Question about Miele 24 in. G638 Plus Free-standing Dishwasher
Inlet/drain light flashes on miele dishwasher and water will not completely drain away. Model G638l plus help please
    Novelist:
  • 251 Answers
The pump is blocked, need to remove the trays, drain plg, the gauze, scoop the water out as much as possible, thge thers a plastic hosing with a spring clip on top, remove this to unblock the pump. assemble & should be good to go.
Posted on Jun 14, 2011
Miele G641 SC Plus Drain /inlet light 4 short 1 long flash. How do I find a fault code chart?
Inlet / Drain is a general fault meaning there was no water movement when it was necessary to start the pump. Either it didn\'t drain out or it didn\'t fill the last time.
Call 800-999-1360 for free Miele tech support. They will advise you free of charge. You will perform step by step control board operations over the phone to clear the fault code as well as advise you how to cleanout the drain pump.
Dec 27, 2014 | Miele Dishwashers
Inlet/drain light flashes on miele dishwasher and it wont start - I can hear the pump but no water - I have checked and cleaned all pipes etc
The outlet pump is triggered by the anti flood micro switch via the polystyreene float on the base of the washer. If any water for whatever reason (leaky pipe)is on the floor the machiene automatically switches to pump out mode and only works once the water and the cause is rectified
Jan 16, 2010 | Miele 24 in. G638 Plus Free-standing...
Outlet/inlet light flashing on miele dishwasher G674SC
Usually indicates a intake or drain fault - could be a plugged drain line at the garbage disposal or insufficient water coming into the unit
Sep 22, 2009 | Miele Dishwashers
MIELE INTEGRATED DISHWASHER WONT TAKE IN WATER
Contact Miele at (800) 843-7231
They will walk you through entering service mode on the machine to diagnose the fault code by pressing a series of buttons. At that point they can let you know what exactly is wrong with you machine
Sep 12, 2009 | Miele Premier-Plus Built-in Dishwasher
The G638 finished its cycle but didn't completely
pump maybe on it's way out, though i doubt it, is the washing machine on the same drain out? if so you may have back wash, another could be lengh of drain hose, i had the same problem with my miele dishwasher because of the position in the kitchen i doubled up the drain hose and though it pumped out fine, with the volume of water left in the hose it came back in untill i repositioned the drain hose so it could't run back, hope this helps.
Aug 03, 2009 | Miele 24 in. G638 Plus Free-standing...
Intake/drain light is flashing
When this happens with my dishwasher it usually means that the drain is clogged with food/debris.  To fix 1) remove bottom dish rack from machine 2) using a small cup, scoop out as much water as possible 3) remove inlet drain cover and unsnap the plastic insert and remove 4) rinse the plastic part and reinstall 5) start machine 6) if light still flashes, repeat steps 3 4 and 5 and restart
Jul 18, 2009 | Miele G892SC SS Dishwasher
Half way through a program then stops, leaving water in the bottom of the machine
Check the flood switch first. It will stop the dishwasher but you may hear a moter running.
Jul 21, 2008 | Miele 24 in. G656SCi Plus SS Built-in...
Wash motor does not run: Inlet/Drain error
Wordhog: Does sound like a siezed wash pump to me. Wash motor needs to run to get the correct level of water.
To drain a Miele dishwasher, start the machine on a cycle. All the Miele range of dishwashers drain before filling. Then hold in the start button until the end/finish light is lit. Keep doing this until all the water has gone. You could just get a jug and bail it out. Once the jug does not do the job anymore, switch to a cup, I use a very large syringe for the remaining half a litre.
Oct 28, 2007 | Miele 24 in. G646SC Plus Free-Standing...
Miele G646SC Plus dishwasher Drainage / inlet warning light
I had the same problem a few days ago. I followed the instructions to clean the filter and check to see that the impeller was free to rotate in both directions. The problem persisted. After reading this thread, and a similar one on another site, I tried what mikeboerma suggested in "solution #3", and bingo, problem solved. The magic combination is to push and hold the on/off button and the start/stop button.
Sep 15, 2007 | Miele 24 in. G646SC Plus Free-Standing...
Miele 24 in. G638 Plus Free-standing Dishwasher Logo
603 people viewed this question
Top Miele Dishwashers Experts
Mike
shaun taylor
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
