Question about Toshiba e-Studio 350 Copier
I have One Copier (Toshiba C350) this is color copier i face one porblem Sound is coming - than Error on display is coming - Call Service C360 plz give me solution
    Scholar:
  • 78 Answers
Charger cleaner motor abnormality: Charger
cleaner motor is not rotating or wire cleaner is not
moving normally.
Posted on Jun 05, 2011
Bizhub C350 - C-0510 error code how fix copier
Turn OFF the copier.
Press and keep pressed the Uitlity key and turn ON the copier.
Keep pressed the Utility key when will Trouble reset message displayed.
Release the Utility key,touch the message and turn OFF the copier.
Wait 1 minutes and turn ON.
Apr 12, 2013 | Konica Minolta DiALTA Di200 Copier
Konica minolta c350 error code c-0096
If your copier models is Konica minolta Bizhub C350 reset the error code:
Press and keep pressed the Utility key and turn ON.
Keep pressed the Utility key and wait will Trouble reset message displayed.
Release the Utility key and touch the message.
Turn OFF the copier,wait 1 minutes and turn ON.
If the code persist enter in the service mode,select counter,select service call condition and read the trouble code description to lacalizate the truble.
If your copier model is KonicaMinolta Dialta CF3102 or OCE CS 220 the code C0096 refer to Transfer belt separation.
Apr 09, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
MINOLTA C350 ERROR CODE C0200
Cyan image unit replace it. Reset code by opening and closing the front door. Also try reseating it.
Jan 15, 2013 | Minolta C350 Color Printer/Scanner/Copier
HI! I have one machine Toshiba C350 this is Color
Hello
The error code that is displaying, is the charger cleaner motor abnormality: Charger cleaner motor is not rotating or the wire cleaner is not moving normally.
Please try the following.
(1) Check if the main charger is installed normally.
(2) Check if the charger wire is broken.
(3)Check if any of the connector pins of the charger cleaner front/rear position detection switch is disconnected.
(4) Check if the cleaning pads are damaged or removed.
(5) Check if any of the connector pins of the charger cleaner motor is disconnected.
(6) Replace the charger cleaner motor.
(7) Replace the Logic board.
I hope this helps a bit
Regards
May 23, 2011 | Toshiba e-Studio 350 Copier
Estudio3500 spanner flashing call service, how do you find what the error code is
When your copier is displaying an error the code will be found in the top right hand corner of the display. It will be a mixture of letters and numbers and will be 4 characters. If the copier is not displaying an error code, holding the c and 8 button will make it appear.
Sep 24, 2010 | Toshiba E-Studio 3511 Color Copier
F 105
How do u get in service mode on a toshiba 3511
Nov 06, 2009 | Toshiba E-Studio 3511 Color Copier
Error code H4-00 and machine is "locked-up" in scan mode
H4 is a fuser error. It needs to be replaced by a tech. Sometimes they can reset this error in service program.
Apr 24, 2009 | Toshiba E-Studio 3511 Color Copier
Toshiba e-Studio 350 Copier Logo
145 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
