Question about Microwave Ovens
Hi I have a LG MC805clr 850 watts mircowave oven that works in mirco wave mode but does not reach temp in convection mode any more an error message is displayed after somw time and then the oven stops with no heat.
  • jowillson May 24, 2011
    Daniel
    If it is the door switch then why does it still work in mircowave mode.....in mircowave mode the unit heats up, turn table turns around and the light works, but in convection mode the oven turns on to pre heat the turn table turns the light comes on, but it does not heat up it stops after a short time say 2 mins and it displays a code F2.... would like to confirm your solution.
  • jowillson May 25, 2011
    Daniel
    I removed the door switch unit and bench tested each switch.... switch o.k.... also checked wiring from the door switch to the circuit board.... wiring o.k. Removed rear panel to check the oven element... it looks o.k. as well.....stumped.... any recommendations. Maybe l should buy a new one.
  • 4,323 Answers
Hi
If everything else is working fine then it seems the issue is with the door switch, if this switch is bad control senses that the door is still open and so won't heat. Hope this helps...please post back for further assistance.
Daniel
Posted on May 23, 2011
  • Daniel Scott
    Daniel Scott May 24, 2011
    I agree that the unit heats up, however, this should not be happening. F2 error code means door lock failure, please check the door switch wiring. If wiring seems to be fine then replace the door switch assembly. Hope this helps...please post back for further assistance.
    Daniel
  • Daniel Scott
    Daniel Scott May 25, 2011
    If you tested the switch as given in this link then it seems that the issue is with the control board
The food is not heating
The wave generator (Magnetron) or one of its components is defective.
Nov 25, 2013 | Miele M638EC 1500 Watts Convection /...
Mircowave wont heat food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ,;
Aug 25, 2011 | GE Monogram ZE2160SF Convection /...
JNM1851SM1SS - MIRCOWAVE makes a load noise when you try to cook sounds like a deep arcing sound...
heatman101
May 04, 2011 | GE JNM1851SMSS Convection/Microwave Oven
Microwave not heating anything? everything else work
heatman101
fgshg
Jul 28, 2010 | LG LMH1517 1000 Watts Convection /...
I AM LOOKING FOR A DOWN LOADABLE MANUAL FOR SHARP R-1874 850
Sharp Electronics has a website for support and your microwave is listed and there is a tab to access downloadable manuals etc Visit their page HERE
Jun 01, 2010 | Sharp R-1874 Convection/Microwave Oven
Cooking temp to bake cake inn convection mode samsung model
Hi I guess you are cooking usng the combination setting? if so The cake will be hard due to increased microwave energy, I would suggest reducing the microwave energy on the Samsung unit when using the combination setting.
Hope this helps
Jan 07, 2010 | KitchenAid KHMC107BT Convection/Microwave...
Only heats to 325 degrees in convection mode. takes long time to reach this temp.
Hi two possabilities here, either the element or the thermostat is faulty and will need to be replaced.
Jan 07, 2010 | Amana AMV6177 Convection/Microwave Oven
The unit works fine, but the plastic frame around the control pad is broken, just above the door open button. Where can I get a replacement part, and how do you get that frame off of there?
you must take it to a approved Sharp engineers, who will give you aprice for replacement.
This is due to m/waves holding charge inside even when you have unplugged it and may give a electric shock unless you know what you are doing
Oct 03, 2009 | Sharp R-1851A 850 Watts Convection /...
The mircowave has no power, outlet works, just mirco strop workin
HI, the popping sound that you herd was the result of a failed HV capacitor. This failure will render the unit inoperable, as you has witnessed at this time. Replacing this failed HV capacitor, will correct this issue. I would also advise to check the cut-off fuse and in-line AC fuse as well. There may be some issues concerning the integrity of these fuses as well.
Sep 11, 2009 | Goldstar MV-1501 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
