SATA Hardisk canot read into bios.. the sata cable is brandnew and SATA hardisk is also new
  • dhcpdiscover May 23, 2011
    is this your first sata hard disk attached to your current motherboard? any other sata disk can be read by the bios? have you tried the disk on another system?
  • 36 Answers
You will need a RAID driver for your motherboard. Contact your motherboard manufacturer for assistance.
Posted on May 23, 2011
Sata hardisk is not working "usb not recogenised"
Connect hardisk directly to computer without usb
go to start > run > cmd
type chkdsk /p enter
it will fix your problem
remove hardisk via safe remove
and connect via usb cable
Jul 29, 2011 | Conrad WD HDD 250GB SATA 35" WD2500AAJS...
Hardisk not detected
- Check hard drive connection (SATA cable).
- Check Bios Setup (hard drive configuration - SATA drive should be enabled)
May 16, 2011 | Western Digital WD Scorpio WD3200BEVT hard...
Boot device not found Please instal l an operating sistem on your hard disk. Hard Disk - (3FO) F2 Sistem Diagnostics Foe more information, please visit: www.hp.com/go/techcenter/startup
please go to the bios setup by pressing F2. then check your sata hardisk if detected. if not, remove the sata hardisk and use it as external by using external sata case adapter. then plug to the other pc and check if spinning or detected by another pc. once not detected or spinning change your sata hardisk. but if detected, there is a problem on your dv6000Z notebook.
Feb 01, 2011 | HP Pavilion dv6000z Notebook
By startup fails to see IDE 0 and IDE 2 , says no channel 0 and channel 1. Is it possible that the cmos battery is empty?
Once your powered on the CMOS battery is no longer an issue. If it isn't reading the IDE or SATA channels it could be because they are not set in the BIOS. Check your BIOS setting and double check your cable connections. You also need to make sure, for IDE devices, that one of the drives is set to Master and the other to Slave otherwise they confuse the board and cancel each other out.
Jan 03, 2011 | Asrock P4VM8 Motherboard
Did not detect the additional sata hard disk?
Have you tried connecting the SATA hard-drive to a different computer, just to prove that it is not a "dud" ?
Is the SATA hard-drive getting power?
(It should warm-up a bit, and you make feel it vibrate as it spins.)
Have you tried a different SATA cable between the hard-drive and the SATA connector on the motherboard?
Check the BIOS settings, to be sure that detection of SATA drives is "enabled".
Apr 09, 2010 | Computers & Internet
I cannot install software
Hi..
This happen due to 3 reasons,
The Hard drive is bad.
The BIOS Setting have to be put to SATA.
During the the installation the have to press the F6 option to install the SATA drive drivers.
Let me know
Thanks
Smith
Aug 09, 2009 | ASUS P5LD2-VM Motherboard
160gb SATA hardisk opareting system not installed
Check data and power cable. Verify in BIOS. Change SATA Port. Change SATA Cable.
Regards;
Hassan
Jul 14, 2009 | Computers & Internet
I have a new 8ogb sataII Exelstor hardisk which i
Windows XP does -not- have native SATA support and therefore will not recognize a SATA drive without first installing 3rd party drivers.
To go around this problem without installing drivers check your BIOS. There might be something in there where the bios will emulate an IDE controller.
If not, you'll need a floppy and the sata drivers. A flash drive will also do if the motherboard bios supports legacy USB. To find the drivers, simply go to the motherboards manufacturers website.
Mar 03, 2009 | EPoX EP-8KRAI-X Motherboard
Formating hardisk with sata connection
1) Be sure that your motherboard support SATA - See Bios
2) Using the Win XP installation CD you can format the drive. If you cannot load windows during the installation hit F6 to charge the SATA drivers.
If your sata drive is working like a second disk, you can format it directly from windows.
Start>> Control Panel >> Admistrative tools >> Computer Management
Or using any partition tools...
Sep 23, 2008 | Seagate Computers & Internet
Computers & Internet Logo
108 people viewed this question
David Payne
David Payne
