Sharp mx-2700n keeps jamming. No visible obstruction. Can I reset machine to test for faulty sensor?
    Scholar:
  • 157 Answers
Sir,
you have to clean all Rollers(Paper Feed)with wet cloth.then check printer propertis under features paper type as plain paper(which type of paper u r using select that paper size.
Posted on May 23, 2011
What shall i do to return my sharp mx-2700n copier to operation?
have you check the sensor actuates on the registration section
Oct 19, 2015 | Sharp MX-2700N Color Copier
I have a sharp 2700 copier with code H5-01
HI
H5-01 means you have had five consecutive jams, it would suggest there is either something blocking the paper path, or the paper is not being picked up at all.
Try resetting the machine by the following:
Program, *, clear, *
It will then ask for a simulation code, enter 14 and press print, are you sure?, press yes. Clear all, clear all, should reboot the machine and try again.
If it continues to jam, try a different cassette.
Cheers
Andy
Apr 23, 2015 | Sharp MX-2700N Color Copier
We have a code h4-30 on a sharp mx-2700n how do I reset?
You need to make sure the machine is in Copy Mode when you hit
# * C *
enter 14, then touch start
execute on the screen
the machine will reboot and the code should go away.
If it persists you may need some maintenance. If you're in Houston give us a shout. Our labor rates are low compared to the other Sharp dealers in Houston.
Skelton Business Equipment Houston Copiers
http://www.youtube.com/equipmybiz
Jul 07, 2014 | Sharp MX-2700N Color Copier
WHAT IS A CA CODE ON A SHARP MX-2700N
Believe it or not, it means "Check All". It's kind of like a Check Engine light in a car. Typically it is caused by a door not being closed completely. On your model, the most likely culprit is the door on the right side of the machine that slides out on rails. Open it, make sure there are no obstructions, and slam it shut. These machines are notorious for the right side door becoming slightly warped, and they don't recognize that the door is shut if you try to gently close it. Don't try to knock the machine off of it's stand when you close it, but do it quickly and with a bit of purpose.
Feb 28, 2011 | Sharp MX-2700N Color Copier
Hello, I have (had) a paper jam on a Sharp MX2700N. I have removed all copies but am now advised to call for service Code H5-01. Any ideas?
after call for service, the machine will indicate an error code like H4, F2,etc. if you can give me the code i will know what to do
Feb 03, 2011 | Sharp MX-2700N Color Copier
How to delete password protected pront job in Sharp mx-2700N when password is lost? I can log in as admin (web-access to printer) but cannot delete the documents in Documenthandling. BR, Steven
Open web interface of the printer and supply admin password.
As an administrator you should be able to navigate to the System Settings screen.
Select Document Filing Settings and navigate to the section Administrator Authority Setting.
Select Delete so you can delete forgotten print jobs (remember to Save the setting).
Navigate on Document Operation where you can see a list of existing saved print jobs.
Select the jobs to delete and go on.
You don't have unwanted ghosts anymore on your machine!
Most important: always remeber to smile and to help people. Take care.
Jan 05, 2010 | Sharp MX-2700N Color Copier
Sharp mx 2700n how to go SP mode and i get error code h5.01 how i solve this problem
Use SIM14 to
cancel the trouble.
Entering the simulation mode
1) Copy mode key ON → Program key ON → Asterisk (*) key
ON → CLEAR key ON → Asterisk (*) key ON → Ready for input of a main code of simulation
enter 14
accpet yes clear..
machine should restart.
You may have to have a tech look into why this is jamming...
Hope that helps
Lbcoaster
Dec 23, 2008 | Sharp MX-2700N Color Copier
Error code h4-01
P * C * enter sim 14 press copy key then CA. Machine should reboot. if problem re-occurs your thermostat in the fuser has tripped
Dec 01, 2008 | Sharp MX-2700N Color Copier
Error Message H5-01
H5-01 = detecting 5 consecutive POD_1N jams
Check the fusing section for jam paper. (winding, etc.)
Use SIM14 to
cancel the trouble.
enter 14
accpet yes clear..
To fix this you need to have the fusing unit looked at... could be various problems causing this , from bad paper to bad rollers?
Nov 24, 2008 | Office Equipment & Supplies
73 people viewed this question
jasbo
jasbo
