Question about Kodak EASYSHARE 5100 All-In-One Printer
Color on print
My color won't print anything . I put new jets in and it still would not print and I thought those were just dried up so I bought some more new jets.
Still the same thing so now I have 2 open sers of ink jets and neither color will work. I can't find my Book as I am doing geneology and thinks sure can get piled up .
Really hope I can get this fixed or I will have to buy a new one and it won't be a kodak. I just got a new Kodak digital camera for Christmas---gift from
my Daughters.
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Hmmm...can you provide a little more information on how long that printer's been working?
http://tinyurl.com/6qcpgy
Posted on Aug 18, 2008
SOURCE:
RX700 not printing anything
After two years of no use the ink is most likely dried up and plugging the print head, try this first before you replace the cartridges, soak the print head of all cart's. in hot water for 10 minutes and wipe dry, then try again, if that doesn't work you will need to try need cart's, buy reman ones they are cheap and if the printer is defective you won't be out so much money. I advise you based on my experiences that buying a used printer is risky, a new one is so cheap it is just not worth the risk of getting a DOA used printer. The last printer I bought came with a rebate for the entire price of the printer, and it is a Canon not a no name.
Jan 20, 2012 | Epson Stylus Photo RX700 All-In-One InkJet...
My office jet G85 won't print. No error messages appear,it has a new color cartridge,it copies, but won't print from my computer.
If it copies ok, then the issue is either the way it is cabled to computer or the print driver software settings on pc.... How is it connected via USB? Check port and correct driver is in windows/control panel/printers. Reinstall.
Nov 30, 2011 | HP OfficeJet G85 All-In-One InkJet Printer
Ayaw mag print out
cant quite understand the type of english used but if the cartridges have been refilled .. the mashine goes through a process of cleaning and realianing the cartridges.if one isnt working then jets have dried out and blocked,in the refil kit is a bottle of solvent,put a bit in saucer,put cartridge in so jets are covered and it will disolve the dry ink
Jul 05, 2010 | HP DeskJet F380 All-In-One Printer
It won't print anything in color
this is an old days printer. The print head is almost reach to the end of life. Most probably is the print head faulty.
May 26, 2010 | Canon i450 - Printer - color - ink-jet -...
Changed ink and now the printer wont print
The old ink has probably dried, plugging the jets. Try going through the cleaning cycle (several times if necessary). If it begins to print at all then let the printer set overnight and try cleaning again.
Fred
May 09, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Cannot print black on epson cx7400, I bought new cartridges for all four color, but still it doesn't print black, but it is printing all other colors. can some one can help me out?
I've had nothing but problems with Epson cartridges and drying up of ink. If the cartridge is a little old, say a few months, then don't be surprised if its dried up. especialy if its in warmer weather near a window.
If its new, then make sure that the tape is remved from the cartridge [obvious but I thought I'd mention it].
Also, its expensive, but you shodu lonly use genuine Epson ink cartirdiges adn not genreic brands or refills.. having spent coutless hours reparing ruined printers because someone thought they could save a few bucks.. it ain't worth it in the long run.. buy the genuine ink adn use good quality paper..
Jun 06, 2009 | Epson Office Equipment & Supplies
HP Printer Deskjet 697C won't print color
Unfortunately when a inkjet printer is not used in a while the ink dries up... If I was you I would try a new color cartridge and see if that helps out. It is a fine balance with ink jet printers... you don't want to print so much because ink is expensive but you want to print enough to keep the heads and ink from drying out. Good Luck!!!
cdixon18
The Man Inside the Machine
May 11, 2009 | Office Equipment & Supplies
Can print in color but not black changed cartridge still no black.
I've had this problem. Once it was because the ink I purchased at the local office supply was out of date. Check the side of the box. I bought a new cartridge and it worked just fine.
The other problem could be bad heads or dried up jets.
Apr 23, 2009 | HP DeskJet F380 All-In-One Printer
Lexmark X5150 printer (serial #10450991811): Error message reads "color cartridge missing." It is not. With the last cartridge, printing was light and scattered; could not print anything...
Went to online chat with Lexmark. FREE.
They offered to replace cartridges as they felt the ink was dried out in one, and the ink jets in the other were damaged.
Apr 18, 2008 | Lexmark Office Equipment & Supplies
Epson Stylus Printer CX4600
I don't know if this will work on an Epson, but it does on Cannon. The pads on the cartridges or the ink jets in the printer head may be cloged with dry ink. Get some Q-tips and rubbing alcohol (water is a poor substitute). Take out the ink cartridges and touch the pad on the bottom with a Q-tip (one for each color). If there is color the cartridge pad is OK. Take a fresh Q-tip dip it in rubbing alcohol and GENTLY rub the little holes on the bottom of the plastic box the cartridges go in. Thse are the print head jets. You should see color. You may need to clean it a couple of times if the ink has dried down into the jets. It is OK to have the Q-tip pretty wet, but not dripping.
Hope this helps
Dec 03, 2007 | Epson Stylus CX4600 All-In-One InkJet...
Kodak EASYSHARE 5100 All-In-One Printer Logo
35 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Clive
Clive
Ekse
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
