Question about Western Digital WDME5000TN 500 GB USB 20 Hard Drive
WDME5000tn In my computer this HD (500GB) will not be assigned a disk letter. It shows up in "disk manager" without any problems but no disk letter. I tried to assign a letter without avail. During boot up I put my ear on the drive and the disk sounds normal and running. Computer says new hardware installed without problems. Tried another WD (250GB) drive in the same computer and it worked ok with a drive letter. Tried the problem HD in another computer same problem. Could the hard disk have corrupt firmware and needs to be replaced? What should I do the information on this drive is very important to me. Thanks David (david.ostrowski@snet.net)
  • Western Digital Master
  • 27,725 Answers
How did you try to assign a drive letter right click start right click on this drive select (RENAME) in xp
hope this helps
Posted on May 23, 2011
HP simplesave sd500a (Portable) become unallocated and "Not Initialized"
You must be logged on as an administrator to perform these steps.
Windows typically assigns a letter of the alphabet to most drives.
If you want to organize your drives in a certain way, you can change the drive letter.
You can assign any letter to a drive as long as long as the letter isn't already in use by a different drive.
To see which drive letters are in use
Open Computer by clicking the Start button, and then clicking Computer.
Open Computer Management by clicking the Start button clicking Control Panel, clicking System and Security, clicking Administrative Tools, and then double-clicking Computer Management.
If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
In the left pane, click Disk Management.
Right-click the drive that you want to change, and then click Change Drive Letter and Paths.
Do one of the following:
To assign a drive letter if one has not already been assigned, click Add, click the letter that you want to use, and then click OK.
To change a drive letter, click Change, click Assign the following drive letter, click the letter that you want to use, and then click OK.
To remove a drive letter, click Remove, and then click Yes to confirm that you want to remove it.
Initialize New Disks
http://technet.microsoft.com/en-us/library/cc771486.aspx
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
hope this helps
Jul 26, 2012 | HP Electronics - Others
I have a Maxtor OneTouch 4 Plus 500GB external harddrive...I originally used it on a really old dell desktop computer but since then recieved an HP pavilion laptop...the laptop has windows vista. At one...
1.) Right click My Computer
2.) Click on Manage
3.) Click on Disk Management at the left side panel of Computer Management
4.) Right Click on the USB device in the Disk Management panel
5.) Click on Change Drive Letter
6.) Assign an Alphabet from E-Z to the USB device
7.) Click Ok
Go to My Computer and find the drive letter that you have assigned.
Hope it helps.
Jun 02, 2017 | Maxtor OneTouch 4 Plus 500GB External USB...
Drive not working/ not showing on desktop/ green light showing on powerpack but light blinking amber / yellow on the hard drive
Do you hear a clicking sound while the HD (hard drive) is ON? If not, here's what you need to do:
1. Try to connect the HD into different USB ports of your computer. Or might as well, try different computer.
2. If you're using USB cable to connect the HD to the computer, try different cable. If it has a FireWire connection, then try FireWire.
3. If same problem occur, check the Disk Management of your computer while the HD is connected. To check the Disk Management, here's how:
- Right click "My Computer" (for XP) or right-click the "Computer" icon (for Vista or Win 7).
- Go to"Manage", then select "Disk Management".
- List down all the drive letters that you will see. Include the "Unallocated" disk space on the list(if there is), then unplug the HD from the computer.
* If there's a drive letter that disappears, then it's your HD. You may reconnect the HD to the computer > right-click on the HD's drive letter > change drive letter. Try to set the drive letter of the HD in drive X: or V:.
* If the drive letters remained the same, though you disconnect your HD, then, it means that the HD is no longer detected by the computer.
* If the HD appears to be "unallocated", then you need to reformat it.
*** However, if you're hearing a clicking sound, I'm sorry to inform you that the HD is no longer working. That clicking sound is also called the "click of death".
Thank you and good luck!
Jul 04, 2010 | LaCie 500GB FireWire-400 Porsche - 7.2K...
I have a WD 500GB External Hard Drive. It has
That could even be a USB problem, I have the same one, my issue turn out to be just power. You are not the first one to have that problem. Replace the USB cord and see if that affects anything.
Mar 25, 2010 | Western Digital My Book Essential 500GB...
Hi, i have a old st344310a seagate hd i want to install. it plugs into the mother board and power supply, but won't show up on "my computer"
Right-click My Computer, choose Manage, or otherwise go to Management Tools.
In the left window drill down to Disk Management and select it.
On the right pane find your 4GB disk.
Right-click it, choose Assign drive letter, and choose an unused drive letter from list.
Confirm, and your drive should appear in My Computer under the newly assigned letter.
Dec 04, 2009 | Seagate Medalist 4310 (ST34310A) 4.3 GB...
Mylacie drive is no longer connected to my computer. When it is turned on, there is a clicking noise and the LED light is alternating between red and yellow. What do you think the problem is?
when a disk makes a clicking noise, in most cases (99%) that means that the disk has crashed. i'm sorry to inform you that the data you had on the disk is lost, unless you are prepared to pay lots of money to a company that takes the disk apart to retrieve data manually.
Jun 24, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Vista is not picking up my maxtor harddriver but wheni had xp was .
Check the disk management MMC - it's likely that you have another drive letter that is conflicting with the Maxtor.
1. Right Click on the Computer Icon (or in the menu),
2. click on Managment,
3. look for Disk Management(on the left side) and click on that.
4. This will show you all the installed HD's that you have.
Your main HD is probably called Disk 0. IF there are any other HD's listed they will probably be labled "removeable", if it doesn't have a drive letter assigned to it do the following:
1. Right click on the Disk (X) that does not have a drive letter. (it should be a "Removable Drive")
2. Select Change drive letter and Paths.
3. Choose a drive letter from the list that is not used, I suggest W or Z just to be sure.
4. After you do that it should come up in My Computer as an available drive.
IF the External Drive is not listed then you need to change the USB port or try it on another PC to see if it works there.
May 30, 2009 | Maxtor OneTouch 4 Plus 500GB External USB...
Drive No Longer Appears as an Available/Accessible Drive
goto disk management - right click and choose assign/change drive letter
Mar 18, 2009 | Electronics - Others
I want to use my seagate freeagent with our server windows 2003. how can i do it. if i plug it, windows says usb device not recognized.
As administrator:
Click Start->Right click My Computer and choose 'Manage'
The Computer Management window will open.
Click on Disk Management and you should see the rive listed in the right-hand pane, without a drive letter assigned.
Right click on this drive and assign it a letter, like Q.
You'll now see drive Q (or whatever letter you picked) in the regular drive list.
Feb 28, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Western Digital WDME5000TN 500 GB USB 20 Hard Drive Logo
56 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
