Question about Goodman Heating & Cooling
Where is reset switch at to started fan back up?on 2004-2005 split system heat pump goodman.
    President:
  • 2,047 Answers
Goodman doesn't make reset buttons with their units, however you can shut the power off at the breakers or at the switch for the furnace power if equipped. Do this for 3 mins and turn them back on this should reset the system.
Hope this solution has been helpful?
Posted on May 23, 2011
On a cpkj 48-1B Goodman heat pump I am having condenser fan issues. runs full spedd for a while then cuts down to barely running, Even after changing the motor and capacitor.
Does the condenser utilise head pressure control to maintain head pressure? if so is the unit fully charged...r22. r410 Freon.If the unit is an older model. the fan motor only runs at 850 r.p.m design flaw. The newer units now run the fan at 1075. R.p.m. I have installed many Goodman split systems and was having problems similar to yours. Hope this. Helps you
Jul 11, 2015 | Goodman Heating & Cooling
Need to know how a mobile home split system is wired with just ac and 15 kW heat stripesqqq
you have to have 240 volts for power. 24 volts to operate cool and heat. thermostat feeds color code white to heat yellow to cool green to fan. think of the thermostat as a light switch. transformer in system feeds common to different controls & usually red to thermostat which is then switched to what it is set for.
May 13, 2014 | Goodman CLQ36AR49 Air Conditioner
Where is reset button on R-410A split system heat pump
No reset, high and low pressure switches are auto resetting.
Dec 04, 2012 | Goodman Manufacturing Heating & Cooling
My Amana heat pump model PTH153B50AJ does not cool properly. The compressor comes on and the fan works.
This sounds like a freon problem your system probably has a leak in the system somewhere. Amana has tons of problems with there equipment. They make there coils paper thin and they split especially on a heatpump. Amana used to be a good brand and then got bought out by goodman manufacturing and have turned there product into ****. How old is this unit?
Jun 14, 2011 | Amana PTH153B50AJ Heat Pump Air...
Fedder Heat Pump not Running
you can check your heat pump on the outside by turning off the power and listening to see if it makes a whoosh sound. and then turn it back on you should hear it kick in. Is the outside unit running? Sounds like an electrical problem maybe in the breaker or the contactor on the inside of the unit. This is where the 24 volts from the thermostat call to the 240 volts to kick on the condenser fan and compressor. Be real careful in messing with this because of the high voltage.
Jul 09, 2010 | Fedders C36ACD1VF Split System Air...
Goodman heat pump the fan runs but blows the 3amp fuse
The 3 amp fuse is for you're control voltage only, which is 24volts,ac. Something in the control side of your unit has a direct short in it. Since I am not on site to help you find out what part is at fault, I will give you some things to check out.You say you're indoor fan runs. I can only assume when you put the thermostat fan to on and not auto. Since this is a heat-pump, and not a gas fired unit, you will have a few less things that are 24volts.You say it blows the fuse on both heat and cool. You or someone that may give you a hand needs to do a process of elimination. What you will need to do, is to check all of the 24v. components to see which is at fault. The 24volts via relays and coils are what controls the motors, compressor, ect. We know that the indoor fan is good. I would be looking at the contacter coil first, even though the thermostat is 24volts. Since the contacter controls the condenser fan motor and compressor, my guess would be the coil on your contactor is shorted. I am not sure if you're heat-pump is a package unit or a split? Either way, you need to open up the control section of the compressor section which on a split its the outdoor unit. On a package unit, its where the main power enters. That would be on what ever kind of Goodman you may have, the 220volts come in and each of the 2 hot wires connect to the bottom of the contactor.What to do 1st.What ever it is, a split or a pack unit, turn off the main power to unit, split, outdoor unit, pack, whole unit.Even if this is a split system, when you turn the power off to the outdoor unit, you will still have 24volts to it when you turn the stat on.The 24 volts comes from the fan center on the indoor unit. With all of the power off, look at the contactor. On each side you will see 2 wires to a copper coil. Pull off these 2 wires, and dont let them touch anything even though they are dead.Turn power back on and check the 3 amp fuse. It should be fine. Now, with the power turned back on, touch these 2 wires back to the coil.This should blow the fuse. If it does, that contactor needs to be replaced.I know this is a lot to check, but I am sure the contactor coil is shorted. You will have to buy one from a retail appliance store. Every wire must be put back in its original place. If you don't think you can test this, I would advise calling someone out. I know this is a long solution, but i am sure that is the problem. Let me know please. Good Luck,
Shastalaker7
Ps an electrical meter would be of a lot of use to you. One more thing, if the copper coil on the contacter is burned and black, just turn off all power and replace it. I am certain this is your fault.
Nov 12, 2009 | Heating & Cooling
We live in SC, have a Goodman 4 ton split system w
First of all is this unit a heat pump i'm not up on goodman model #'s if it is a heat pump reversing valves do go not a real common problem 1000.00 is excessive i would be inclined to get a 2nd opinion. plastic over the sand could create a condensation mold problem. Good luck. Tom
Jun 23, 2009 | Goodman CLQ36AR49 Air Conditioner
Goodman SSX16 split system not working
Defective thermostat wire.
Defective contactor.
With the t-stat set for cool and turned down on a low temperature, check for 24 volts at the contactor low voltage hookup. If you have 24 volts, replace the contactor.
You can manually close the contactor to make sure the high voltage is going through it.
Apr 28, 2009 | Goodman CKL60AR60 Air Conditioner
Heating & Cooling Logo
60 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
