Repairing broken cables - Audio Players & Recorders
  • 58 Answers
Depends on how the cable is broken. you can always cut and splice if there is enough cable, otherwise replacement may be your best bet.
Posted on Aug 15, 2008
Hood release with broken cable 2002 odyssey
look under the dash see if cable is broken close to that end
grip inner cable with pliers and pull hard
if broken at the engine bay
work from under the car with a long tool to release the bonnet catch
if not sure how its done drive to a panel repair shop for a solution
Jul 14, 2016 | Cars & Trucks
How too release the emergency brake foot pedal when the cable is broken?
About 73,400 results (0.87 seconds) Search Results
    Parking brake release cable snaps - Chevy Avalanche Fan Club of ...
    chevyavalanchefanclub.com > ... > Problems: Brakes
    24 posts - ‎16 authors
    Went to release the parking brake on my 04 and the cable snapped. ... More like the end cap coming of the cable that attaches to the foot pedal. ..... Then I released the parking brake, pulled out the broken release cable/handle assembly, ...
    How To Install Repair Replace Parking Brake Release ...
    ? 5:54
    https://www.youtube.com/watch?v=qx0oGfV62NQ
    Jun 23, 2011 - Uploaded by 1A Auto Parts
    How To Install Repair Replace Parking Brake Release CableHandle ... or replace a broken or worn out parking brake release cable handle.
    Emergency Brake Pedal Assembly & Stuck Brake Cable ...
    ? 10:13
    https://www.youtube.com/watch?v=0jYfvthBzhU
    Apr 17, 2014 - Uploaded by corgLLC
    Emergency (Parking) Brake Pedal Assembly & Stuck Emergency (Parking) Rear Brake Cable The emergency ...
    E-Brake Cable Broken? Stuck Emergency Brake... Help Please ' Chevy ...
    www.tahoeyukonforum.com > ... > Engine & Drivetrain
Jan 25, 2016 | Cars & Trucks
Philips slc4
It can be repaired. Contact any technician.
Apr 28, 2013 | Televison & Video
2004 3rd row rear seat won't fold down using lever
Cable is broken or stretched. pick up the bottom seat and see the cable end if broken or slack from being stretched pull that cable and then the back should fold down. Ibelieve you will need to remove seat to repair the cable. the bottom seat when lifted pulls on a cable that releases the backs lock to fold down
Jun 11, 2011 | 2004 Chevrolet Suburban
My bose headphones have just stopped working, is there a decent chance I can get them repaired fairly cheaply?
You can try taking to a electronic repair shop to check if the cable is broken somewhere, if so, it can be repaired, if thats not the case bad luck. always take care of the headphones cables, never tie them tight always keep them loose.
Apr 07, 2011 | Bose On-Ear Headphones
Broken brake cable.Where do I get a replacement?
Hi. I repair walkers wheelchairs and mobility scooters. I sometimes get asked to repair broken brake cables on walkers and wheelchairs. I get new cables from the local bicycle repair shop. Take in your old cable so they can measure its lenght, and find one the same. They only cost a few dollars.
Good luck. Neil.
Jun 07, 2010 | Medline MDS808210AB ExcelT Deluxe Aluminum...
Clutch peddle not working will it be a broken cable
The clutch cable comes in through the engine compartment and I can assure you - you will need to have this repaired. BUT -- now if you want to repair it - why not go to a junk yard and see what it involves to remove an old one - this will teach you how to replace the new one - good training and a cheap used cable. YOU CAN do it with some patience - still you will have the part so you can save some money that way. c7d36ce.jpg
Apr 17, 2010 | 2000 Hyundai Accent
Broken shimano 105 flight deck shifter
You may have broken your derailleur cable. Your cable securing bolt on your front derailleur might have worked loose just enough for the cable to get some slack in it so that your derailleur isn't moving. Try completely loosening the cable bolt at your front derailleur. Pull on the cable and click the control to downshift to the inside crank gear . That should remove all the slack from the cable. Worse case scenario is when you pull on the cable it will completely pull out and it has broken at the shifter. You will have to replace it with a new one. If it isn't broken and you can still shift with the cable make sure your limit screw is properly adjusted for the inside crank ring and then pull all the slack out of the cable with the shifter shifted to that gear. Tighten the bolt that holds the cable in place and try the shifter again. It should now shift normally. If it doesn't you will have to take the bike in to have the shifter repaired. These shifters are not easy to repair unless you have the tools, parts and experience. Hope this helps.
Jun 04, 2009 | Cycling
Broken handel (Wire snaped)
Cables Broken In your Handle ???? Please visit Repairyabuggy.co.uk as we specialise in the repair of Quinny/Maxicosi Mura/My 3 -4 Handles,Grips-Cables Repaired
Dec 16, 2008 | Quinny Buzz Jogger
24 people viewed this question
 Grubhead
Grubhead
