Question about Kirby G4 Bagged Upright Vacuum
G5 Kirby. Works in Neutral fine. When Drive is engaged and I push forward, the wheels do not rotate forwards, however on the pullback stroke the wheels rotate backwards. What causes this? Something is clearly in the wrong position, so a diagram showing the correct position of the part that is affected would be useful.
  • Anje Yelf May 23, 2011
    I have the same problem with my G5. With the Drive working on the pullback stroke, it pulls back very quickly and unexpectedly rams into one's feet.
    Do the Fixya experts know how to explain this?
  • Kirby Master
  • 3,053 Answers
Hello, anje
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about vacuumcleaners and possibly yours, from
repair to trouble shooting it. http://home.howstuffworks.com/vacuum-cleaner.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 29, 2011
In drive I can push kirby forward but not backwards
it will be the transmission this video will help you
Oct 17, 2012 | Kirby G5 Bagged Upright Vacuum
The drive on my Kirby G-5 is stuck in forward.
Motor housing will need to be removed and transmission a linkage adjusted. Take to a pro shop for this one.
Sep 08, 2009 | Kirby G5 Bagged Upright Vacuum
Can't seem to pick up small items like lemon pips with Kirby G5. It just runs over them or pushes them backwards and forwards.
It sounds like your belt is broken, OR your beater bar is rotating but has not been adjusted downward to reach the carpet pile. Check by running the vacuum and looking to see if the beater is moving.
Jun 17, 2009 | Kirby G5 Bagged Upright Vacuum
Kirby G5 rear wheels lock up completely when in "Drive"
When wheels lock when vacuum is OFF - it is normal. If it happens when Kirby is ON then there are a few things that may have gone wrong
Primary drive belt is broken or something is wrong with plastic gears. See how to check the primary drive belt HERE.
If it is fine and gears are spinning - then something must be wrong inside the transmission. Parts for tech drive are not available from manufacturer so you are on your own. It is not really complicated - 2 clutches that engage and disengage depending which direction you push the vacuum. But if something in there is broken - you have to get a new tranny. It is not like getting a transmission for a truck but it still will set you back by about 100 $.
Good Luck
Rocky
May 16, 2009 | Kirby G5 Bagged Upright Vacuum
I have a Kirby G5 vacuum that when light pressure is put on the handle it moves forward but in a jerky movement. Like the drive is engaging and disengaging. If you keep forward pressure on the handle the...
I hope adjusting position of the position of the "pivot spring assembly" will help. but you may have to disassemble entire slide assembly to clean it up if it still does not work smoothly. See instructions HERE (adjustment is explained in step #6). Try to "play" with screws #4 and if it does not help - clean slid.
Good Luck
Feb 28, 2009 | Kirby G5 Bagged Upright Vacuum
Sweeper vibrates when pushed forward.
do u put it on drive or neutral? does the wheels spin when on drive? is the height adjuster on the right level?
Sep 09, 2008 | Kirby Ultimate G Bagged Upright Vacuum
G5 Kirby drive problem
Gary...
You need to adjust your transmission. Here's a link that may help...
http://www.greatvacs.com/Kirby%20Transmission%20Adj.shtml
Marci
Sep 05, 2008 | Kirby G5 Bagged Upright Vacuum
Kirby G5 - the Tech Drive does seem to have much power
you need either a new nutreal cam bracket assembly, that is what engages and disengages the tech drive.OR to adjust the handle pivot assy- diffucult . this is not for the faint of heart. it is possible to fix them as i used to repair kirbys, however, I remember how frustrating it was to figure out how to disassemble and reassemble them. it is very complicated to a novice. I would recomend having it repaired professionaly. it is possible for a professional to repair it in a very short period of time.
another thing to consider. look on the UNDERSIDE of your Kirby, between the two drive wheels. just in fronnt of the tech drive/nutreal switch. there should be a screw there, tighten that screw up. actually tighten all of them. on My generation 3 the center screw came loose and it would not go in to drive and it would make an aweful clatter. hope this was helpful
Jul 08, 2008 | Kirby G5 Bagged Upright Vacuum
Kirby G5
nuetral/drive, the g series has a power drive motor for the back wheels
May 13, 2007 | Kirby G5 Bagged Upright Vacuum
Kirby G4 Bagged Upright Vacuum Logo
71 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
