Question about Tomtom GO 910 GPS Receiver
My TomTom 910 still won't charge properly! I have just replaced the battery considering that that was the most likely solution but there is one other problem that seems to be associated with the power input connector. Without knowing the pin configuration it would appear that the connection can be made by pushing hard down on the RHS of the unit, (same with the car charger) therefore dodgy connection must be on the TomTom. I notice that there's a separate connector at this side which looks like a small BNC type connector but not sure if this is where the problem lies? Your forums recognise this problem but I haven't seen a solution, I am a reasonably competent electronics engr. but my skills do not stretch to micro electronics, can you help?
  • 2 more comments
  • Tom Bedford May 23, 2011
    I think your comment about the TomTom internal connection is valid, but impossible to diagnose. The unit syncs ok to my pc and has been updated recently via the Tom Tom website
    The TOMTOM seems to charge OK from the PC, does that mean that there is a separate power connection route via USB?
  • Tom Bedford May 24, 2011
    Thanks for your great suggestions but I can update now as follows: I had the unit "charging" via usb to my pc but eventually it switched itself off. (I had been monitoring the battery which is shown in the top right corner following a new route planned). This monitor is obviously fictitious otherwise I would still have plenty battery power. I can switch the unit on while connected to the pc but it goes off after about 10 secs confirming the lack off battery power, I can keep it on a little longer by pushing down on the RHS which makes the connection but this is intermittent. Clearly the power connection within the unit is what is causing the problem but can anyone identify which pin connection(s) are deployed and how is this remedied?
  • Tom Bedford May 28, 2011
    I spoke to TomTom technical support, they sent me a prepaid pack in which I returned my faulty unit.
    Within 3 days they'd sent me a replacement unit with full warranty re-instated.
    These guys are amazing or was I just lucky? The guy I spoke to was so helpful, explained all the options.... I honestly thought I was heading for the £50 off trade in shelf or a bill of £100 for repair.
    I am astonished and delighted, what a result!
    Thanks to all the guys on the forum for your assistance, the Fixya experience was certainly enlightening but unfortuately did not provide the solution this time!
    Kind regards
    Tom
  • 3,018 Answers
  • To replace this battery is a tedious task in itself. It is one of the first things that goes into the GPS upon assembling. When you replaced the battery did you look at the charging unit inside the GPS unit. I will post some pictures for you that will show you the piece you need to look at and possibly replace. If you replaced the batty you should be able to get to the battery charger in the GPS because the battery replacement is far more in depth. Also there is no BNC connector, it's a just and RCA audio wire. So reassemble like you would have had to to change the battery and see if the charging unit on your TomTom is loose or see if it responds when moved a bit.
  • You will need a Torx bit number 6 for this job, start by removing the case, the four screws are located under the rubber pads on the devices base
  • The case "pod" simply removes leaving the device sat on the table
  • I remove the GPS Patch aerial for this as it makes the later stages a little easier, two torx number 6 screws and the daughter board will lift away from its multipole connector. The red line indicates the TomTom charging unit.
  • Four Torx number 6 screws secure the main board into position, remove these to release the PCB, disconnect the two plugs as shown in the picture bMy TomTom 910 still won't - ironfist109_107.jpgbr /> ironfist109_107.jpg
    Regards, Tony
Posted on May 24, 2011
  • Iron
    Iron May 24, 2011
    • I see now also that you say it charges well from the PC. That means that the fault is going to be the AC/DC charging unit on the GPS as it does not respond but the GPS does charge from the PC using a USB port which is a different port than the AC/DC port. Further reason to believe it is the charging plug on the TomTom it'self. Do you get the same lack of response from a DC charging attempt as an AC charging attempt? If neither charge it is going to for sure be that AC/DC charging port on the GPS or perhaps a cracked circuit board in the area if enough stress was put on it.
    Regards,
    Tony
  • Iron
    Iron May 28, 2011
    • I don't tell people to send things in unless the customer indicates it's still under warranty. In most instances people check that out first. I'm here to show people how to Fix things. That's what I did. I answered your question with photos. And it was proper. You just were able to get an exchange and now don't feel like paying for the solution you received.
    Tony
  • 343 Answers
I am not sure if this will help but the link below shows the taking apart the unit.
http://www.unc.edu/~bmoc/tomtom/Tomtom%20Go%20910%20Dismantling%20Manual.pdf
thanks for using FixYa
Posted on May 23, 2011
  • Carl W May 23, 2011
    And yes the unit can be charged via usb,so if you like you can buy a usb car charger for your car cigarette lighter/aux power. They look like this and are available at electronics stores,see link below. Again thanks for using FixYa
    http://www.radioshack.com/product/index....
  • Carl W May 24, 2011
    There are no schematics available to me.They probably don't want anyone to know and they want you to sent it back to them or buy a new one. You could call them and see what they could do. Here is a link to contact Tom Tom. Thanks again for using FixYa and if you could,please accept the solution.
    http://uk.support.tomtom.com/app/home/?L...
  • 823 Answers
I sometimes have that problem with mine when using the car charger. But it does not happen when connecting it to my pc with the usb cord. As long as you have 2.0 usb ports on your pc, it should charge the unti correctly. If I were you, I would try charing using that method and see if that solves your problem. Purchasing another cord to charge will not really help if the problem lies with the connection on the Tom Tom itself. If the charger works when you press down hard, maybe the connection on the tom tom has slipped back further into the unit itself and its not reaching it properly? You can check to see if this is the problem by using the cord to connect to the computer. Log into your account on Tom tom live on the internet and try updating your maps. If your cord can connect to the pc correctly and update your maps then you know it lies in the charging cords that you are using. Maybe someone was too forceful when using them?
You can send the unit in for repairs direct to the manufacturer and have the connection on the base replaced for about $ 45 (American Dollars). The address for repair is located in the manual. It can also be found on their website on the internet.
When removing the 910 from power lead it dies, which leads me to think batteries are dead, can the be pelaced by owner or be returned to TomTom?
well the battery is intended to be replaced by TomTom professionals, but you can change it yourself if you have the proper expertise, You can buy the spare battery from Ebay etc.
Jul 16, 2010 | Tomtom GO 910 GPS Receiver
My tomtom 910 does not charge but the charging light comes on so what can i do
Hello there:
What i suggest is removing the battery and check the connections where the battery sits and see if there is any loose connections or is dirty and needs cleaning , and if the battery itself has a bad cell in it it wont charge properly you can take it to your nearest tomtom dealer and have them bench test it too to help find out what is going on with this unit ok>
I hope that this is very helpfull for you.
best regards michael
Oct 23, 2009 | Tomtom GO 910 GPS Receiver
Battery won't hold charge on tomtom 910 - the green light comes on when i plug it in but as soon as i unplug it the warning battery light comes on
Your battery has finally died and needs to be replaced. To replace the battery in your 910 you must completly disassemble the 910. While battery replacement is fairly straight forward, it is not a job for the average user.
Oct 20, 2009 | Tomtom XL 330 Car GPS Receiver
Tomtom910 not holding charge or charge properly
Looks like the battery needs replaced. Go to: http://www.unc.edu/~bmoc/tomtom/Tomtom%20Go%20910%20Dismantling%20Manual.pdf
This site will give yo step by step how to change the battery. Good luck!!!
Oct 03, 2009 | Tomtom GO 910 GPS Receiver
My tomtom 910
Have same thing. I did call Tomtom and they are guessing ,just like me ,that battery is dead and offered me US$ 75 off brand new go 730 and old one u can keep. Was told ,they dont sell battery replacement .
Sounds like someone will sue their **** soon as class action .
Sep 05, 2009 | Tomtom GO 910 GPS Receiver
TomTom Go 910 comes on, then goes off
Sounds like a dying battery. There is not enough charge being maintained in the battery to complete the loading of the data. ChaNGE THE BATTERY
Jul 20, 2009 | Tomtom GO 910 GPS Receiver
Faulty tomtom go 910
have to send it in to get battery replaced.
Jan 20, 2008 | Tomtom GO 910 GPS Receiver
TomTom 910 charger question
Yes, you can.
I presume the charger has an USB connector.
5v and 2A are the correct figures for a Go910.
Aug 24, 2007 | Tomtom GO 910 GPS Receiver
TomTom 910 system
The unit has a lithium-ion battery and can be subject to being "overcharged". Try COMPLETELY discharging the battery and then recharging for 4 hours.
Jun 29, 2007 | Tomtom GO 910 GPS Receiver
Tomtom GO 910 GPS Receiver Logo
174 people viewed this question
Top Tomtom GPS Experts
k24674
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
