Question about Ford Garden
How do you connect a ford tractor 2910 starter. How do the wires connect to the starter?
4 Suggested Answers
  • 218 Answers
SOURCE: 1950 8N FORD TRACTOR WON"T START.
Hi..my name is Keith..and i have 9 ford tractors..i have 9N's..2N's and 8N's..and i have converted one or two of them over to 12V..and i use the solonid that has only 1 side post...and thats what my original starter swich connects to and on the big terminal i have the battery wire and a 12 gauge wire that i run to the amp meter....i hope this helps..and if you have any questions..please write back
Posted on Jun 30, 2009
  • 8404 Answers
SOURCE: my 1949 8N Ford tractor, the starter just spins
My thought is you need a new "bendix" for lack of a better word. The device I speak of spins out and connects with the flywheel. There is the possibility you have electric problems but based on what you say, I think it is mechanical.
Thanks for posting your question at FixYa.com
Pleae vote
thank you
a
Posted on Nov 09, 2009
  • 202 Answers
SOURCE: Diagrams_For ford 2N tractor starter
If you have not already found the info, I would suggest visiting the following website for some detailed help:
mytractorforum.com
No cost but will have to join to post questions. Likely all info can be had simply by searching the Ford "N" section. Good Luck!!
Posted on Nov 27, 2011
How do i find a starter wiring diagram for ford 4630 tractor
Try this web link: http://www.maidaozhi.com/ford/ford-4630-tractor-wiring-diagram
Oct 18, 2016 | Ford Garden
Ford 1520 tractor..no poer to dash
Check all wires and connectors for green or oxidized wires. Check the fuses and check all ground wires. Check starter solenoid wires for bad connection. The main power to the dash should be powered from the solenoid.Here is a link that should help: Alma Tractor Equipment Inc
Mar 06, 2015 | Ford Garden
Wiring a selonoid
http://www.ntractorclub.com/
The link above is just one of a dozen or more very helpful websites for Ford 8n tractors.
The original 8n tractor had a six volt battery with positive ground (this is different than most automobiles that have a negative ground). The starter solenoid is energized via the ignition switch and the large starter button in front of the gear shift, the small wires going to the solenoid energize a coil which "pulls in" and completes a circuit that then provides 6 volts directly to the starter motor through a large, heavy gauge wire. The smaller wires connect to the two terminals on the top of the solenoid and the heavy wire goes to the larger post on the solenoid and originates from the negative post of the battery... Hope this helps. There are many, many schematics and pictures available on the "net" The Ford 8n community is very large and extremely helpful....Good Luck
Apr 11, 2014 | Ford 8N Tractor
Ford 8n Is It Time to Replace the Starter?
Bad brushes it is not making contact with the brushes.
Jun 22, 2013 | Ford 8n,9n,2n, Tractor Starter With Drive
Quits running when I let go of starter button
run wire behind switch broke or not connected, or just a bad switch
Feb 08, 2013 | Ford 8N Tractor
I ran over rock and tore my oil pan. oil leaked engine hot. i shut off. i have removed and repaired pan, disconnected rods, freed up, everything turns pistons up and down. put everything back together and...
Similar to a vehicle starter, there has to be two positive wires attached to the positive terminal on the starter, and then there has to be a ground wire. A starter will not operate if there is no ground wire connected.
Aug 11, 2010 | RTO Ford Tractor 2000 3000 4000 5000 Water...
Do you have starter wiring instructions
Starter wiring on these are pretty easy, here are the following steps...
First, disconnect the battery first before attempting any wiring repair or replacement of electrical system components. I assume the old starter has been removed, so here are the steps to wiring on the new one.
First trace the generator wire (generally a 10 or 12 guage) wire from the generator. this wire along with your positive terminal cable from the battery and a wire which runs to the "light" pull switch all connect to the left side of the starter solenoid which i on top of the starter housing. This solenoid has "2" sides. With the bracket at the rear (towards passenger seat) the left side holds the three wires discussed above. The other side should be connected to the starter itself that has a bolt on the outside. This is a ground wire. If your starter didn't come with a new start solenoid, then this ground wire from the starter will go on the right side of the solenoid. Lastly, there will be a place to mount another wire to the top of the solenoid housing. This wire will run to the push button start near the gear shift on transmission housing. After all these connection have been completed, then reattach wires to the battery, and the tractor should start. If the tractor has been stored a while, may want to drain gas and replace with new for best start, and also check all the fluids such as water, oil, and the trans/pto/and hydraulic lift fluids.
Let me know if you need anything else!
Chip
Apr 03, 2010 | Ford 8N Tractor
My 1949 8N Ford tractor, the starter just spins
Pleae vote
thank you
a
Nov 09, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
Apr 13, 2009 | Ford Tractor 8n Front Emblem
Garden Logo
47 people viewed this question
Top Ford Garden Experts
Dennis Key
Dennis Key
donald boissonneault
fordexpert
Are you a Ford Garden Expert? Answer questions, earn points and help others
