Question about Rheem Water Heaters
The pilot light goes out on an intermittent basis - one week, two weeks or more.
Before calling service technician, open following link for Rheem troubleshooting resources.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
No error code: Without an error code, there are innumerable internal and external factors ranging from a simple plumbing crossover, to bad PC board.
Open link above and read no-error-code, and find copy of manual if available.
Best place to start is manual.
Read troubleshoot section, advisories, and required maintenance.
Burners require yearly cleaning, heat exchangers require yearly de-liming, and water filter should be cleaned monthly. Tankless are complicated machines requiring research, experience and expertise to diagnose and make successful repairs.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on May 23, 2011
Pilot goes out might stay on for a week or a minute
pilot fault not giving enough power to thermal couple or replace thermal couple
Apr 20, 2014 | Bosch & Tankless LP Hot Water Heater
Electrical ignitor on Kenmore Hot Water Heater Not Working
The water heater uses a thermocouple to generate a small voltage from the pilot light. This voltage is used to blink the led and allow the main gas jet to turn on. Either your thermocouple or the wiring from it has failed and needs to be replaced, or realigned if perhaps it moved out of position above the pilot light.
Mar 26, 2017 | Rheem 40 Gallon FVR NATGAS Low WATER...
My Rheemglas fury 21DV50 hot water heater pilot goes out about every 2 days for the last week and 1/2. It will light and I'll be able to have hot showers but doesn't last more than about 2 days. Is it the...
It could be a thermocouple but first take the whole pilot assembly out and disassemble it. Clean it very good (compressed air is ok) especially the orifice inside the pilot horn. You may just have a weak pilot. If the flame is in good contact with the thermocouple and problem still exist, then change the thermocouple. I believe in doing the free things first.
Jan 28, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Pilot will light, goes out when button let go,
A long time ago, in a place far away, I saw an old gas valve, might have been on a water heater, might have been off an A/C unit. I took my 10" adjustable wrench and unscrewed the coil that the thermocouple screws into. Now, when I have the problem that you describe I take the threaded end of the suspected thermocouple and put it into my spare. I light the pilot and hold the button down. Then, after a minute or two, I press the button on my spare, which now has the thermocouple attached. If the spare stays in the "ON" condition, I have just proven my gas valve to have faulted.
I suspect you main gas valve has failed, if you can find another valve, you can test as above, before buying a replacement valve.
Jul 20, 2010 | RTO W4 A.O Smith Gas Hot Water Heater...
Heater Problem
It is normal problem because u r heater is so old
out of company warranty so open it and clean it
NOTE
dont touch it after use means open it before use
means when it is not use in 1 hours because heater contain power in one hour after use
Jul 25, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
What's up with My Bosch Hot water heater??
it sounds like a thermocoupler
its located inside the unit next to the pilot flame and should be screwed in next to the pilot button at the other end
May 28, 2009 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
Pilot goes off every two to three weeks
Check voltage at the gas valve and at the thermocoupling. If you are reading more then 24 volts at the gas valve then replace it, or less then replace it also
Feb 10, 2009 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Pilot goes out
IF THIS IS A STANDING PILOT TYPE WATER HEATER MEANING THE PILOT STAYS LIT ALL THE TIME IT IS USUALLY CONTROLLED BY A THERMOCOUPLE WHICH IS USUALLY THE CULPRIT THIS IS USUALLY AVAILABLE AT ANY GOOD HARDWARE STORE GET THE SAME LENGTH AS YOU TAKE OUT EX 12-18-24 INCH
Nov 25, 2008 | Water Heaters
Water Heaters Logo
61 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
