Question about HTC Snap S522 Cell Phone
After full charge, battery lasts about 1 day, with only "device usage" on the battery.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 139 Answers
Hi, when a phone battery is fully charged and it does not stay long to power the phone,You might need to replace the phone battery.
Phone batteries has cells inside them that determines how long the battery life will last..When these cell dies, it will be unabletopower upthe phonefortoo long and the phone will go off..
To solve the problem of charging a battery and notlasting too long,you will need to replace the phone battery with a new one.
You can get a replacement battery battery from nearest outlet store around your area...
Warning before you buy a new battery, make sure that the phone does not get hot when you insert the battery inside the phone...Because that is not a battery fault. It's a phone board problem.
Take care and thanks for using fixya...
Posted on May 23, 2011
My TR3624 (12 deep cycle 6V batteries - 1 year old and heavily used) doesn't want to fully charge my batteries. It will charge to 100% at 70A and shut off nicely and go to the "3 bars mode"....
U indicate that the batteries have been heavily used. Well, they do wear out and heavy usage will accelerate their demise. When batteries start to go, they do not charge as well and continue to charge less and less.
Best bet is to check them all after they have been "fully" charged to weed out the offending unit(s).
Apr 14, 2017 | Xantrex Technology Trace Series Inverter /...
The last 3 days, my battery lasts only a few hours. It used to last at least 15 hours
Battery and Usage under Settings will tell you exactly what is draining your battery. You should power your phone off for a few minutes every 2 or 3 days.
Also try letting the battery die completely, and charging up to full UNINTERUPTED. This will help the phone reset it's battery meter, which may be the problem.
Your next step would be to backup the phone, apps, and SD Card files, and perform a factory restore. Then reinstall your apps and replace your data.
If that fails, you may simply need to purchase a new battery.
Apr 13, 2011 | HTC Hero Smartphone
My Blackberry 8310 just "died"
The device is performing on low battery power and requiries full recharge possibly a couple hours. How to perform a device recharge
1. power off completely
2. connect to power source with cables provided, expecting to the last the duration of the full charge
3. a full recharge once the process is complete would display a message on the phone.
4. until then, do not unplug
Dec 03, 2010 | RIM BlackBerry Curve 8310 Smartphone
How many hours we should charge the battery fist time Nokia-2700
There are basically 3 types of chemicals currently being used for cell phone and laptop batteries. Ni-cad, Ni-mh and Li-ion. There is a fourth makineg its way in Li-ion polymer. A couple things are consistent for all types of batteries no matter what chemical is inside. You must initially give the battery a 12-14 hour charge on the home charger. (Don't use a cigarette adapter for the first charge. This conditions the battery and don't take it off the charger that first time even if the charging indicator says it's full after 3 hours. Also the manufacturer's also state to run it thru 3 charge cycles. What that mean's is that you fully charge and fully drain 3 times. 1 full charge + 1 full drain = 1 charge cycle. Here's where the way you charge the battery starts to differ.
Ni-cad: Mostly only on older devices, has a "memory" effect, should be drained before a full charge is put on it, should be removed after overnight charge or can be overcharged and burnt out.
Ni-mh: Still used for some devices, has slight memory effect but not enough to have to fully drain before the recharge, should not be consistently left on charger after full charge that can eventually burn out battery and shorten usage time.
Li-ion and Li-ion polymer: Used on a lot of newer devices, has no "memory" effect, should be recharged as often as possible, actually likes to be charged and draining it regularly can cause the usage time to be shortened, can NEVER be overcharged so whenever you're near a charger put it on there. Besides those benefits a li-ion battery is lighter and smaller but the chemical can hold more charge than Ni-cad and Ni-mh.
So the one reply to your question said to error on the side of draining the li-ion batteries. This is incorrect information. You want to charge the battery before it gets below a 20% charge. Also batteries will not go bad from accidentally doing the incorrect charging procedure here and there but normally follow the correct procedure. One last note try to use the home charger more often than the cigarette lighter charger for best long term results. Cigarette lighter chargers do not give a full charge (about 95%) which in the long run can damage any type of battery listed.
Oct 07, 2010 | Nokia N70 Cellular Phone
NOKIA 5300 low battery . . if i will charge in
hi...
I belive your usage of mobile is more.the battery charge wil depend on the usage of the mobile. If you use the mobile too much then the charge wil not last more.so there is no problem with the mobile or the battery
thanx
Jul 17, 2010 | Nokia 5300 Grey Cellular Phone
Battery not holding charge on my 14.4v lithium iron drill giving short battery life during use, from new the battery would last approx 2 full days usage now 2 hours is the longest time is there any way to...
Sometimes rechargeable batteries loose charge with time. Replace the battery type on the drill and the duration will be back to normal :)
Apr 05, 2010 | Garden
Battery doesn't charge
When you connect the charger, if the light goes to red to green within a few minutes and the battery power does not last more than 1-2 hours or less, it may indicate that that the batteries will not take a charge anymore and need to be replaced. This can happen if the power chair has not been charged in a while or has been stored. Having the chair on or off while charging will not affect the charging process, but you ususally want it to be OFF.
Mar 11, 2010 | NRS Hoveround MPV 4 - Hovaround Used...
Charging problem
there is nothing wrong with your charger. The problem is from your battery.
The battery cell is very weak, such that it does not have the ability to with hold power for long.
Therefore, get another battery and the problem will be resolved. But make sure you charge the new battery till its full before you start using it.
Take care.
Mar 10, 2010 | Nokia N70 Cellular Phone
Battery life only last one full day on normal usage n web surfing and music and video
The battery is nearly worn out. Rechargeable batteries have a finite number of charge and discharge cycles and the maximum battery capacity reduces with age and use.
You need to purchase a new battery.
Nov 25, 2009 | Nokia E63 Cell Phone
How long should battery last after full charge?
Up to 9 hours of battery life after fully charge.
Nov 08, 2009 | Acer Aspire One PC Notebook
HTC Snap S522 Cell Phone Logo
247 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
