Question about Numark Industries Numark CDN 22 Mk4 Double DJ CD Player
Numark CDN225 System is about 18mnths old and I use it 4 times a week. Left side(facing deck) CD will not read CD,s I put CD in and I just get a message that says rEAd. When I open the CD drawer the disc is spinning. Also the other side I have noticed occasional speed fluctuation. My CD,s are clean and have no contamination and only original CD,s www.dancewithstuart.co.uk
3 Suggested Answers
jdvillanueva
  • 2098 Answers
SOURCE: Hi, I purchased the Numark Twin
Hi kshanley,
If you have necessary tools and test instruments, know safety precaution in basic troubleshooting try the steps below to solve your problem.
Assuming that the disc is good.
1.Clean the lens. - Sometimes because of dust and any fine foreign objects the lens can't read any disc. If you have a CD Lens cleaner, play it to the affected area. If this is not available you may manually clean the optical lens. Open the cover and gently clean the eye of the lens by smooth,clean,soft cotton buds. Be careful while doing this, just a gentle stroke only.
2.Check the ribbon - Check the ribbon connected to the lens from the main board for scratch, damage. Once it has an open line then of course the lens can't read the disc. Also try to erase the contact by pencil eraser. If you've done the steps above and the symptoms still there then the next step requires you a little knowledge in soldering technique and reading the ohmmeter.
3.Check the motor - Check the motor that spin the disc with an ohmmeter. You can test it using the ohmmeter (x1) even it is connected on the lens assembly.Good motor - reading should be fairly high and it will spin. Bad motor- reading will drop to low resistance and will not spin.
Click this link for more info.
LINK1
LINK2
Hint : Most of my repaired unit the above parts are commonly caused of the problem.
If you confirmed that you have a defective motor then replace it with a new one. Before replacing the new motor you have to check the clearance of the disc holder with the old one. The clearance should be the same as the old because if not the lens will not read the disc if it is too far or too close.
If the above steps didn't cure the problem, high chance that your optical lens was faulty.
If you can't do the job yourself, I would advice you to look for a professional to troubleshoot the symptom.
Also, check if your unit is under warranty period, avail it because the manufacturer will fix it for free. Don't attempt to open the cover(it will void the warranty).
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on May 03, 2011
djromann
  • 158 Answers
SOURCE: my numark cd mix2
Hallo! This is caused by the laser fault. First unplug the cord, high voltage!!! Disassemble the device, look under the cd place you will see a little lense. Clean it VERY DELICATE with a piece of cottonwool with alcohol, can clean it twice with alcohol and then with a dry one. If doesn't help, then need to replace the laser reader system with a new one, it's that where the lense is placed, it must have on it an badge with the serial number, you can search it by that number/code.
Posted on May 18, 2011
Kmx02 disk spins fast, does not read
Educated guess is the deck cannot read the disc for some reason and is trying to find the index to start reading it. Try another disc and see if you have the same problem. Some discs will not play on some machines especially if you copied them yourself due to data duplicating copy guards installed in some machines.
Mar 04, 2014 | Numark Industries Numark KMX02 Dual Deck...
Numark cdn450 has tray error message in left well
For all kind of brands cd or dvd players There is in every cd or dvd tray in the front bottom or under the tray so crazy you can not think an microswitch necessary that will be by mechanic close of the tray detect if the tray is closed and give a timed signal (close or open) to focus laser for reading of table of contents if the belt is bad it can take to long by a slipping tray drivebelt for the detection , or the microswitch or brass plate contacts are have a little corrosion on it or even it can be broken by a missing timing.
Dec 23, 2013 | Numark Industries Numark CDN450 Rack Mount...
How do I connect my laptop to my numark icdmix3
If you want to mixdown onto your laptop, get a cable with RCA left and right on one end and an 1/8 headphone jack on the other. On the back is a master out w/left + right and go to line in or mic input on laptop. If you don't have a line in, you have to disable the mic signal +4 db setting in control panel/audio properties volume control. Open properties there and add mic volume control, and open advanced to turn off +4db setting.
Mar 04, 2013 | Numark Industries Numark iCDMIX 3 Dual...
One cd player wont read
Take a can of compressed air and blow into the player all around and try it. The heads get dirty over time and stop reading. Clean the dust off the laser head and they usually start working again.
Feb 28, 2013 | Numark Industries Numark CDN 22 Mk4 Double...
My NDX400's display screen doesn't show anything. When I turn it on, all the "characters" flash white, so I know it works. But then, it just goes blank. No matter what I do, nothing shows...
If you was to turn the deck upside down you will see 4 main screws in the corners holding the silver top to the black chassis of the deck. undo these screws and carefully turn the deck over and lift the top off slowly. I say slowly because before putting it down (you might need someone to hold it for you) you need to un-clip the white plug and there will be a data ribbon stopping you from pulling the lid away. this is the strip you need to check both ends that the connections are clean and pushed in properly (the blue strip on the connector should be facing the middle of the circuit board) be careful not to snap the connector and make sure you push it into its socket straight and not at all at an angle or it could snap. put the white connector back in and pop the lid back on and turn it on to see if worked.
Jul 05, 2011 | Numark Industries Numark NDX400 Tabletop...
My numark cd mix2 won't play a disc on the left hand side, it just says no disc
May 18, 2011 | Numark CD Mix2
Numark KMX02 left hand CD will not eject
Usual cause is a little rubber belt either deteriorated or is slipping that drives the carriage to do the eject. Open unit and recover the CD and the drive belt will be obvious...
Apr 14, 2011 | Numark Industries Numark KMX02 Dual Deck...
Use the cdn22 on weekends for 6 hours a night. at least twice a nightone of the cd players said no disc when i put one in. its not always the same side that does it. the only way to correct it is to power...
Check for contamination on the disks that won't load. Also if you have things like cigarette smoke or "fog" machine that can cause the problem. The precision of the head of the CD players is amazing as the tracks are millionths of an inch apart and it doesn''t take much to cause a problem. If trying to load again the disk finally works, then it may not be registering on the hub quite right. Care in centering MAY help.
Mar 14, 2011 | Numark Industries Numark CDN 22 Mk4 Double...
How to use Audioline Pro DJ Multimedia Mixer M Dex 3.0
I have been recently using this Cd Dj deck at parties and have some general knowledge of the product, it has alot of potential. Is there anything in particular that you need help with? Or is it the general concept of using them.
Currently, i don't think there are that many websites that explain how to use the Cd decks, however i can provide you with some basic information. Most of the information here could be worked out by trial & error.
- Pitch control on the right of each cd deck can be slid up ( slows it down %) and slid down (speeding the track up %) i think the pitch control has a range of either +-10% or +-16%.
- Cue button, has the potential for Cue'ing or setting up the cd to instantly jump to the "cue'd" point with the press of this CUE button. This is done by either pressing play/pause button and rotating the jog wheel to a point of time in the track which automatically sets the cue point OR holding down the >> or << search button to find a spot within the track at a greater speed.
-Vinyl mode. Pressing this button will set the deck to the "vinyl mode" to simulate scratching or even backspins. pressing this button again will change the mode back.
- the Crossfader (or 'X' fader) button will select the left cd track if the x fader is all the way to the left and the right track if the x fader is all the way to right. having the X fader in the middle will play both tracks together.
- Low, Mid, High. These nobs on the middle section of the deck change the individual track by which it is corresponds. (Left side = left cd track, and vica versa) Low refers to the Bass of a track which can be essential for mixing two tracks and elminating excess bass noise. Mid refers to the drumming and even synth of a track, and changing this can result in some cool sounding effects. High refers to the 'high' frequencies of the track playing, such as snares, hi hats and possibly vocals. All these controls are crucial to understand in order to mix 2 songs together successfully. It's good to get a chance to muck around with these cointrols. The middle of each control resets the setting to normal or default.
- Channel fader. the two controls that slide up & down on both sides of the mixer on the deck. This is also referred to the volume setting. Useful for mixing seamlessly one track into another.
- Gain. This control at the top of the mixer refers to the volume level or 'gain' of the cd track that it corresponds to.
- Jog wheel. Serves 3 purposes. firstly it can be used whilst a song is playing to temporarily speed up or slow down the track to match with the song on the opposite side. secondly, whilst holding down the 'search' button, operates as a control to quickly find a spot in a song. and lastly when selecting "vinyl" mode, can simulate the reaction of a vinyl turntable. The scatch function, and backspin effect.
- The pitch button, is just another control to speed up or slow down a song temporarily whilst holding down the '+' or '-' button.
- Reverse button, for a certain amount of time will play the song on the left or right in reverse.
- Time. this button is essential to change the time selection on the cd deck, to either "Time elapsed", "Time remaining" and "total time remaining on the cd".
- the "tap" button, allows the user to physically "tap" the button in time with the song's beat, which calculates the Beats per Minute (Bpm) of that song. which is essential to work out the bpm of 1 track to mix the speed with that of the opposite deck.
- Cd/usb/sd, changes the mode of system reading. from CD to USB or SD card.
I really hope this general guide to using the Audioline ProDJ MDex3 has helped!
Peace. Marc.
Apr 03, 2009 | Music
Numark Industries Numark CDN 22 Mk4 Double DJ CD Player Logo
137 people viewed this question
Top Numark Music Experts
Matthew Spark
Matthew Spark
Pieter Vleeshouwers
Pieter Vleeshouwers
J.D. Browning
J.D. Browning
Are you a Numark Music Expert? Answer questions, earn points and help others
