Zenith PVY5263RK projection TV... want a factory reset for the service menu settings
Found this PVY5263RK on the curb, cleaned the screen/mirror/CRTs and got a decent picture out of it... the convergence is different on each CRT, the red is the furthest out, it looks like it is rotated a few degrees CCW around screen center. Tried to find a setting for rotation or pincushion in the service menu and accidentaly blacked out the 'RGB Contrast' or 'RGB Brightness' and now I can't see the menu alphnumerics to fix the setting. Catch-22, need to see the text to adjust the text brightness...
I thought a factory reset might get me out of this issue, I'll probably get a kit for the convergence problem.
Is there a jumper setting or key combo to force a factory reset?
Thanks!
    Top Expert:
  • Televison & ... Master
  • 30,506 Answers
The only was to perform a 'factory reset' is to reload the firmware from the manufacturer.
Posted on Mar 23, 2017
SOURCE:
  • 119 Answers
SOURCE: Blue convergence
if the problem as atated only needs rotation, then your need to turn the yolk on the blue tube. you will have to slightly loosen the screw that hold the yolk. rutate it the proper way to get it aligned with the other colors. retighten the screw, but do not over tighten, you do not want to break the tube. ALSO make sure that you do not move the yolk UP or DOWN. if so the blue picture will be resized. down the picture goes smaller, up the picture gets bigger. good luck.
Posted on Dec 24, 2006
  • 80 Answers
SOURCE: Poor color issues.
If the set is 10 years old, one or more of the CRT's (picture tubes) may need to be rebalanced in a process called white balancing. If the tubes are in good shape this can be accomplished with great ease. A good tech will then reset the focus and screen adjustments to obtain an optimal picture. I personally own a 16 year old Sony KP61 series big screen and it looks great with the original tubes, hope yours goes just as long. Joe Weibel Custom Electronics (customelectronics.org)
Posted on Feb 14, 2007
  • 3 Answers
SOURCE: 50" rear projection zenith television
It sounds to me like one of your color tubes went. If I had to guess I would say the red tube is shot. Its cheaper to buy a new tv almost. You can get a quote over the phone and compare the cost of repair to the cost of the tv.
Posted on Dec 16, 2007
doin12volt
  • 233 Answers
SOURCE: Convergence Problem and Contrast Adjustment
Have you checked all of the resistors inthe convergence circuit as well? If not, check them for the correct impedance.. Remember, you have to pull one side of the resistor out of circuit to measure it correctly.
If all of the resistors are good, then you have to do a coarse convergence adjustment on the set through the service menu.. if you need the service manual for the convergence directions, I have one uploaded in the technicians corner of techlore.com
Posted on Dec 25, 2008
ladywinn
  • 5138 Answers
SOURCE: Center Target Blue Convergence and Contrast Adjustment
Yes there is a Service Code you have to have to get into Alinement menu and its a Dog following step by step to get in! (1) Turn set on cable (2) Turn sleep timer on 30 min (3) Press Action Twice exit menu 4) now tune to ch 124 (5) adjust vol half way down (6) Now Press vol- on front of TV ,now you should see a RED chk appear in upper corner (7) Now Power on remote hand unit and you shiuld be in menu Press cursor to move Mute locks where you want to aline ADJUST with vol-,Vol+ ch- ch+ for up&down back and forth.If you need anymore help let me know .
Press R-tune to change R-G-B
We have a Phillips rear projection tv, about 9 years old. The color has been getting progressively worse over time. Dark scenes are almost impossible to see. It almost seems that only blue and red are...
Tv have halo pictures and dulls colors?Yes,the tv have bad Coolant chemicals on those colors guns R,G,B CRTS tv Tubes.Must replaced those CRTS Coolant chemicals on those CRTS tv tubes.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a Coolant kit to replaced those CRTS tv Tubes coolant chemicals.
Nov 13, 2010 | Philips 55PW9363 55" Rear Projection...
Blurry tv
there is a focus control in the front of the set behind the front grill there is a door in the middle attached by screws take this off and it should be right behind it. There are six controls on a little box one row says focus and the other says screen don't adjust the screen controls. In some cases these are in the back of the set.
Aug 07, 2009 | Sony KP-65WS500 65" Rear Projection...
Ripped screen on Zenith 52"Tv
email me at [email protected]
we have one that dosnt work maybe we can part it out
Apr 29, 2009 | Zenith R57W46 57" Rear Projection...
REAR PROJECTION TV SCREEN GETTING HARD TO SEE
Your TV requires service and cleaning of screen, mirror and 3 lenses (of CRTs) as looks dusty.
Below is an exploded view how to take off front beznet assembly of this TV to clean inside with moist cotton cloth.
Unplug TV before taking off front of TV.
Jan 26, 2009 | Sony KP-43HT20 43" Rear Projection...
Colors have a blue-green tint
Try this first:
Press: MENU, 2, 4, 7, 0, ENTER
This will factory reset your tv. Be aware, this will erase any NetCommand or user-created features you have set up on the tv.
Check your results.
If you don't see a change, begin to suspect either the lamp, color wheel or light engine.
Nov 03, 2008 | Mitsubishi WD-62525 62" Rear Projection...
How to clean CRTs and mirrors
I have the same problem, spiders actually are showing ip on the screen, did you get a solution on how to open the front panel? please help if you can.
Oct 22, 2008 | Toshiba TN50X81 50" Rear Projection...
ZENITH D52WLCD
I just found the solution on another model of Zenith TV. Hold the enter button down on the TV and the MUTE button on the remote. In approx. 5-7 seconds a screen will pop up asking if you want to reset the lamp timer. Hit the bullseye button in the middle of the arrows and it will reset. Worked perfectly.
Apr 15, 2008 | Zenith D52WLCD 52" Rear Projection...
Phillips
Hi. I had the same problem with my Philips RPTV and the fix is extremelly ease. You just need to open the back cover (mine uses torx screws). Inside the tv is very mechanic. You will find the three CRTs and most likely the lenses are dirty. You just need to wipe them off with a soft cloth. Also the CRTs project the image not directly to the screen, but to a big mirror and that mirror will be most likely dirty (like when you open the hot water in front of a mirror). Once you clean the mirror and the crts, your tv will like as the they you got it.
Jan 24, 2008 | Philips 55PP9502 55" Rear Projection...
Lg television du-27fb32c reset to factory settings
mute on the remote and menu on tv
service mode and go to factory reset
Dec 09, 2007 | LG DU-27FB32C TV
R57w46 zenith
Hello Was wondering if you ever found anything out how to reset the IC Screen Numbers or what the factory numbers all are on the Zenith Rear Projection TV Model # R57W46? I have the same problem ! My 2 year old son, not knowing how he did it cuze only a technecian is suppose to get into this screen, but he did change numbers in the too. I called zenith themselves and no luck ! My screen is bowed , etc.. Any Help ?
Jan 16, 2007 | Zenith R57W46 57" Rear Projection...
Televison & Video Logo
212 people viewed this question
Top Televison & Video Experts
Ekse
