Question about MSI MS-6580 Motherboard
Cannot install drivers for usb seagate expansion drive
  • MSI Master
  • 27,725 Answers
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
hope this helps
Posted on May 23, 2011
Seagate Expansion 1TB Portable External Hard Drive USB 3.0
Try with proper USB 3.0 drivers obtained from Intel, must work with original cable on the USB 3.0 computer port.
Feb 13, 2014 | Seagate Expansion Computers & Internet
Seagate Expansion 1TB external Desktop Hard Drive (9sf2A4-500) not detected.em?
Sounds like driver problem to me. Re install the driver by using installation disc, or if you have lost your CD, than use this Driver Update Software to update. I hope this helped.
Brian
Oct 24, 2012 | Seagate Expansion 1 TB USB 2.0 Portable...
Seagate expansion portable drive won't post makes clicking noise
Very likely the head is no longer aligned, and can no read the disc correctly. This is physical damage that can not be repaired. There are specialist, but at premium prices.
Oct 20, 2012 | Seagate Expansion 500GB External USB 2.0...
Need a replacement circuit board for a seagate expansion drive
it can be easily fix by computer service center so you please take to the nearest servicing center
Sep 20, 2012 | Seagate Expansion 1 TB USB 2.0 Portable...
Install seagate expansion
New drives have to be readied for use. Try Start > Run (aka Search in Win 7) type dskmgmt.msc. Look for your drive there. It should be without a drive letter. Right clicking will give you the options of initializing, creating disc partitions, and assigning logical drives. If this seems a little daunting. A wizard should load. If not there is refresh icon on the tool bar. You may want break down the 1TB down to a few partition because of the large size.
Aug 30, 2012 | Seagate 1TB Expansion External Desktop USB...
I cant find the installer for Seagate Expansion External Drive - hard drive - 500 GB, so i cant install this
Check with Seagates Customer support.
Should be an installer in their drivers section.
Possibly locate installer at www.driverguide.com
Jun 22, 2011 | Seagate FreeAgent Pro 500GB External USB...
I have a Seagate expansion external hard drive, i can connect it, but how do i use it-keep it simple
Put all your documents in my documents folder of your hard disk
or install the software come along with him CEEDO in the hard disk itself.
Always connect both the USP prot of the cale to the PC for better efficiency
Jan 15, 2011 | Seagate Expansion 1.5 TB USB 2.0 Portable...
I do not know how to use my Seagate 500gb expansion portable drive
Just plug it into your computer, it should install a driver and then you can go to 'My Computer' and click on the drive, it should be an F drive but it could be anything. An easy way to know which drive is the portable one is to go to 'My Computer' before you plug the other drive in, then you know which one is new.
Jan 13, 2011 | Seagate FreeAgent Go 320 GB USB 20 Hard...
My portable HD detect pc, but no driver found and cpould'nt open
If it shows up in my computer then just double click on it as you would the C drive or dvd or cd it should put the driver in already if it is showing remove safely sometimes it will require a reboot after it is installed
Jul 07, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
MSI MS-6580 Motherboard Logo
64 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
