Question about Mercury Boating
Engine runs for about 10 minutes then cuts out and will only restart with choke applied then runs for another 10 minutes and cuts out again
  • 696 Answers
Hi!
It sounds to me as if the motor is attempting to eat its own exhaust.
An easy way to check is to remove the motor cover and start it. USE CAUTION HERE! If the motor runs normally with the cover removed, you can be sure there's an exhaust leak. Our motor had the smallest bit of corrosion where the exhaust coupling bolted to the block and was leaking. It was fairly difficult to spot, but we finally found the problem.
Hope this helps.
Posted on May 23, 2011
My mtd mower with 15.5 hp engine starts and runs for 5 to 10 minutes and quits. It will usually restart with the choke on and run for a few minutes more and quit again. It will finally not restart.
More than likely a carb problem. What kind of fuel you use makes a difference. If ethanol, causes corrosion inside carb. Or maybe something easy as air filter.
Jun 03, 2016 | Mtd Garden
2007 Yamaha 115 Hp 2 stroke idle problem
Check the idle mixture. Sounds to me like it is too lean.
Mar 20, 2017 | Clymer EvinrudeJohnson Outboard Shop...
Toro Proline 52" stalls out after warming up
Do you know if that unit has a fuel pump or not? If not, then engine vacuum is what draws the fuel in ... but only IF the hoses involved DON'T have any cracks or splits, and they fit TIGHT on the ports to which they connect! Try using an eye dropper and squirt a little gas in the air intake under the air cleaner. Does it fire then?
Apr 19, 2017 | Garden
Engine cuts out
take off the gas cap and try it the vent could be plugged in the cap
May 22, 2012 | Garden
Engine quit when stopped at stop light. Acted as if it was choking then died. Tried restarting. Turns over strong, no start. Thought maybe no gas. Added gas after about 30 minutes. Started first try....
Sounds like the fuel pump is going out. Replace the filter first, as it's only $10. If that doesn't fix it, then it's probably the pump, which is $250.
Jun 10, 2011 | 1993 Jeep Grand Cherokee
Spark plug gap mitsubishi delica van 1990
If the engine runs OK when cold and starts to miss when warm usually spark is the problem. Make sure the choke is open all the way. How does the plug look? When the engine quits then restarts and runs then quits again but at a shorter interval the ignition coil is the culprit. Good luck
Apr 10, 2010 | Spark Plugs BR4HS Plug 10/BX #3322
Runs about 10 minutes 7 cuts off. can't restart
Plan your beer breaks every 10 minutes and enjoy the time off. Also check your fuel mix, the engine is running hot, replace fuel mixture with proper oil mix.
Jul 15, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I have a union power pressure washer it runs for 10 minutes and then cuts off and wont work again, it still needs the choke on when the engine is warm and only runs for a few seconds
"it still needs the choke on when the engine is warm and only runs for a few seconds"
This sounds like a fuel problem such as the carb needs cleaning
Jun 16, 2009 | Garden
Engine coughs and stops after about 15 min. of cutting
check the vacuum line from pump to crank case fo leaks
Apr 25, 2009 | Garden
Boating Logo
109 people viewed this question
Top Mercury Boating Experts
Colin Stickland
Colin Stickland
Mike
Steve
Steve
Are you a Mercury Boating Expert? Answer questions, earn points and help others
