Question about Seiko Kinetic watch
10 year old Seiko Kinetic (model5M62-0B00) blue face. Last week stopped and after some shaking started again but seconds moved in 2 sec intervals for a few hours. Went OK for a week and again last night stopped and same thing happening again. The advance button appears to have stopped working now as well
    Problem Solver:
  • 7 Answers
After 10 years it will be likely that the Kinetic capacitor will need upgrading. Your watch is designed to tick in two second intervals to tell you the power is very low. The power button will work again when it has some power to show. Yorkshire Watches www,yorkshirewatches.co.uk can do the upgrade for you if your in the UK. Give them a ring.
Posted on Jan 22, 2013
I have purchased a new Seiko kinetic SUN007 mens watch. After hours of swinging back & forth to charge the watch, the 'second' hand still moves in two-second increments. (After charging via movement,...
I have a Seiko kinetic watch and it has behaved perfectly for over two years and therefore I think that yours is faulty.
I suggest you send it to Seiko to have it repaired or replaced under warranty.
Apr 05, 2011 | Seiko Sun007 Kinetic Watch for Men
My 5 year old Seiko kinetic (divers') watch: beyond shaking, is there a way to wind it? I used to be able to press the power button and see the second hand advance 20 seconds. Now I never have enough...
I am going to make an assumption or two. One is you wear your watch regularly. At least every other day. Two is you are not sedentary. Try wearing the watch for three days. If the power indicator doesn't read at least 15 to 20 you have a bad cell (capacitor). If it does charge up to 15 to 20 then see if it lasts very long. Should last a couple weeks or more. If not then you still have the same problem. You can also go to a watchmaker and he will have a piece of equipment that can charge your cell in 3 1/2 hours. Then if the cell goes dead rapidly he/she will replace it. Should cost around 50 or less.
Mar 13, 2011 | Seiko Kinetic watch
SEIKO KINETIC SQ 50 HAVE USE MY WATCH FOR 14 YRS
It is unlikely that the capacitor will have any charge on it so you should shake it gently to charge it up. You certainly can't do any harm by charging it, even if the capacitor did have any charge.
Feb 20, 2011 | Seiko Kinetic watch
Hello. I have purchased a seiko premier perpetual snp025 watch. From the moment I opened the box the 2nd hand is moving consistently at 2sec intervals and it does not move normally every 1sec. Also the...
Two sec jumps is low power in the elec store,,, winds with movement back and forth as your arm would swing. Sometime the day date function is changed by pressing the small button type crown in slightly with your finger nail.it may have on or two detents if so it adjusts both functions. if not the stemcrown needs to be used to set day and button to set date.
May 09, 2017 | Seiko Premier Kinetic® Perpetual Watch for...
My watch, Seiko Kinetic Auto-Relay (5J22-OD60), no longer holds enough energy to keep working overnight, the second hand starts moving at two-second intervals and it stops before morning.
You have a bad capacitor. You can either try to repair this yourself with a special upgrade kit for about $20 (and maybe screw it up) or pay an expert who will do it right for $67.
http://www.qualitywatchrepair.com/seiko_kinetic.htm
For an extra $20 he'll do a pressure test on it to be sure it is water-proof but since this is a pro you really don't need to worry about it on a non dive watch.
Sep 29, 2009 | Watches
Watch stopped while in hospital and now, although running again, has the second hand moving in two second intervals
Some Seiko kinetic watches and other self charging watches do this when the battery is low. If it relies on you moving to keep it charged that may explain why it stopped in hospital. Try giving it a good shake and see if it starts moving smoothly again
Aug 10, 2009 | Watches
I have not worn my SEIKO kinetic wrist watch for a
Here is the information from the website. The link to the manual is provided below. HOW TO CHARGE AND START THE WATCH Swing the watch from side to side approximately 50 times. * Before swinging the watch, check and remember where the minute hand is so that you can tell if the start-up indicator has worked or not. First, check that the crown is at the normal position. * If the crown is pulled out and the watch is swung, the start-up indicator will not work even if the watch starts operating. * Swing rhythmically at a rate of twice a second. * No additional benefit is obtained by swinging the watch more quickly or with greater vigor. * When the watch is swung, the oscillating weight in the generating system rotates to drive the mechanism. As it rotates, it gives out a sound, which is not a malfunction. 1 2 The minute hand moves quickly and stops as the watch starts operating. (Start-up indicator) Then, it will move at 20-second intervals. 3 After checking that the minute hand has done this, pull out the crown to set the time. 4 After pushing back the crown in to the normal position, swing the watch further approximately 350 times to reserve one day of power, and then, put the watch on your wrist. http://www.seikowatches.com/support/ib/pdf/1m20_e.pdf Good luck, Techjoel
Jun 05, 2009 | Seiko Kinetic watch
Seiko kinetic
I habe seiko kinetic work and stop work
Feb 07, 2008 | Watches
Seiko Kinetic that doesn't work
This watch does not have a battery, but has a capacitor which is rechargable. It is not taking a charge, and needs to be replaced. You should take it to a store with a watchmaker ON THE PREMISES. Or you could send it to: www.bscwatchrepair.com
Jun 27, 2007 | Seiko SKA192 Wrist Watch
Seiko Kinetic watch Logo
844 people viewed this question
Top Seiko Watches Experts
Vernon Taylor
Are you a Seiko Watch Expert? Answer questions, earn points and help others
