Question about Dishwashers
I have a whirlpool ADP 4601 dishwasher and it is asking me to add salt which I have done but i'm not sure how much to pour into the salt dispenser. Also the salt dispenser is full of water - is this mant to be? Many thanks
5 Suggested Answers
  • 69 Answers
SOURCE: dishwasher adp 4601 when switched on the pump
The number of flashes indicates the fault. Reset machine by holding down the start button for 3 secs, then start a new cycle. If fault reoccurs, the number of flashes indicates fault eg 3 flashes, stop, 3 flashes stop, indicates F3 fault.
Faults listed below- advice on repair depends on which fault your machine is indicating, but may give you an idea of what to look for
1flash=NTC (temperature sensor) break- NTC outside normal range.
2flash=water leakage-float switch in base activated.
3flash=heating fault(check element.NTC,control board).
4flash=drain error-blockage in pump or drain system,or faulty water indicator switch.
6flash=water inlet fault-check inlet valve, check inlet hose not kinked
7flash=flow meter failure (flow meter measures water intake volume-large plastic weir located on left hand side of machine-reomve side panel to access)
These a most common faults, but further advice on repair requires counting flashes when fault occurs.
Posted on Aug 09, 2009
  • 220 Answers
SOURCE: Whirlpool ADP 5500 dishwasher stops - light flashes 7 times.
It's a heating issue either a bad heater or bad sensor.
Posted on Sep 01, 2009
  • 1121 Answers
SOURCE: my adp 4601 dishwasher light on the start button
there a sensor error, motor error, or board defective, send to repair.
Posted on Jan 14, 2010
  • 572 Answers
SOURCE: My dishwasher detergent dispenser door won't open
make sure u dont block it with any dishes. manually open it. theres a latch under. sometimes it gums up
Posted on Feb 09, 2010
Do you need to put salt in the dishwasher. If using tablets detergent ...where to put it ?
A lot of dishwashers do not have salt dispensers. If it does, the salt is added to a container which has a lid on the base (floor) on the inside under the bottom basket. Unscrew the lid and add the salt. Use normal pool salt. It is the same as "special dishwasher salt" that you pay a lot for. When full, the salt will last for 12 to 18 months. Most machines that have a salt container, also have a warning light on the panel to let you know it needs refilling. Dishwasher tablets do not add salt to the machine. Make sure you wipe up any salt that you may have spilt on the base of the machine, it will stain or rust the cabinet.
Sep 25, 2014 | Dishwashers
Red salt light is on whirlpool ADP 2962
The sensor is defective replace it.
Apr 06, 2012 | Dishwashers
Where do i put the salt
Hello Maria,
The salt goes in the salt compartment in the base of the washing compartment. Unscrew the lid of the salt compartment (counter-clockwise), pour in salt until the compatment is full or nearly full then screw the lid back on firmly, but do not overtighten it.
If the dishwasher is new and you are using it for the first time, pour about 1 litre of cold clean water into the salt compartment before adding the salt. If you spill any salt or the water spills over the top of the salt compartment, it will wash/drain away the next time you use the washer.
The most important thing is to only use dishwasher salt. The salt is used for water-softening and only salt sold specifically for dishwashers can be used for this purpose.
The picture above is from a Bosch dishwasher. You may have another brand or model of dishwasher, but the salt compartment will still be in the base of the washing compartment and will have a cap which you unscrew as above.
Hope this helps. If you need further assistance, please let me know the brand and model number of your dishwasher.
Regards,
BElectric
Mar 14, 2011 | Dishwashers
Where do I add the salt in the dishwasher
Before i provide you with the solution, Read the below one :-
CAN I USE ORDINARY TABLE SALT?
No. Table, cooking, rock and sea salts may contain additives that can actually increase water hardness. Also, the fine consistency of some of these salts mean they are likely to clog when wet. Always use granular dishwasher salt because it is very pure and is the right consistency for use in your machine.
Granular salt is the ONLY type of salt that should be used to regenerate the softener. Be aware that some varieties of ‘dishwasher salt’ use Dead Sea salt. This variety may contain minute insoluble organic matter that may adversely affect the resin within your softener over time. If you are in doubt about the origins of the salt, ask the retailer or manufacturer.
Now, look at the Video :-
http://www.videojug.com/film/how-to-load-a-dishwasher-for-the-best-results
The steps also include where you need to add Salt in the Dishwasher.You need to be careful with the amount. On few dishwashers, you would have an indication light. Make sure that it should be appropriate.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 07, 2009 | Siemens Dishwashers
Dishwasher (Whirlpool ADP 952) not working
I have a whirlpool ADP 952 and the start button is flashing and it won't work
May 25, 2009 | Dishwashers
Whirlpool Dishwasher ADP 4601 , Light flashing constantly.
There is a switch attached to the door latch that may need to be replaced. (the switch is inside the door).
Feb 08, 2009 | Kitchen and Much More Dishwashers
Whirlpool ADP 9520
press the start button (which is flashing) for a few seconds and it should start again?
Jun 09, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
Whirlpool adp 5540
My dishwasher isnt working anymore after i cleaned the filters? i took out and cleaned the filters in it and now it doesnt seem to be working properly. it goes thru the cycle but its not cleaning. the dishwashing tablet falls to the bottom and isnt even dissolved completetly after the cycle has finished. is it possible that its blocked somewhere?
It is a Whirlpool ADP 5540
thanks for your help
**** the walls are still dirty after the cycle but there is steam in there as if its done its normal cycle
May 13, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
Whirlpool ADP 5966 Dishwasher using the complete salt load in 6 washes and coating all the dishes in salt that would not rinse off. I filled the salt and 6 washes later it was requiring a new load of...
Hello, we are sorry to hear that you are experiencing this problem with the Dishwasher. We would recommend having a certified technician out to diagnose the problem. If you would like further assistance you can send your name, phone number, address, model/serial numbers and the date on which you purchased the Dishwasher to Whirlpool_Reviews@Whirlpool.com. Thank you.
Apr 17, 2017 | Whirlpool 24 in. ADP5966 Free-standing...
Dishwashers Logo
85 people viewed this question
Top Dishwashers Experts
