Question about Bosch Washing Machines
F27 or f80 fault codes for Bosch logixx8 1400..... switch off machine and leave for 30 mins and works OK again
F:80 Turn the power plug 180 dgr.
Posted on Aug 06, 2014
SOURCE: my bosch exxcel 1400 washing
After checking that the pump was working freely and water was being extracted by means of the pump, I then assumed it could be one of two faults faulty brushs or motor but still as washing machines can hold a charge of electricity capable of causing a fatality after being isolated I ordered the parts required by refering to the model no. and enr no. located behind the door and requested a competent person to fit them. The parts i ordered were brushes.
Posted on Jun 17, 2008
  • 25 Answers
SOURCE: fault codes
found fault to be in motor assy
Posted on Jul 03, 2008
SOURCE: what is error code f27
i'm
Posted on Nov 08, 2008
THENTHEREWER
  • 131 Answers
SOURCE: Hi - we have a
if this unit is only two weeks old,its safe to say its under warranty ,if you can't remedy this yourself by consulting the owners manual,contact the place of purchase &/or the manufacture,i'm sure they will be glad to repair or replace the dryer.any attempt by you or any unqualified person to repair this will void your warranty.hope this helps.thanx for using fix-ya
Posted on Nov 26, 2008
barkencoa
  • 3463 Answers
SOURCE: hot point f-08 fault code
F08 means that the heater relay cannot be activated.
Suggest you check heater, and or thermistor (thermostat) for a fault, replace as req'd.
Please rate my solujtion.
Thanks.
Posted on May 20, 2009
I have a 4 year old Bosch Ecologixx 7 self cleaning condenser dryer, WTW86561GB/02. The problem is after 10 minutes the machine just switches off, and the display panel goes dark
sounds like the thermal safety overload is cutting the power due to overheating hence why it just turns back on after a certain time, when the safety overload reaches a certain temperature it will cut the power to the machine or in some cases just the heating elements, once it cools down it resets and power is restored and by using the warm setting it obviously isn't as hot so its not overheating, its highly likely it is all blocked up internally with lint (i know it says self cleaning but they never work for more than a few years before requiring a proper clean and service)
Jan 30, 2017 | Bosch Washing Machines
E2 Fault. Brushes replaced. unit was operational before. Brushes are in the correct way.how do we clear the fault code ?
Unplug machine and leave for about 30 mins and hthis sometimes reset computer in machine
Jun 30, 2015 | Bosch Washing Machines
E50 fault
An imbalance during the spin cycle has occurred. It's possible that the appliance has been overloaded, or the load is causing the drum to be unbalanced.
If the machine has been used repeatedly in a row, which can cause the motor to be overloaded, leave it to cool down for approx. 30 min. and then try again.
If the problem continues to occur, there is a problem with the motor. This has to be repaired by a Service Engineer.
Dec 21, 2013 | AEG T57800 Electric Dryer
F27 fault on bosch logixx 8
F27 is a problem with the pressure switch
Nov 04, 2012 | Washing Machines
Changed ignition switch and now the car thinks it's being stolen. It shuts off the gas flow. Does anyone have the code or know how to reprogram for the new switch?
YOU HAVE A PASSLOCK SYSTEM WHEN YOU TURN THE KEY THE COMPTER READS IT OK OK RESET YOU MUST DO THIS
1 TRY TO START VEH AND LEAVE IN RUN POSITION FOR 10 MINS
2 DO IT AGAIN
3 DO IT AGAIN
FOR A TOTAL OF 30 MINS THIS DOESNT ALWAYS TAKE THE FIRST TIME. MAY HAVE TO DO IT MORE THEN ONCE AGAIN TRY TO START VEH AND JUST LET THE KEY GO AND WAIT 10 MIN 3 TIMES
Feb 11, 2010 | 2003 Oldsmobile Alero
Fault code 01
this is actually a fault code error code 1 not one minute check your manual as codes different on some machines from memory i think 1 is a filling fault this machine uses fuzzy logic if water fill takes longer than 4 mins (low pressure) machine stops can be restarted by pressing start button.
see if machine will complete just a rinse cycle.
good luck
Oct 04, 2007 | Bosch WFE 2021 Front Load All-in-One...
Washing Machines Logo
1,279 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
