Question about Tangent Quattro WiFi Internet Radio Wireless Adapter
Very poor Wifi receipt with tangent quattro radio
What is the power button on the radio on 2001 Audi Quattro tt stereo?
User's manual of your car should have a schematic indicating On/off button else, try different buttons. One of them should turn your device on,
If you can't find any button which might turn your radio on, probably it is bad, not working.Return it to shapo and claim your warranty
Nov 08, 2015 | OEM 2001 Audi Allroad Quattro Radio / CD...
How can I get my Tangent Quattro MKII Internet Radio repaired?
I remember answering this question but in case you missed it - Yes it is possible to do so by getting the Digital Encoder connected to the Selection Dial
Jun 23, 2015 | Audio Players & Recorders
How do i get the radio started? I am going insane - mine is a tangent alio?
Here is the link to a user manual for a tangent Alio radio. I am not sure it corresponds to your model (you do not say).
Here is also a screen capture from the manual linked to above.
Mar 29, 2012 | Office Equipment & Supplies
The tangent and inverse tangent offer the incorrect sollution. whould i simply get a new calculator?
No, you don't need a new calculator. Yours simply has the angular mode set to grads. The inverse tangent of 1 is 50 grads, the inverse tangent of sqrt(3) is 66.6... grads.
To change the angular mode, press MODE one or more times until you get the display "Deg Rad Gra". Select the mode you want (from the results you're expecting, it's 1 for Deg).
Jan 26, 2012 | Casio FX-300MS Calculator
Is there any way I can use my tangent quattro with a wireless modem
You will need the ip address of your tangent quattro for that.
then, connect it with your your wireless modem, which is also connected to your pc or laptop.
then enter the ip address of the quattro in your web browser in the laptop.
you will get some settings there.
feed in the dns, gateway and other details for the modem and this should get your quattro working with the wifi.
Mar 10, 2011 | Tangent Quattro WiFi Internet Radio...
How do I find the tan of an angle and given the tan value, how do I find the angle
To find the tangent of an angle:
  1. input TAN (it's up one and left one from the division key)
  2. then the desired angle
  3. then a close parenthesis
  4. And then hit ENTER
To find the inverse tangent:
  1. Press 2nd
  2. Press TAN (TAN-1)
  3. Enter the desired tangent value
  4. close parenthesis
  5. hit enter
this will give you the angle that yields that tangent value.
You might have to switch your calculator from radian to degrees or from degrees to radians to get the expected result. To do that:
  1. Press MODE
  2. Scroll down to where it says ANGLE
  3. change it from either RAD or DEG
Good luck
Mar 01, 2011 | Texas Instruments TI-83 Plus Calculator
Don't have user manual for Tangent Quattro MkII
This product is quite easy to use and set up, so within a few minutes of switching on, I had successfully connected it to my wireless router and I was able to select internet radio stations and store favourites.
Sound quality from the built in speaker is very good indeed, and the set offers very clear reception on analogue FM as well.
I probably will never use all the facilities this set has to offer, but I have worked out the stuff I need to receive internet radio.
Thank you for following up my query.
Tony
Sep 17, 2009 | Tangent Audio Players & Recorders
Tangent Quattro WiFi Internet Radio Wireless Adapter Logo
Top Tangent Computers & Internet Experts
David Payne
David Payne
Are you a Tangent Computer and Internet Expert? Answer questions, earn points and help others
