Aspect" button on the remote until the picture looks appropriate. You are probably trying to display a 4:3 ratio channel on your 16:9 ratio TV. You are probably viewing it in "zoom" mode, which does not stretch the 4:3 ratio video, but enlarges it until it fits the width of the screen, which zooms part of the video off the top and bottom of the screen.
Mar 07, 2011 | Panasonic PT-53WX54 53" Rear Projection...
How do I change it from wide screen to regular? I have a black area above and below the picture.
Hello
You can set the picture size by remote control itself.
You can vide 480i format programmes in three picture sizes. 4:3, 16:9, and ZOOM
You can change the picture size by pressing the PICTURE SIZE button on the remote control.
4:3 Picutre size
To fill the screen, the top and bottom edges are extedted more widely, although the center of the picture remains near the former ratio.
If receiving a 4:3 programme, the image size is displayed in its originally formatted proportion.
16:9 picure size
This image displays the size of standard 16:9 with black bars at the top and bottom.
If receiving a 4:3 programme, the image is displayed with black bars at the top and bottom and stretched wider.
NOTE: If a fixed bar remains on the screen for a long period of time, the image can become parmanantly engrained in the screen and cause subtle but permanent ghost images. Never leave your TV for long periods of time while it is displaying these images.
Zoom picture size [for 16:9 formats]
The entire picture is uniformly enlarged --it is stretched the same amount both wider and taller (retains its original proportion). The right and left edges of the picture may be hidden.
OK.
Dec 14, 2010 | Insignia NS- 27" TV27 TV
I cant keep the picture at full screen fom channel to channel
The reason for this is that the incoming signal is not always the same. Stations broadcast in different formats from 480i to 1080. If the bars top and bottom or side to side bother you then you'll have to stretch the picture (try different modes) to keep the picture screen full.
Dec 24, 2009 | Dynex DX-LCD37 TV
JUST PURCHASED A 60 INCH DLP TELEVISION MOST TV CHANNELS ARE NOT FULL SCREEN.... WHAT STEPS DO I TAKE TO INLARGE THE PICTURE TO FIT THE 60 INCH SCREEN ?
Channels that transmit in 480 or 720 may not fill the screen. You can use the Aspect or Zoom button or feature to expand those channels to fill the screen but there may be some stretching in one direction or parts of the picture may extend beyond the edge of the TV. Some TVs have a "justified" setting that will not distort the center of the picture and just stretches the corners. Look in your manual for Picture Size, Aspect, or Zoom for details about your TV.
Dec 21, 2009 | Radio Communications
Picture is to big for screen
Menu go to setup,go to reset,well be back to factory setting.U will have function to view mode,not than ur video backlight board have problems.
Apr 30, 2009 | Sharp Aquos LC32D41U 32 in. LCD TV
Can't read stuff at bottom of screen
it is possible the picture format is set to stretched. look for a button on the remote that can do this. it could also be the signal. try looking at a different channel that has lettering along the top and bottom and determine if the entire picture looks like it needs to be moved up. if after all this you can still determine that the picture is misaligned post the model number and i can help you move it up.
Feb 05, 2009 | Sylvania Televison & Video
On CNN or during football games banner is cut off
It sounds like you're watching wide screen content on a 4:3 tv, so the screen may be zoomed in so that the bars that would normally be on the top and bottom are not showing. Because the picture is zoomed in, images that would be at the top and bottom are off the screen. If you're watching from a home receiver (Uverse, DirecTv, Xfinity, etc.) you need to change the video settings to let the receiver know that your TV's aspect ratio is 4:3 (full screen) and not 16:9 (widescreen). Also, if your channel lineup has the option of watching CNN on a standard definition channel, that would also help because the shape of the image would be what your tv was designed for. If you watch 16:9 programs, you will have to choose letter box mode (bars on top and bottom because the shape of the widescreen image does not match the shape of your tv), pillar box mode (bars on either side) zoomed, or stretched. Stretched will make the shape of everything appear distorted, as it squeezes a widescreen image on the sides to make it narrow enough, so that everyone will have tall and skinny heads like an old Kung Fu movie. The sharpest picture would likely be to watch 16:9 (hi def) content in letterbox mode (bars on top and bottom) so at least you get the proper aspect ratio that the sports were recorded in, and it comes from a sharper source (HD vs SD). I would just deal with the bars, because even with a widescreen tv, there will sometimes be bars because that's how programs are sometimes recorded, for different visual impact or cinematic effect.
Jun 16, 2017 | Mito Car Audio & Video
Vertical Stretch
You need to adjust "vertical height" in the service program. You need to put the set in "service mode" to do this adjustment. If you google "enter service mode RCA F32665" you should find the procedure. It will be listed in abbreviated letters such as VERT SIZE or VERT HT. Follow the instructions for entering service mode and saving the data closely!! The data you change will be listed as a number between 1 and 63. The number will only need to reduced by a small amount and you can still see the picture behind the data and watch it shrink as you adjust the number down.Always burn the new number to memory (if required) before exiting service mode. Good luck
barneyluc
Dec 01, 2008 | RCA F32665 32" TV
Samsung DLP HL-P5674W Screen is stretched at the top and bottom...
did you ever find out the problem , mine is doing the same thing,
please email highltv3@aol.com if you can help
thank you so much
debi
Mar 05, 2008 | Samsung DLP HL-P5663W 56" TV
JVC AV-61PRO
This is a convergence problem.Could be convergence IC's or short in delfection circuit.
Get a quote from your local service center.
Dec 15, 2007 | Televison & Video
Emerson EWF2703 27" TV Logo
185 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
