Question about ASUS RTN10 WirelessN Router Black
Hi i am using asus rtn10 problem i am faing is.1 can acces internet.. i have broad band connedtion and have attached router to one of the iobox now nor i am unable to acess internet nor can c other computer.. though have changed the ip address of router to 192.168.2.1 so that it should not conflict with broad band moderm 2 the thing is that when ever i am getting into set up its said that u haven connected the cabels.....
  • Anonymous May 23, 2011
    Have you got your whole network setup with static ip addresses or have them all obtain one automatically?
  • 556 Answers
SOURCE: WL 520 GC can only acess net in "default" before encrypting
To enable WEP encryption requires configuration changes in two places the router (WL-520G) and for the network adapter on the associated with the computer expecting to use the wireless router. Do you both believe you made the appropriate changes to both devices required? The router and the computer
Another possible issue is either the router or the network adapter do not support WEP meaning the option is not possible at all.
Posted on Dec 07, 2007
SOURCE: Cannot through ASUS WL-530G connect to internet
I've settle my problem. Set the correct VPI and VCI provided by ISP.
Posted on Nov 20, 2008
  • 67 Answers
SOURCE: Connecting 2 routers (ASUS WL-500W and D-Link DSL-G604T Wireless)
This will give you a "Double NAT" setup. Meaning, Your D-Link router is connected to the external internet address assigned to you by your internet service provider. More than likely this is a DHCP address you do not control. Your D-Link router is then translating the address to the 192.168.1.x network. This is the first NAT translation. You are then connecting the ASUS router to DLINK, causing a second NAT translation. (Internet ADSL --> D-Link WAN Port --> D-Link Lan Port --> ASUS WAN Port --> ASUS Lan Port to computer/server/etc. ) If both of your routers are giving out DHCP addresses, then this is all that is required.
Posted on Dec 10, 2008
rahul26485
  • 611 Answers
SOURCE: asus wl-500w and modem
your sub net mask is wrong you have to put 255.255.255.0 and make 192.168.1.1 to modem and 192.168.2.1 to router
Posted on Apr 11, 2009
  • 153 Answers
SOURCE: can not find mac for router or how to spoof pc mac to router so my ips will let me connect
Usually the MAC is on a sticker somewhere on the router, but your ISP should also be able to detect it.
Posted on May 15, 2009
WHY DOES ASUS RT N10 NOT RELEASE DNS ONLY TO A WINDOWS 7 PC
Make sure your windows 7 pc internet connection is set to obtain DNS server's automatically .(From your router)
Jun 25, 2014 | ASUS RTN10 wireless router
How to connect two ASUS RT-N10 Routers to PPPoe connection?
All routers don't work the same. You have assigned to the second router to an IP address that is outside of the pool. Some routers will not see this. Try assigning the second router to the .50 IP and see if it is identified. If so, you know that is your problem. You can then decide to either reassign the second router's IP to a high address in the pool, or use the .50 IP and in the first router, use the advanced settings to reserve the .50 address to the second router so it will not re inadvertently assigned to another device, causing an IP conflict.
Sep 15, 2012 | ASUS RTN10 wireless router
What ports do i plug into to be able to use a Broad Band internet
Plug the lan cable from Modem to the Router Wan / Internet port. From Lan port ( Router) you can connect to switch or computer if you have any . Or connect computer via wireless.
That' all
Mar 25, 2011 | D-Link AirPlus Xtreme G DI-624 Wireless...
I have a ASUS RT N10 Wi-Fi Router. I connected the wi-fi Router to my Desktop after-which I am not able to access the Internet. If I connect my desktop directly to my ADSL Modem, I am able to connect to ...
Check to see if you can plug the wan port to your adsl modem and then plug your pc to the router. on ADSL, some ISPs will record your mac address to avoid sharing. Just see I your router supports cloning your mac. All you do is login to your router from your pc, and it should be under your Wan settings. Use DHCP unless specified otherwise, and ensure to enter any pptp login info if your ISP provided any.
Dec 27, 2017 | ASUS EZ N Wireless Router up to 150Mbps...
WL-520GC... wifi signal very good; but no internet connection...
login to the router page and you need to configure your router settings as per your internet service provider then save the settings and reboot your router and check it
Jun 29, 2010 | ASUS EZ N Wireless Router up to 150Mbps...
How can i connect the router? i got a intellinet 192.168.1.1 there is one wan and 4 ports are there.i have dialog broad band connection.how can i connect it?or iwant to install any software?
This is very easy to do and you should have no problems doing this. The first step to installing it connecting your router to your broad band router through the wan port. All you do it take your Ethernet cable that went from your broad band router to your computer and attach it to your new routers WAN port. next wile your new router is turned off, turn off your broad band router and then turn it back on wile it is booting up turn on your new router this is not always necessary but it will make sure that they sink together properly. And that's it your done just hook up all of your other computers to the remaining ports and they should work with out a problem.
PS. this is just the basics of setting up your router if it has wireless you may want to think about implementing some security measures such as encryption.
I hope this helped.
Thank you,
Norse
May 18, 2010 | Intellinet Active Networking Intellinet...
The wireless connection is not connecting
first unpluuge the modem and the router than plug in the internet from the modem to the router where it says internet ,than you install cd in pc restart the pc and plugg the modem and the router back to the outlet in the wall and see if you can read if your router is broad band if not you will not get acces to the internet and if you have the wireless or inbuild internet than you might be able to be online , so make sure if you dont ahve abuild inn use awirelessinternet adapter that goes with the router
Aug 04, 2009 | Belkin Wireless-N Wireless Router with...
ASUS RTN10 WirelessN Router Black Logo
53 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
