Question about Fisher and Paykel DEGX1 Electric Dryer
A loud banging noise when dryer is running. Sounds like washer does when it has an uneven load. But dryer is not even close to being overloaded. Since it is a top loader dryer and the drummer rolls shut after lid is locked could it be that , Also dryer is also not drying clothes properly since the load noise has started. Please help
  • Fisher and P... Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Posted on May 25, 2011
GE Profile washer, tumbler out of balance?
Empty, fill with water only run through spin cycle. Replace clothes
do not overload and try to distribute clothes in an even weight pattern over the tub bottom.
Sep 04, 2014 | GE Profile WPRE6100G Top Load Washer
Loud noise during spin cycle now they are stacked
a loud noise comes when you forget to remove shipping bolts after installation or if the shocks are worn out it makes noise thirdly the bearings might be worn out if the washer is more than 6years old
Jan 21, 2013 | LG Cherry Red Steamwasher Wm2487h Front...
Loud banging noise in dryer (maytag). Have taken dryer apart. don't know how to tell if drum rollers, belt, and blower wheel are okay. Don't know what else could be causing loud noice.
the most common culprit of banging is an uneven spot on one of rollers. It may not be really noticable, but a slight flat spot can form on them.
Nov 15, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Why does my front loader washing machine bang loudly during the wash/rinse cycle - it is not overloaded or on an uneven surface?
it is either out of balance from over loading or the center rotorey bearing is bad ,,most likely problems
Nov 09, 2009 | KitchenAid KAWS850L Top Load Washer
First: Loud Banging Noise. Now: No spin cycle.
Sounds like it may have been overloaded, or unblanced, I would say it would be better to replace....it can get pricey if the first fix doesn't work. Washers don't cost what they use to, get a scratch and dent sale item and save money too!
Aug 09, 2009 | Washing Machines
Dryer banging
Check the vibration damper rods. It is detecting an uneven load and stopping.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 17, 2009 | Kenmore 88732 Top Load Stacked Washer /...
Very loud banging noise when spinning
sounds like a balance problem may be when the drum was replaced they didn't fit the new drum in the correct spot the other thing that would cause load banging and excessive vibrations in the machine is if the shockers are worn out,
believe it our not even washing machines have shockers to dampen the movement of the drum spinning
Dec 19, 2008 | Indesit W 123 Front Load Washer
WASHING MECHEN PROBLEM ELECTROLUX
Hi DRVBM
Welcome to fixya.
I'm Huuum and happy to assist you,
Tuk Tuk or banging may mean several things.
Uneven load or over load of cloths, meaning to mush inside at one time.
Or if it is a top load washer and, an old washer it may have a bad coupling connect in it to the transmission .
What's the model number, year of washer and slowly describe the issue!
with the answers to the above questions I may help you more!
Check these!
Is the load balanced and the washer level? The wash load
should be balanced and not overloaded. The washer must be
level. The front feet should be properly installed and the nuts
tightened. Reset the rear leveling legs (if needed). See the
Installation Instructions.
Did you completely remove the yellow shipping strap with
cotter pins? See the Installation Instructions.
Huuum ,
Please leave a rating at the end
Sep 26, 2008 | Washing Machines
Loud noise while agitating in wash cycle
If you begin dissassembly from the tub down, you wil come to the transmission with the spindle sticking out of it. If you undo the bendable tabs all around the transmission it comes apart in two halves. Careful, its full of oil. The spindle has a plastic gear bolted to the bottom of it. It meshes with other gears in the tranny. It has sheered teath and is making the noise.
Sep 24, 2006 | Admiral AAV7000A
Fisher and Paykel DEGX1 Electric Dryer Logo
184 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Bill Eager
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
