Question about Water Heaters
I need a wireing diagram for siebe climate control ltd ikon model T45. Thanks
  • 70 Answers
Google it or go to the company web site,
Posted on Jun 12, 2011
GeoSpring GEH50DNSRSA wire diagram
Here are all the resources that are available for GE heat pump without calling GE and hearing them tell you to call service technician:
http://waterheatertimer.org/GE-heat-pump-manuals-by-date.html
http://waterheatertimer.org/Review-GE-Heat-Pump-water-heater.html
There is no wiring diagram for the bundles of wires coming from chip control board.
As general rule, these things are made to last 10 years, and afterwards will not function or be repairable. It's like a window air conditioner, except connected to water pipes, and connected to computer chip and multiple sensors, each susceptible to failure, and then the machine is used 24 hours a day, 365.
Designs have changed continually from 2009 to 2010 to 2012 models.
It's likely you got a nice piece of junk with depleted anode rod and failed sensors that stopped working and somebody got rid of it because it wasn't repairable.
http://waterheatertimer.org/How-to-recycle-water-heater.html
Add a comment
Jun 02, 2013 | Reliance & 40 Gal Electric Mobile Home...
Wiring diagram on whirlpool gas water heater
Whirlpool is AO Smith tank-type heater.
Year, model, type of heater not known.
So add a comment and then expert can look up the manual.
You probably have power vent, or dampered water heater, otherwise the only wiring would be for thermopile, thermal reset, and igniter.
Power vent, or dampered, of flow control water heaters plug into outlet, and wires from gas control run to the various components.
Copy following link to troubleshoot by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
http://waterheatertimer.org/Review-AO-Smith-Effex-water-heater.html
Don't forget to add comment and include model number that shows on label located side of tank.
Sep 21, 2012 | Whirlpool 6th Sense 40-Gallon 6-Year Tall...
Aquastar125WP is overheating and the strainer has been removed. We need to fix it. Have any ideas? Thanks for your support, Martina
Before calling service technician, open following links for troubleshoot resources:
The problem could be bad gas control solenoid, or bad sensor, or bad wiring or bad PC-board, etc, or combination of problems. Fixing one problem may not completely fix problem.
http://www.bosch-climate.us/bosch-hot-water/aquastar-service-bulletins/
http://www.bosch-climate.us/bosch-hot-water/aquastar-service-bulletins/38b-125-series-bulletins.html
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Before installing tankless water heater, read the service manuals and product manual to make sure you have testing skills and equipment needed to repair tankless gas water heater, and that you are prepared to buy expensive parts and do the recommended yearly and monthly maintenance.
Also check that area has qualified service technician, and that person carries parts on-hand, and is certified to service your model number. Keep Tankless manufacturer contact information on-hand, and be skeptical of promises of unlimited hot water, and effortless long-lasting water heating, and saving money. The only folks saying this are the folks selling the product, and not their customers.
Fix most tankless gas water heaters yourself, same day, all brads for about $350.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Sep 21, 2011 | Water Heaters
I replaced the heating elements(2) and switiches(2) on my Rudd electric hot water heater. Model PES 40-2. The switghes came with several wiring diagrams.(universal) Can I get a diagram specific to my...
Residential water heaters USUALLY follow same diagram unless water heater is wired for other purpose. Multiple diagrams on instructions show available options. Take photo of wiring before removing wires on any electrical device.
Upper element.
Black wire from top of heater connects to #1 top left screw.
Red wire from top connects to #3 top right screw.
Blue wire from upper element connects to #4 middle screw on right side
Red wire from lower element connects to #4 middle screw on right side
Yellow wire from upper element connects to #2 lower left screw
Black wire from lower thermostat connects to #4 lower right screw
Upper element: Yellow and Blue wires connect to either screw
Lower element: Red wire from top connects to either screw
Lower thermostat: Black wire from top connects to top screw
Short wire between lower thermostat and lower element
http://waterheatertimer.org/images/Water-heater-wiring-w-numbe.jpg
http://waterheatertimer.org/images/Thermostats-numbered-divided-500.jpg
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html
Sep 18, 2010 | Whirlpool Water Heaters
Model RE2424 W-Z (SP) one the 2 remote controllers is not displaying any power lights or 2 digit display. The other unit still works and the heater unit is functioning ok. Would like to get the other...
Disconnect both controllers. Put the one that works ok on the wiring supply to the one that isn't working. If it does not work you have a wiring problem. If it does work then the controller is faulty. This wiring is 12volt low amps by the way. When connecting the wiring can go either way on to the back of the controller. Don't let the two wires touch if the power is on to the heater, this can blow the circuit board on some older models.
Aug 05, 2010 | Rinnai Digital Remote Water Heater Control...
Titan-SCR2 N-120, water heater, need schematics
I have taken pictures and produced a wiring diagram for this model
Jan 23, 2009 | Water Heaters
Hooking up Tandem Rinnai R94 LSi
you will find a master controler at a electrical lighting and hardware store you have to be specific with the model and voltage/amprage rating. they will give you a schematic with the controler. .............please rate this ........thanks
Aug 30, 2008 | Water Heaters
Water Heaters Logo
173 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
