Question about Ryobi Garden
I have a Ryobi RPT-2610 26cc 2-stroke line trimmer and one of the screws came loose on the pick-up coil.I set the the gap to 0.25mm using a piece of brass shim,to no avail ,can you please tell me the size of the air-gap?.
5 Suggested Answers
bozcro
  • 867 Answers
SOURCE: 2 Cycle Gas Trimmer will not start
it is normal to see air bubbles in line when pumping the bulb. to make sure what the problem is, try starting several times, remove spark plug. if dry, yes no fuel, remove the carb. if wet, place plug on engine block and look for blue spark. no spark means you need new plug, plug cord or ignition module
Posted on Jul 24, 2009
lemmingleejn
  • 173 Answers
SOURCE: need to know the size to use to gap the coil and
The gap will vary, depending on engine wear.
If you have a ' feeler gauge', it won't take you long before it runs beautifully.
That's it,
oh and, don't forget to rate:)
Posted on Jul 28, 2009
  • 4 Answers
SOURCE: Ryobi chainsaw magneto gap
The gap needs to be as narrow as possible without any actual rubbing of the rotor against the magneto. The spacing is not as critical as with spark plugs or points (remember them?) since unlike those gaps there is no spark jumping across this gap.
Generally, as long as the magnetic field is strong enough, the magneto will produce the necessary spark at the spark plug. The closer the magnets are to the coil, the stronger the magnetic field will be across the coil, and therefore the stronger and hotter the spark.
I have replaced magnetos and they are simple to install, and almost impossible to mess up if you do it this way. All you need is a piece of thin cardboard (not corrugated). I use a glossy business card without raised lettering (so it slides easily), or the like.
1) Rotate the flywheel so that the magnets are NOT positioned in front of the magneto, then loosen both screws of the magneto so it can move freely.
2) Insert the business card between the magneto and the flywheel such that the glossy side of the business card faces the rotor.
3) Then BEND the business card back over each side of the magneto (in other words away from the flywheel) so it stays fixed and can not move from side to side when you rotate the rotor.
4) Then while pinching the magneto and ends of the business card tight between your fingers, rotate the flywheel to position the magnets directly in line with the two sides of the magneto.
Note: The magnets will grab the magneto and try to move it. As long as the slippery side of the business card is facing the rotor and you haven't removed the screws, it should move fairly easily.
Since the magnets want to pull tight to the magneto, but the business card thickness is the same across the entire surface, this gives you an even spacing between both sides of the magneto and the rotor. Essentially, the magnets on the rotor do all the work for you. with regard to alignment. As long as the magnets (flat shiny polished square surfaces on the outer rim of the rotor) align directly with the two faces of the magneto, the alignment is automatic.
5) Once you have the magneto and rotor in perfect alignment, cinch down both screws in an alternating method, first just to where they start to grab, and then back and forth a few times until they are firmly tightened.
6) Now, unfold the flaps of the business card and let it move with the rotor instead. You should be able to rotate the rotor away from the magneto and the business card should slip out easily. It may stay where it was or it may slide out from the magneto - either way will work.
7) Once past the magnets, the business card should come out. You may have to move the rotor back and forth gently a few times to get it to come free. When you are done, the magneto should be in perfect alignment with the face of the rotor and the rotor should spin freely without any rubbing.
8) Confirm the above and then reassemble and go cut some trees.
Phil
Posted on Jun 01, 2010
Testimonial: "Thank-you very much, just as I suspected - had not come up with of an alternative to the feeler gauge so that was most helpful."
  • 111 Answers
SOURCE: We lost the operator's Manual
The unit should have a model number on it. You should write this number down and keep it in a safe place. When you have the model number you can go to this website and look for it by typing in Ryobi and (Model #). This should get you in the right place. =) www.manualsonline.com
Posted on Mar 30, 2011
I have a ryobi rpt 320e grass trimmer. my question is when pushing the prime bubble , should fuel come out of the small hole on the plate under the diaphram bowl.
the small hole should have a line attached to it so fuel goes to the carb --the bulb --has inlet from tank to bulb -outlet from bulb to carb
Nov 24, 2016 | Ryobi Garden
I have a Ryobi RPT3000 trimmer. Firstly how do I top up engine oil? And then how do I restring it?
The engine on that trimmer will be a 2 stroke 30cc engine not a 4 stroke.
"Two Stroke Oil" is added to the fuel for a 2 stroke fuel mix in accordance with the proportions specified by Ryobi for that engine. The required petrol/oil mix may be printed on the top of the fuel cap. No other oil is used in a 2 stroke engine.
There are a number of videos on Youtube people have uploaded which will show you how to replace the pull cord on a trimmer.
Dec 28, 2015 | Ryobi Garden
How do you check engine oil level on ryobi 2 strike line trimmer rpt-3000
Small two stroke engines don't have oil in the engine that you can check like a car engine has. The oil is a special "two stroke engine oil", that is mixed with the fuel in a preset ratio. Like 50:1 or a ratio similar depending on the manufacturer of the equipment. You would typically premix a certain amount of the oil with gasoline in a can as directed on the label.
Sep 21, 2014 | Garden
What is the air gap between the coil and flywheel on Ryobi 700r weed trimmer
Set it at about .010"-.012". That is about the thickness of a standard business card (which many use to do just this same repair).
Sep 11, 2011 | Ryobi Garden
I've lost the user manual for my Ryobi 25cc RPT 2543c strimmer. Can you please advise where the dip stick is to check the oil. Can't seem to find it.
Ryobi RPT 2543c This is a 2 stroke engine, so no dipstick. You mix oil with the petrol (ratio 50:1) or 200ml of two stroke oil per litre of petrol, and that's how the engine is lubricated. Hope this helps, arvidis@btopenworld.com
Apr 19, 2011 | Ryobi Garden
AHOW TO SET AIR GAP ON TB 70 SS
The Torx head screws holding the coil in place have to be loosened. They may be tough as sometimes when assembled, the factory uses Threadlocker on them (alongwith the cylinder bolts). If you have removed covers and are at the flywheel/coil area rotate the flywheel till the magnets in it line up with the leg or legs on the coil. Insert a business card (folded in two) in between and let the magnets "draw" the coil onto the card. The proper gap is about .010-.014" or so. The closer the better. Make sure to tighten the coil screws extra tight. You can coat them with some thread lock if you choose so they can't vibrate loose. The business card gap works on most small engines.
Aug 14, 2010 | Troy Bilt Tb70ss Gas Trimmer
Spark plug gap keeps closing on 2 stroke engine
it could be the spark plugs are to long and the piston is hitting the glug
Mar 21, 2009 | Ryobi Garden
Ryobi 18V Hedge Trimmer Blade Question
I use a dremel with a sharpening stone, if u don't have one you can also use a power drill with a small sanding disk (1 inch) and course sand paper (30 or 40 grit). or you can use a bastard file. its too tight to use any kind of angle guide so just take your time and do it by eye. it shouldn't take much to get them sharp enough to do the job, over-sharpening is unnecessary and dangerous, and will make the blades dull faster. sharpen all the free blades, top and bottom, then start the trimmers to advance the blades to free up the sides you couldn't get. i use a light penetrating oil to clean the blades first, then lithium grease spray to lubricate.
Aug 27, 2008 | Ryobi 18V Hedge Trimmer
Garden Logo
183 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
