Question about Grohe Home
We have a concealed cistern which won't refill until you give the wall a hit and then keeps filling until it overflows which is fixed by another thump to the wall. Any sugestions. This is a new unit. Greg
olddewsons
  • 38 Answers
SOURCE: Villeroy Boch subway toilet cistern filling up to much
On this model am not sure if it come apart. But if you have a air compressure try and blow though it. when you have it off toilet. sounds like its dirt caught in it.
hope this helped. :)
Posted on Jul 07, 2009
SOURCE: Modern toilet cisterns without overflowprovision
Most modern flush units have built in overflow protection, if the water level rises above the flush device then water runs into the toilet itself rather than out of the overflow pipe to the outside as in older toilets.
You could always check by taking the top off the cistern and push down the float device with your finger to see what happens!
hope this helps
Posted on Jul 28, 2009
Obertelli
  • 3006 Answers
SOURCE: water overflow from cistern to bowl
The shut off valve depends upon where your plumber fitted it and whether one was installed at all. If there's not one near the cistern then you'll need to find the stop valve which is on either the main household cold water tank outlet or if the cistern is filled directly by mains water then you'll need to turn off the main supply valve or even the valve in the street.
The fault is caused by a failed syphon assembly inside the cistern. Although it's possible to remove the faulty part and replace it the sheer number of different syphon assembly designs and the age of many of them usually mean that it's quicker and simpler to replace the entire assembly. Without knowing exactly which make and model of syphon you have it's impossible to give you any more specific details as the operating methods vary so widely, but if you're mechanically minded then you may well find that you can dismantle the old syphon and locate the failed seal. Sometimes all you need to repair them is an old car tyre inner tube and a pair of scissors. A repair often costs pennies and takes hours, a complete replacement syphon assembly often costs between £13 and £60 depending on the model and design (plus labour) but usually takes no more than around fifteen to twenty minutes to replace if the cistern is close-coupled to the toilet and a bit longer if it's an old-fashioned high level cistern with restricted access.
Given the need for guesswork based on the limited details in your question I hope that you appreciate my reply and ask only that you return the favour by rating my answer.
Posted on Oct 01, 2009
Testimonial: "thanks for the fast reply and solution"
peterrance19
  • 399 Answers
SOURCE: after cistern refill outflow into toilet bowl
hi i would suggest your ball valve in the cistern needs ajusting remove the top of the cistern you will see the ajustment screw at the end fo the ball **** arm hope this helps
Posted on Nov 15, 2009
  • 150 Answers
SOURCE: even after filling up, water from the cistern keep...
That is the cistern overflow running.You need to adjust the fill level in the cistern by adjusting the plastic screw on the ballfloat or adjust the height of the float if its the silent fill tpe
Posted on May 22, 2010
I have a leak coming through my ceiling from the ensuite toilet above. It is an ideal standard wall hung with concealed cistern behind tiles. There is no obvious access panel. The tiled wall is flush.
The flush control panel normally comes off. You can then hopefully see inside. You won't be able to see much though as the cistern will be in the way...
Places to look for leaks are:
Soil pipe to pan
Cistern to flush pipe
Flush pipe to pan
Cistern overflow.
Apr 17, 2017 | Home
Twyford dual flush cistern
replace the whole control unit
There may be 2 problems
the small washer that shuts off the water flow when the level is reached may be swollen and not sealing properly
the section at the bottom has cracked at a thread level
so by replacing the unit you will eliminate both problems
to remove the unit, turn off the water tap, flush the system, holding the button down until all of the water has gone
remove the inlet pipe at the bottom of the cistern
undo the retaining nut under the cistern and lift the control unit out
there will be water in the bottom of the cistern so use old towels on the floor to soak up the water that will run out
Mar 23, 2017 | Home
Pozzi Ginori Cistern In Wall won't stop running, how do the internal parts come out for repair
It could be the fact its overflowing through the siphon( that's the bit your talking about) because the water inlet has a problem, try changing the washer on the inlet if its easier than removing the siphon or replace the inlet.
May 20, 2012 | Home
2001 dodge dakota sport 4.7. i flushed the radiator, now it won't take all of the antifreeze that is required for refill. help
You have an air bubble. Look for plug on top of the intake manifold next to the thermostat housing, Remove that and fill until coolant starts to run out. Put plug back in loosely and continue filling until no more goes in. Tighten plug and replace your radiator cap. Fill overflow bottle and start engine.
Jul 13, 2011 | 2001 Dodge Dakota
Our automatic ice maker will not quit dripping in the freezer. It keeps clogging the ice maker with icicles and large blocks of ice. Essentially, it keeps "freezing over." We have defrosted it...
if it keeps filling and overflowing you have a bad water valve on the back of the fridge.the part number is WR57X10027 and the valve is around 75 dollars.first thing lift the arm or shut off the ice maker so it won't leak anymore,you're missing a few letters off of the model number so when you call your parts store give them the full model number,open the fridge door,look up on the right hand side wall up near the ceiling and give them the model number to make sure you get the correct valve,shut off the water supply to the fridge,then have the new valve next to the old valve when you remove a water line from the old valve just connect it to the new valve,do this until everything is changed out and the new valve is in place,turn on the water supply and you can check the ice maker to make sure it doesn't overflow.you can manually start the ice maker by grabbing the plastic arms of the ice maker and pull them forwards slowly until the arms start to advance on their own,you'll hear the water valve fill the ice maker and then you can watch it fill to see if the water is filling it correctly and i'm sure you'll be fine with the new water valve installed
Jun 05, 2011 | GE Monogram ZDI15C Automatic Icemaker
Even after filling up, water from the cistern keep...
May 20, 2010 | Home
Home Logo
70 people viewed this question
Top Grohe Home Experts
Mike
Donni Steen
Are you a Grohe Home Expert? Answer questions, earn points and help others
