Question about LRD6100SWS Radar Detector
Tengo un detector de radar uniden model.ird 6100 sws, dejo de funcionar alguien me puede decir que devo hacer con el
ttech
  • 139 Answers
SOURCE: UNIDEN STALKER 6000W
Crakkers,Here is a Link to take you to where you need to Go to Request one Good Luck ttech http://www.mycusthelp.com/uniden/
Posted on Jul 29, 2007
IrishDruid
  • 2712 Answers
SOURCE: Uniden LRD9100SW Radar detector
You can try:
Uniden America Corporation
Parts and Service
4700 Amon Carter Blvd.
Fort Worth, TX 76155
(800) 297-1023, 8:00 a.m. to 5:00 p.m. Central Time, Monday through Friday
Posted on May 25, 2008
SOURCE: uniden wide band stalker radar detector RD 6000W
Uniden's website has it available as a PDF
Posted on Apr 10, 2009
  • 86 Answers
SOURCE: Need new suction cup clip
CALL THEM AND TELL THEM IT BROKE AND 9 TIMES OUT OF 10 THEY WILL SEND YOU A FREE REPLACEMENT...
Posted on Apr 28, 2009
SOURCE: looking for a owners manual for a Uniden laser
http://uniden.com/pdf/LRD6399SWSom.pdf
Posted on May 08, 2009
NECESITO EL CODIGO DE UN TELEVISOR SANYO CON UN CONTROL REMOTO DE JVC
These are the codes for Sanyo TV: 0049 0097 0110 0004 0268 0012 0108 0180
Aug 19, 2012 | RCA Universal Remote Control
Mi MP828-8G DEJO DE FUNCIONAR A UNOS DIAS DE COMPRARLO
YO TAMBIEN TENGO UN PROBLEMA CON EL MISMO REPRODUCTOR NADA MAS QUE ES CON LA REPRODUCCION ALETORIA E IGUAL LO COMPRE EN COOPEL, ME LO CAMBIARON PERO SALIO IGUAL Y NO ME PUEDO COMUNICAR CON EL PROVEDOR, YA LO SOLUSIONASTE TU PROBLEMA?
May 31, 2012 | Coby MP828 MP3 Player
Tengo problemas con un Multifuncional HP Laserjet M1522, por alguna razon empezo marcar ERROR 5 Y NO PUDO INICIALIZARSE el SCANNER , Funciona como impresora pero no como copiadora o Scaner, , parpadea la...
59c05df4-3e41-4402-8674-16fa865682b6.jpg1e27574a-853d-43f0-83e9-639f0eb8015f.jpg6f9cb0d0-efc0-4725-b485-113c15667e78.jpg639e37f6-dbca-4b87-baf4-9919d68a26d4.jpgf319f64c-35bb-4a4d-b11b-3637a94260fd.jpgdf4c7415-80c2-478b-9083-7ef214ae9172.jpg027f0e9b-f662-4bc9-916c-d62c423d9e73.jpga1eea8bc-2311-4ede-b6b1-2b036b38dc64.jpg7ada6481-ced7-4dab-b710-09760d6b9498.jpg04f42b95-4eec-4796-8556-1ef7ab6cddbe.jpgHola amigos, tambien tengo este problema con una impresora, reinstale el firmware y no funciono, lo que note es que el motor estaba quemado, lo desarme y lo rebobine, compre el alambre me parece que fue calibre 33, aprox 25 mts, 260 vueltas con una resistencia de 10ohms por bobina. bueno despues de esto lo monte y funciono un poco mejor. pero al parecer es la tajeta logica pregunte a un proveedor de hp y su valor es de aprox 3000 pesos mx, lo que hice es hacerle un agujero al escaner.
Detalles.
viendo de frente el escaner del lado izquierdo le hice un agujero de 3mm. y le puse un cincho largo(pueden usar algun desarmador, el cincho se lo puse doble para que no se doblara, el cincho debe entrar con facilidad pero no muy olgado para que no se doble, al introducirlo no es necesario sacarlo ya que el carro lo sacar, es por eso que no debe quedar apretado). esto me permite mover el carro del escaner a lo posicion "0". posicion de partida y hubicacion de la banda indicadora(Empujarlo unos 3 cm aprox, despues solo se calibra).
La finalidad de esto es de manera manual regresar el carro, se apaga y se vuelve a encender y listo. funciona nuevamente.
Este error me aparece despues de haber utilizado el ADF, el cual el carro se mueve al lado izquierdo para poder escanear automaticamente los documentos. posteriormente no puede regresar.
Aqui pues es donde le podemos ayudar a regresar a su posicion original.
Espero que les ayude en algo.
Aug 29, 2010 | HP LaserJet M1522nf Multifunction Printer...
Coby mpc7097 el playlist solo llega a 200 temas pero tengo 800 temas en aparato, quisiera aumentar el numero maximo del playlist, gracias por la ayuda que puedan ofrecerme.
lo que puedes hacer es formatearlo desde mi equipo "my computer" encuentra el dispositivo y dale con el botón de la derecha, selcciona en donde dice formatear, selecciona fat (default) y eso te libera el espacio pero cuidado porque te borra la información. despues de que hagas eso puedes meter toda tu música de nuevo lo único es que este dispositivo es de 2GB
17,179,869,184 .......... bits
2,147,483,648 .......... bytes
2,097,152 .......... kilobytes
2,048 .......... megabytes
2 .......... gigabytes
0.001953125 terabytes
0.0000019073 petabytes
0.0000000018 exabytes
una canción=entre 1500 y 6000KB quiere decir que en tu dispositivo caben alrededor de 420 cancionesy a estos dispositivos no les puedes agregar mas memoria si quieres meterle mas música tienes que comprar un aparato con mas capacidad.
si te sirve el consejo dame un buen rating
gracias
Apr 27, 2010 | Coby MPC895 MP3 Player
Tengo una lavadora LXR7144EZ1 Empezo con un ruido
Mil gracias por tu ayuda, la lavadora cuando llena no hace ningun ruido, luego cuando empieza a restregar empieza un ruido fuerte y despues de esto se detiene por completo, muchas veces a trata de llegar al ciclo de exprimido. Pero el dia de ayer dejo de funcionar completamente.
Sep 01, 2009 | Whirlpool Washing Machines
Problemas de transmision automatica
hola que tal, tengo un saab 9000 1988 y tengo problemas con la transmicion aveses me hace los cambios y abeses no, si abansa para atras y para adelante pero me abienta los cambios cada que quiere,,, alguin tiene idea de que pueda ser?? nesesito ayuda ya estoy desesperado...
Aug 02, 2009 | 2001 Hyundai Accent
El motor esta trabado
si se puede hacer pero de entrada es necesario desmontar el motor completo para desarmarlo xq no tiene espacio para hacwerlo montado y pues de cualquier modo podria salir algo caro y con algo de tiempo
Jul 18, 2009 | 2000 Lincoln LS
Hola , necesito saber si puedo cambiar toda la maquina, excepto el DD y dejar este mismo como master, tengo programas que me costaria mucho conseguir e instalar de nuevo gracias
Muchas Gracias COnstantin, quizas me expresé mal, mira mi problema es que el pc, excepto el disco nos quedó chico, es decir, quiero cambiarlo por una maquina mas nueva core duo por ej, por ende con distinta placa, y el DD tiene toda la informacion y programass con licencia que necesito, entonces necesariamente tiene que quedar como master, me indicaba un tecnico que los driver de la placa podriasn darme problemas, si es así y tengo los drives de la maquina nueva ( placa) no debiera tener problemas?
agradeceré tu respuesta
gracias
Jun 23, 2009 | MSI PM8PM-V Motherboard
DONT START
La fuente de alimentacion esta fallando en tu TV. En un 95% de las veces si el TV no enciende la falla esta en ese circuito. Se puede reparar ya que las nuevas partes son dificiles de encontrar porque no creo que esten siendo producidas.
Si necesitas mas ayuda hazmelo saber, o puedes mandar un correo electronico a jah2mil@hotmail.com
Yo reparo toda clase de fuentes de alimentacion para LCDs, plasmas y muchos otras aplicaciones.
Oct 17, 2008 | Digimate DGL2700 27 in. LCD Television
LRD6100SWS Radar Detector Logo
120 people viewed this question
Top Uniden Vehicle Parts & Accessories Experts
John Nolan
Greg Cann
Greg Cann
Are you an Uniden Vehicle Part and Accessory Expert? Answer questions, earn points and help others
