Question about Dishwashers
Our dishwasher continuously flashes "CL"
    Guru:
  • 500 Answers
Hi trrhodes,
I believe the CL you are getting means "Child Lock". Under normal circumstances there should be no activity at all on your machine.
Please do the following:
- On the Facial Panel (Where the buttons are located), look for 2 buttons marked together with a line, it should also have a face of a child somewhere on that line.
- Press both these buttons together for 3 - 5 seconds, this should reset the Child Lock.
Kind Regards :-)
Jacques
*If you found this solution helpful, please rate it
Posted on May 26, 2011
Electrolux dishwasher fdb2310lcc1 flashing cl on display
Hello sandy miller, thanks for your post!
From my understanding your Electrolux dishwasher is flashing "CL". Typically, that stands for close door it could be an issue with the control panel, door latch, or door strike. I would recommend having a professional technician come out to properly diagnosis your dishwasher to avoid any unnecessary part purchases. Hope this helps. -Matt
Nov 16, 2014 | Dishwashers
Why does display flashes "cl"?
Good Afternoon Friend,
I understand the display is flashing "cl" on your Frigidaire dishwasher, model# GLD2450RD. The "cl" code you are seeing is stating to close your dishwasher door. The status indicator lights will also flash to indicate current cycle status. If the door is closed, try pushing it in just to make sure. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 30, 2014 | Frigidaire GLD2450RD Built-in Dishwasher
CL trouble light flashing
If you reset the unit from the household circuit breaker and it doesn't change, then contact a professional to have the main control board repaired.
Aug 19, 2012 | Electrolux Frigidaire Professional Series...
Our "Clean" light is flashing green continuous and
Try running a cleaning cycle with no dishes. If you have hard water, try adding a little CLR, or cleaning solution. Check the bottom of the washer for clogged bottom drains. Also check the manual if you have it. Sometimes holding down the button for almost a minute will reset the systems alert for cleaning. Unplug and let it set for a few minutes. Good luck
Feb 21, 2011 | Whirlpool 24 in. DU1055XTP Built-in...
Flashing "Clean" light. Found defective
you need to reset the board..take off kickplate and there is a tech sheet.. this explains , which programs to push within so many seconds to reset board....
Jan 28, 2011 | Dishwashers
On the display is a flashing CL, according to the manual the latch is not closed. Tried several times to close the door and push the normal wash button. Nothing happens, only the CL light is on. Tried...
Hi
Error CL appears when the dishwasher control detects door switch is open or door is open. You'll have to open the door and check the continuity of the door switch. If the door seems to be closed then it is the control has detected an issue with the door latch. Check the door latch & seals to make sure door is closing fine. Unplug the dishwasher from power outlet and wait for 10-15 minutes. Restart the dishwasher and check if the error is still there. If error still appears then you'll need to repalce the door switch/door latch. Hope this helps... Please post back for further assistance.
Daniel
Nov 26, 2010 | Frigidaire PLD2855RFC Dishwasher
I tried both of the "key dances" and still get no
Unplug it for 10 minutes then plug back in give it a chance to reset
Oct 30, 2017 | Kenmore 24 in. 16033 Built-in Dishwasher
Frigidaire pld3460rdc1 the dishwasher flashed CL when the door is closed.
The CL is letting you know that the door was closed. If it continues to show CL it means you need to close and latch before the cycle will run. If it just flashes your okay.
Mar 10, 2009 | Frigidaire 24 in. PLD3465REC Stainless...
Top drawer not working
sometimes if the heater is faulty only one drawer will work and the other drawer will flash f1
Nov 02, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwashers Logo
140 people viewed this question
Top Dishwashers Experts
