Question about Saniflo & Saniplus& Macerator Pump
Bath takes about hour to empty toilet works ok flushes ok
    Problem Solver:
  • 11 Answers
Go to lowes, walmart and get some drain-o prolly clogged by hair.
Posted on May 23, 2011
What is causing air in my cold water line and how do I fix it?
try running all the water in the whole house at once. all toilets. outside faucets, washing machine, ect...
assuming you have no leaks.
Aug 25, 2014 | Home
Wont stop filling and emptying
The flush valve assembly is lose, You need to take of the tank and tighten the nut it about 3 inches or so. then replace the tank. Good luck
Mar 07, 2014 | Home
After flushing the tiolet the water level in the bowl returns but then starts to empty out through the trap again until it starts gluggin for about 10/15 seconds and then re-fills and is ok untill the next...
It sounds like your toilet is not vented properly. Either there is no vent pipe (which is not likely since it has worked properly for a while), or the vent is plugged. Possibly an animal or bird has gotten into the vent stack going out the roof of your house and plugged it. When the vent is plugged, the water in a trap or toilet bowl will get sucked out as the water from the flush goes down the drain. I would say to have someone check your venting.
Good luck.
Dec 04, 2009 | Home
I have a 3 bath rental. The last tenants were
With the toilet clean, try a large shop vac and see if that will unplug it , I had to do that when my son had flushed a toy and it was stuck. If that wont work you will have to pull the toilet.
Oct 24, 2009 | American Standard 2860.334 Enfield Two...
Downstairs toilet won't stop filling, upstairs toilet won't fill
for the upstairs if the valve is fully on there is not much you can do other than replace water service to the house or heaven forbid repipe.Valves usually don't restrict fill volume.But you can take the supply loose from the tank and stick it in a bucket turn the valve on and check the flow.this should narrow it down.Down stairs repair or replace flush valve
Aug 04, 2009 | Home
My new EZ-33 cloggs easily with small amount of waste to flush.
you have to take the whole toilet out. you need to check the opening of the down pipe. most likely the wax ring is blocking the soilds. shunt off the water drain out the toilet, unbolt the floor bolts and left it up. clean out the down pipe and replace a new wax ring.
Jun 04, 2009 | Jacuzzi Bath Perfecta EZ33 959 White round...
Standard toilet will not flush
If this is a new development, then you have a partially clogged drain or maybe a crack in the bowl assembly. If the toilet always did this, then perhaps the drain pipe was not installed correctly.
I would remove the toilet and run a snake through to the main stack. If you find that is clear, check the bowl for cracks and check the tank water level to be sure that the tank is filling to the water line on the tank
May 09, 2009 | American Standard Colony 2388.012.222...
Master bath toilet replaced with a Cimmeron class 6 confort height toilet. The master bath toilet backs up to the hall bath toilet - same wall. The hall toilet is very old. When the old toilet is flushed,...
Kohler is correct. The most likely cause of this problem is an obstruction in the common vent stack that both toilets share. When you flush the old toilet it need more air to flush and will get it from the easiest source (your new water saver toilet). First adjust the float level in the old toilet so it won't use as much water or just stick a brick in the tank to take up space.Second, run a snake down the vent stack from the roof to check for obstructions. Birds will sometimes nest in there.
Mar 16, 2009 | Kohler K-3489 Cimarron Comfort Height...
Our Saniflo - Saniplus works fine and efficiently when we flush the toilet, if we use the shower or bath,when emptying the water the flow is not as strong/as much pressure like a toilet flush & the...
Sounds like a restriction in the outlet pipe, the 2 galls from a flush are OK but the bath or shower is more, especiallly if you have flushed before you shower, try drain unblocking chemicals or flushing the outlet pipe with mains water from a hose
Mar 09, 2009 | Saniflo & Saniplus& Macerator Pump
Saniflo & Saniplus& Macerator Pump  Logo
57 people viewed this question
Top Saniflo Home Experts
paulcarew
Donni Steen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
