Question about Toshiba Satellite A135-S4527 Notebook
Won't boot I bought a used toshiba A135 laptop from a guy and it worked when i bought it, but now when i press power button, LED's come on but all i hear is a popping noise from speakers. Optical drive has no power and monitor wont show up. Any suggestions? Did i get burned? lol
  • prophetessac Aug 18, 2008
    Hello I am having the same issue with my laptop. How much should I expect to pay and what sugguestion for a hard drive should I get?
    Christina
  • Anonymous Aug 19, 2008
    I HAVE THE SAME EXACT PROBLEMS AND SYMPTOMS
    Scholar:
  • 46 Answers
I had one issues with this before and it ending up being the hard drive. Once the drive was replace with a different brand, worked fine. But this mine not fix your problem. If it does, kudos to you then.
Let me know if this works for you
comier957
Posted on Aug 16, 2008
Toshiba Satellite a135-s2386 won't bootup and CD/DVD drive won't open. The power button, plug button and battery button all come on. I tried taking out the RAM and switching the 2 RAM sticks. I also took...
I assume there is a specific reason that you mentioned the DVD drive won't open. Is it because there is a disk in it that you are trying to remove, and you can't because the laptop won't boot? You can open the DVD drive with a pin or paperclip. There is a little hole in the drive near the eject or open button. Insert a small pin or paperclip straight into that hole and push. It should pop open.
May 01, 2011 | Toshiba Satellite A135-S2386 Notebook
My toshiba a135-s2306 will not boot. The laptop locked up on me. It would not restart by pressing the power button, so I removed the battery and the charger. After restoring power and the battery, I...
Even though a lot of things might have gone wrong and caused this, especially if where you place the laptop is not well ventilated, and the CPU becomes very
hot.
It then shuts down automatically...and you will have to wait for a few moments, get a cool environment and power it on.
But I will also try and tell you some troubleshooting steps that you can try.
First of all, disconnect your battery from back of the laptop, and try to power your laptop without the battery there, if it powers up, then just get a new
battery.
Second, get a screw-driver, remove all the RAM(memory sticks) at the back of it, clean their interface with an eraser, and try to power it on first without
them, then replace them back and power it on.
Alternatively,
Remove all your RAM(Memory Sticks), and clean the tip of the connector with an eraser, and re-insert it one after the other.
That is, if you have two of them, after you insert the first one, put on your system and see if it works, then do the same thing with the other one.
If the two of them works, them insert the them all. but if it is just one that worked, just remove the other one that is not working and replace it.
Also from what you have just said, I suspect that your hard drive is likely to be corrupt, or having a bad sector on it.
To be sure of this, disconnect your hard drive from the laptop, and power it up without connecting the hard drive, if it boots up to the point where it says:
"Operating System Not Found" or "No Bootable Device Found", then that shows that your hard drive needs replacement
Kindly Let me know how it goes.
Hope this helps.
Apr 16, 2010 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellie A135-S4467 is not turning on
If they tested the PSU,power and found it to be working, and they
put your memory into another laptop and it worked
I would say it is your processor, most times people forget these cool from the bottom and they set them on places that they can't keep themselves cool and overheat.
If it was be, I would buy a used processor on ebay that was guaranteed to work, before buy a mobo,
Buy check the pice of both and see if its just better to buy new, with the advancement of processors, prices have dropped.
Feb 09, 2010 | Toshiba Satellite A135-S4467 Notebook
Toshiba A135-S4527 will not boot
Could be power supply (ac block and power cord) is dying or died. Laptops are notorious for this.
Aug 01, 2009 | Computers & Internet
Toshiba a135-s2276 will not boot
First try to reset bios by make short in cmos battery. If it doesnt work turn it off then remove battery, connect adopter power then turn it on, also if doest work press number one hold then turn it on.
Apr 20, 2009 | Toshiba Satellite A135-S2276 Notebook
Toshiba laptop satellite A135 S4527 power
take it with you when you go and try the new cord before you buy it , Toshiba's are Notorious for the charger cords to be crappy and also the port for the laptop itself to break and need repairing , witch you have to send it to toshiba to get done if that is the case
Apr 12, 2009 | Toshiba Satellite A135-S4527 Notebook
No power at all even if i press the power button
Most likely the only thing wrong is the power button. Try to either replace the power button board or use a wire to short circuit the two points under the push button to turn the machine on.
Jan 31, 2009 | Toshiba Satellite A135-S2266 Notebook
Laptop stuck in sleep / hibernate mode??
Try holding the power button down for at least 10 seconds, that should turn off the laptop completely. Then press the power button again to turn it on. Hopefully it will boot up.
May 14, 2008 | Toshiba Satellite A135-S4527 Notebook
Starting up problem
I had the same thing. I was passed down this laptop to checkout for a friend. After overviewing the system turns out the processer board got loose. Pushed it back in and she fired up..
Issue was green power led then 2 short orange flashes that repeated untill I discoved the issue.
Feb 22, 2008 | Toshiba Satellite A135-S4427 Notebook
My toshiba satellite a135-s2276 won't turn on
A coworker used to work for Toshiba and said that this is common for the Satellite A135 models and under warranty the fix was a motherboard swap for a newer/updated motherboard. Otherwise the unit is unusable.
Dana
Jan 24, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite A135-S4527 Notebook Logo
67 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
