Question about John Deere Garden
I have a L118 John Deere mower. When cold, the mower moves forward and reverse without problems. I mow my 1/2 acre yard and at the last couple passes, the mower barely moves forward and has no reverse. after a cooling down period, the mower drives normal in forward and reverse. This has happened the last two times I mowed. Is this a fluid level problem or worse? Can I fix it myself? The mower is only 4 years old and has not given me any problems until now.
  • 608 Answers
Hi, remove the battery and battery support tray and clean all debris from around the hydrostatic drive, fan and cooling fins. Your problem is caused by the hydrostatic drive overheating. Hope this helps, regards Phil
Posted on May 23, 2011
John Deere Riding Mower won't steer after a rollover accident. How do we fix? Or even know what to fix?
not sure but if it is mechanical steering I would look for a bent tie rod on either side and from the steering gear under the hood ..
Oct 16, 2015 | John Starter Deere Sst18 Spin Steer Deere...
Mower was moving & just stopped
You'll have to take a cover off where the drive is for wheels as there is probably a belt there
Sep 12, 2014 | John Deere Original 130 160 165 175 180...
John deere sabre 2354 hv moves slow forward, even slower in reverse
this hydrostat drive tractor is designed to max at 5.5 mph forward, 2.5 in reverse, check linkage at pedal if you dont think your achieving those speeds
Mar 23, 2013 | John Deere 420,1020,2010,2020,2510,2520...
John deere riding mower will not go forwards or backwards and was just mowing yard with it. it will start it will cut grass but will not move now help
If it is the belt driven version you should have a deck belt and a drive belt. The drive belt is under the engine. If you have the hydraulic version check for a broken linkage at the pump.
Apr 22, 2012 | John Deere Garden
I have a John Deere L120 tractor with a hydrostatic transmission which after a half an hour of mowing struggles to go in reverse and seems to loose power when moving forward without stressing the motot. I...
Hi, your problem is caused by the transmission over heating. Remove the battery and battery carrier and clean all grass and debris from the hydro cooling fins and fan. Hope this is helpful, regards Phil.
Sep 08, 2011 | John Deere 22HP VTwin 48" Riding Mower
I HAVE A JOHN DEERE L118 RIDING MOWER AND TODAY WITHOUT ANY WARNING THE MOWER JUST STOPPED MOVING.I HAVE NO LEAKS OUT OF THE TRANSMISSION AND THE BELT IS NOT THAT LOOSE. THE LINKAGE IS ALL GOOD AND TIGHT....
yes,,, they just go bang,,if its striped the drive key they just stop,
have a look at the pully ends if you can turn one with out nothing moveing the key has striped take off the pully and replace the woodruff key,,easy to fix some times?,
Aug 08, 2010 | John Deere Garden
Mowing right along and suddenly the tractor won't go move
it's 1 of 5 likely things
The drive belt from the engine to the transaxle is totally slipping or broken
The linkage from the control pedal to the transaxle is faulty.
The transaxle is broken (not user fixable)
The by-pass rod is pulled out
The brake pedal is pushed or the linkage is stuck in the "brake" position.
Jul 11, 2010 | John Deere 22HP Hydrostatic 42" Riding...
John deere x340 wont move
there is a release usually behind the seat that has to be pulled in order to push it physically. make sure that the release is pushed in for the forward/reverse to work.
May 26, 2009 | Garden
John Deere L118 Riding Lawn mower speed problem
I have lost the key to my John Deere Model L118 lawn mower. Where can I buy a replacement?
Mar 16, 2009 | Garden
Garden Logo
653 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
