Question about BenQ MP610 Multimedia Projector
I have not used my PB6100 for a little while and when I tried to run it I only had a plain screen. I could not even get the menu to show. The lamp had less than 300 hours at the previous showing.
George - I have a similar problem. Low light output, no blue screen, or BENQ power up - nothing but low light being projected. Did you solve your problem? Same as you we have not used the projector for a few months. TIA Jim
Posted on Jun 18, 2011
How do i flip the projector image,its now in upside down mode.
go into the menu, in the image adjustments, and there should be a screen adjustment, and select front (and non ceiling).
Aug 03, 2009 | BenQ (200NSH-LAMP) Projector Lamp for...
Projector displays reverse image also has grayish purple color
Use the remote to go into the menu and change the screen position. There are 4 to choose from, flip left, flip right, flip upside down left, flip upside down right. It may be tricky to navigae the menu backward though.
Dec 31, 2008 | BenQ PB6100 Multimedia Projector
Blue screen
Hi Guys,
I recently struck this issue with one of our PB6100's. To resolve I did the following:
  1. Enter service menu (found on AVForums): PRESS AND HOLD UP BUTTON UNTIL LAMP HOURS ARE DISPLAYED, PRESS THE POWER AND BLANK BUTTONS TOGETHER
  2. Under the Fan menu select "More Options". You should then be in the "Fac7 Submenu".
  3. Select "Hard Reset". Note that this will reset the lamp hours also!
  4. Power off & then on again. Test input.
The above worked for me. Hope it helps.
Jun 20, 2008 | BenQ PB6100 Multimedia Projector
Mainboard of PB6200
Hi, I'm looking for a mainboard too. Just last week one of the PLL clock multipliers wacked-out and overclocked one of the DLP ICs. (confirmed by O-scope and service manual). Guess they timed the warranty just right before the units start to die.
Jun 18, 2008 | BenQ (200NSH-LAMP) Projector Lamp for...
BENQ FLAHING
Hi cvijr
This can only one of two things - the lamp or the Ballast ( lamp's powersupply )
Normally the PB6100/6200 lamp's has got markings on the lamp itself when this flickering occurs.
Take out the lamp by unscrewing the lamp door at the bottom. Then look for any vein like looking marks in either black or white. Or even a bubble at the bottom end of the lamp's shaft.
If you can spot anything out of order , then the lamp will need replacement.
If not , then you'll know for sure that it is the Ballast that is in need of either repair or replacement.
Part Numbers :
Ballast :5D.J8612.011
Lamp : 60.J8618.CG1
Hope this is of help and thanks for using Fixya !
May 05, 2008 | BenQ PB6100 Multimedia Projector
Projector Problem- Screen appears Blue
Hi there
Press the source button on your Projector until it reads RGB.
If this doesn't work , right click on your desktop and go to properties - check that your seconadry screen is attached in your advanced settings.
Apr 26, 2008 | BenQ (200NSH-LAMP) Projector Lamp for...
BenQ PB6100 extremely dim screen/projection
Hi skeeterJ
This is most probably your lamp , I have had loads of PB6100 's that has even had less hours on the lamp than yours and needed replacement.
Keep in mind that the 2000-3000 hours they talk about on a lamp is just a rough factory estimate. The time you get on a lamp is determined by how you use the Projector - because at the end of the day the lamp is just like a globe in your home - it doesn't like being swithed on and off for short periods. This is a mistake most Projector owners make - by thinking they are saving the bulb's lifetime and switching it off for short periods.
You can take my word on this as I am a Authorised BenQ Service Technician.
I've had clients who got 10 000 hours on one bulb just because they left the unit running for longer periods.
Lamp Part No : 60.J8618.CG1
Easiest way to make 100% sure before investing in a new lamp is to take out the lamp by opening the lamp door at the bottom.
Check for any vein like looking marks in either white or black or a bubble on the shaft.
If you have any further troubles or questions , feel free to post another posting and I'll answer it for you ASAP.
Thanks for using Fixya and good luck !
Apr 24, 2008 | BenQ PB6100 Multimedia Projector
PB6100:No picture display
The projector needs to be turned on first, then connect it to the laptop. If the picture still does not show at that point, press the FN and the LCD keys on your laptop at the same time. This should work.
Feb 10, 2008 | BenQ PB6100 Multimedia Projector
Reset after lamp replacement
benq mp610. press EXIT button for five sec. you see counter hrs. then press AUTO button to reset
Oct 13, 2007 | BenQ (200NSH-LAMP) Projector Lamp for...
BenQ MP610 Multimedia Projector Logo
117 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Electro Med Services...
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
