Too much noise with use of cd rom driver - Computers & Internet
    Master:
  • 328 Answers
Too much dust is in it
the dust is make the lubricating oil and grease lost
if you have enough experienced try to unscrew it clean it dry cloth then grease it`s gears with vassilen Jilly
Posted on May 23, 2011
Hello i want buy solution cd-rom driver..... my
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties you will have options under general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
Jan 16, 2011 | Dell (074JH) Internal 48x CD-ROM Drive
When I insert a disk nothing happens, it makes really loud noises asif its about to take off. This carrys on and my computer does not recognise there has been a disk inserted.
The driver for your CD-ROM needs to be UPDATED. click start, then control panel, click performance and maintenance, then click system, click the hardware tab, then click DEVICE MANAGER.under the CD/DVD ROM DRIVES, your CD-ROM should be listed. It may have a "?" mark or "!" to show the driver is out of date. If so, then right click on the device, click the "driver" tab, and click update driver. If the driver is updated, but the CD-ROM is still not functioning, follow the same steps, however; when you right click the device and enter the properties, instead of entering driver, click the "PROPERTIES TAB: and UN-CHECK the box in the DIGITAL CD PLAYBACK. If that does not work, then search online for a driver that is compatable with your windows system,
Nov 22, 2010 | Compaq (120192-B21) CD-ROM Drive
Averatec 5100 series. the disc drive makes some clicking and other noises, but will not play disks. They are spinning some when I open it up. I am trying to play the recovery disks and can't
It is NOT NORMAL for a CD-ROM to experience any of the below symptoms.
  • No noise
  • Clicking during accessing the CD-ROM.
  • Noises when the CD-ROM is not being accessed.
If you are exhibiting any of the above issues it is likely that the CD-ROM drive is defective and it is recommended that it be replaced.
BEST REGARDS MICHAEL
Nov 11, 2009 | Averatec 5110HX Notebook
Won't recognize CD, it makes a lot of noise, like if is running but nothing happens. (Dell inspiron 1420 laptop)
U need to reinstall the driver for you cd/dvd rom drive u can do this by "Start right click computer select properties click hardware tab ,device manager then dvd/cd rom drive uninstall driver then click action tab check for hardware change i should be gone after this step go to the dell web site and download the correct driver for your cd/dvd from the web site here is the link http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen this should fix the problem hope this helps
Oct 11, 2009 | Dell Inspiron 1420 Laptop
Every time I put Any kind of CD the driver cd rom
first uninstall the drivers of CD-ROM and then again install the drivers you will see that it will play your CD.
If it doesn't play then check your CD-ROM jumper settings remove the pin and set it to slave mode.
Oct 08, 2009 | Lite On (LTN486S) Internal 48x CD-ROM...
I lost the driver
It does not look like it burns CDs. Here is the Features of the LTN-486S.
  • 48x CD-ROM with Pure-CAV Technology.
  • E-IDE Interface, support all PIO, MW-DMA, Ultra DMA-33 modes.
  • Support Power Saving Function.
  • Support High Speed Digital Audio Extraction ( DAE ).
  • Support High Speed VCD Data Extraction.
  • Support Plug & Play; Emergency Manual Eject.
  • High Speed CD-Audio Playback Technology to Improve Audio Playability.
  • Access all format CD, CD-R, CD-RW Title & Disc ( support up to 99 mins ).Easy-TrayR Design for both horizontally & vertically use.
  • Gear-Driven Tray Loading Mechanism to improve reliability.ABS Auto Balance System ( 486, 485 ) Mecha to Reduce Vibration R Noise.
  • WSSR Wire Suspension System ( 483 ) Mecha to Reduce Vibration & Noise.
  • Jul 01, 2009 | Lite On (LTN486S) Internal 48x CD-ROM...
    Acer aspire 3500 DVD ROM making noise
    type of noise ? It might just need a cleaning. Try using a compress air can to clean. Look inside to see nothing is stuck in there.
    May 06, 2008 | Acer (91.48T37.003) CD-RW/DVD-ROM (Combo)...
    I need to download a driver for matshita cd-rom cr-176
    The driver you are looking for might be found here, http://www.cdrom-drivers.com/drivers/0/104.htm
    Dec 30, 2007 | Panasonic CR-176-D (CR176D) 24x CD-ROM...
    Cd driver
    CD-ROM driver help CD-ROM drivers, helping you load your CD-ROM drivers on PC computers, listing what to have in the autoexec.bat / config.sys, listing different drivers .
    Computer CD-ROM drive help and technical information. Complete technical help and support dealing with computer CD-ROM drives.
    Good Luck if this dont do it for ya, re-install your computer back to the factory setting.
    Please dont for get to Vote, Thank You.
    Dec 26, 2007 | Acer Aspire 5100-5033 Notebook
    Cd rom
    Where can I get the driver for my CD-ROM?
    Visit our hardware download section to obtain a generic CD-ROM driver (oakcdrom.sys) and mscdex.exe if needed.
    If you are looking for a specific driver for your CD-ROM drive or a Firmware update, please see our CD-ROM driver page.
    Dont for get to Vote / Merry Christmas.......Good Luck!
    Dec 06, 2007 | Computers & Internet
    Computers & Internet Logo
    20 people viewed this question
    David Payne
    David Payne
