Question about Dell 3000cn Laser Printer
Dell 3000 printer
I can not replace the toner, it will not budge, any ideas?
  • 3 Answers
The toner is secured on both ends. if the carousel is not in the correct position you need to rotate it. Push in a peice of folded paper into the small opening on the left side of the printer. This will push a lever and let the carousel rotate.
Posted on Oct 05, 2008
Dell Printer problem
Generic toners often cause this error. Was the cyan you purchased a aftermarket compatible?
Jul 26, 2012 | Dell 5100cn Laser Printer
My Dell 5110CN printer is printing a double image
I am having the same problem, and I am using the original toner cartridges that were supplied with the printer, so yes, they are genuine Dell toner cartridges.
Dec 27, 2009 | Dell 5110cn Laser Printer
Drum full of waste toner. Do i have to replace the
I have no idea what ikkenom is smoking.
The Drum Cartridge unit is as user-replaceable as a toner cartridge.
Yes, you will have to replace the drum cart.
http://accessories.us.dell.com/sna/PopupProductDetail.aspx?c=us&l=en&cs=bsdv&sku=310-5732
Dell wants $169 for this part. Here's what it does:
Highlights
* Applies toner to the page
* Provides a usable life of up to 42,000 page impressions (up to 10,500 pages per color)
Overview The Imaging Drum Kit from Dell is specifically designed for use with Dell Color Laser Printer. This kit includes an imaging drum and instructions on how to replace it. It applies toner to the page and offers a usable life of up to 42,000 page impressions (up to 10,500 pages per color).The part number located on this toner cartridge is: P4866
Manufacturer Part# : M5065
Dell Part# : 310-5732
It comes with very detailed instructions on how to remove the old cartridge and install the new one. Very easy, but there's no way around the price tag.
Nov 18, 2009 | Dell 3100cn Laser Printer
I use to get thousands of copies from one cart -
DELL has two types of toner cartridges for your printer:
- a 3000 Page Standard Yield Toner Cartridge (Manufacturer Part# : RP441 | Dell Part# : 310-8701)
- a 6,000 Page High Yield Toner
(Manufacturer Part# : GR332 | Dell Part# : 310-8700)
The Toner yield is based on printing pages with 5% page coverage in accordance with ISO/IEC 19752 testing methodology. Yields vary with usage and environmental conditions.
In practice, depending on what type of documents you print, one cartridge can print much less than the quantity of prints advertised.
You might perhaps bought before a high capacity (more expensive cartrige)?
Also, if you are using compatible (not original Dell cartridges) or reffils of the original cartriges , the yeld of the cartrige may vary.
Aug 18, 2009 | Dell 1720dn Laser Printer
Ink on the edge of the page everytime we print a document.  we refill our toner, but have done so for years.  dell says that it is bc of the refilling and that it has filled up our drum??? any...
The Dell 1700 cartridge can leak from a failed mylar blade that sits against the Developer Roller.
The plastic locking ring on the and of the Developer roller spindle (of the toner cartridge) can come loose, or break (over time).
The drum unit has a relatively low capacity to hold waste toner, and all toner is not the same (waste toner shouldn't be re-used - it will just fill up the waste section of the drum even faster). Some toners are more efficient than others.
If you reset the 'replace drum' indication, without actually replacing it (or at least emptying it) you will soon have the drum over-full of waste toner, and the only other place it can go then, is inside the printer, and onto the paper.
Jun 23, 2009 | Dell 1700 Laser Printer
Cleaning the Dell 3000 CN
Dell 3000 CN has no printheads, printheads are on inkjet printers, this is a color laser.
On a laser there is nothing that you can clean with a software.
If printer is not printing replace toner cartridge or try reinstalling drivers.
If printouts are dirt, then the printer must be manually be cleaned inside, see Clean your laser printer safely with these tips
Feb 24, 2009 | Dell 3000cn Color Laser Printer
Dell 3100CN w/new black toner cart reads "Black toner LOW"
service your printer and change roller taplon tape and fuser aseembley.
Oct 09, 2008 | Dell 3100cn Laser Printer
1710 Dell Laser Printer
Check the gears on the drum and the toner..it may have worn out...
Aug 01, 2008 | Dell 1710n Laser Printer
Dell 1720dn Error and Toner light on
After replacing the drum unit you have to tell the printer that you've done it(it's not smart enough to figure it out itself). Have the front door open and press and hold the Cancel button on the printer until all lights flash in sequence then let go. Then close door and try.
Apr 09, 2008 | Dell 1720dn Laser Printer
Dell 5100cn Laser Printer Problem
My Dell 1600n suddenly stopped printing. It keeps saying "No paper," and even though I've changed papers, fanned it, squared it, changed how much, how little.............it still says "no paper."
Dec 27, 2007 | Dell 5100cn Laser Printer
Dell 3000cn Laser Printer Logo
152 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
