Question about Samsung LN-R328W 32 in. HD-Ready LCD Television
LA32R71BM/XTL SOUND OK NO PICTURE - Samsung LN-R328W 32 in. HD-Ready LCD Television
Motorola radio set XTL 5000 audio is not comming spk cables are ok. Main cct board is faulty.whst I do pl help me
Check that you have the radio set to message trunking. it sounds like your in transmission mode.
Nov 10, 2014 | Radio Communications
I have xtl 500 model no L20QSS9PW1AN .audio is not comming.its audio interface board consolete is ok, spk is ok cables are ok I also re software but same condition .some fault is inside the main board pl...
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Nov 09, 2014 | Televison & Video
Hi I am hoping that somebody could help me out with that samsung TV which i have purchased before 5 years ago, tv having problem regarding all about with sound of tv (model no-CZ-21K5G7 type-KS9A21K5 SVC...
Hello
you have given me a detailed description of the fault of your Samsung TV. At first, make sure that the "mute" function is in 'OFF" positon. If it is in "ON" position, no sound output will be there from your TV as you know. If it is alright, switch OFF your set by its mains power ON/OFF switch at its front panel. You have to check this first. Keep your ear very close to the speaker side of your TV, and switch it ON by the front panel switch, and listen, whether there is any "Thumb" sound comes from the speaker or not. If there is sound, it means that the speaker is alright, and the sound output section inside the main board of your TV is faulty. If there is no sound "Thumb" from the speaker, the speaker has got damaged, and should be replaced.
The second step needs some skill in electronic work. You must have a good quality multimeter and soldering iron to proceed. Open your TV, and pull out the main circuit board out, keep it upside down, and check for any loose sodering at the audio output side in the circuit. it is a common fault to all kind of TVs that, loose solderings will occur after a long period of use. heating and cooling of these components in the audio output section will result in loose solderings at the termianals of componets. Just resolder most of the suspected solder point by applying a little more solder over it. Care should be taken not to short circuit adjecent sodler points when do this work. If this does not help you, measure the voltage at the input pin of the audio output IC. If it is found ok, desolder it out the audio output IC from the circuit board, and replace it with same type and number. OK.
Mar 18, 2011 | Samsung TXN2730F 27" TV
No picture sound ok,osd ok.
LG 42pj350r this led tv sound ok but not cume picture
May 25, 2010 | Panasonic VIERA TH-42PX80B 42 in. Plasma...
LCD TV LA40R81BM/XTL tv tick tick sound 5min then strat
Hi my name is Roety,
I can help you with your issue ,
This is most likely a power supply issue
I usually replace the swollen capacitors I can see
A repairman would charge about $300 to replace them for you.
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
Dec 15, 2009 | Samsung LA40A450 40 in. LCD TV
I have been given a Bowflex XTL fitness gym and I don't have a manual for the gym. Where can I get an instruction manual.
Online Bowflex XTL owner manual -no charge. Download PDF file at:www.djkcomputing.com/bowflex/index.html or fitness.manualsonline.com/manuals/mfg/bowflex/bowflex_home_gym_product_list.html
Either of these site will address your needs.
Sep 02, 2009 | Exercise & Fitness
Xtl head shows "maintenance mode" "remote device" is it not programmed? Also is control head wiring red 12 volt and yellow ign.?
The red wire on the remote head should go to the battery (with a fuse inline) the yellow wire should go to a switched 12 volt source (with a fuse).
The XTL radio is in need of correct programing, With out looking at the codeplug I would say that the option for remote head was not checked.
Hope this helps, Bill
Aug 22, 2009 | Motorola Radio Communications
Dishwasher won't start - non responsive
Check the door switches. Both. and the wiring going to them
Jan 23, 2008 | Whirlpool DUL300 XTL Built-in Dishwasher
Samsung LN-R328W 32 in. HD-Ready LCD Television Logo
55 people viewed this question
Jerry Greenberg
Jerry Greenberg
