Question about HP Officejet 5610 All-In-One InkJet Printer
I can not receive fax but i can send fax the printer hp officejet5610 was at the client he receive the error that says fax fail brought the printer to my workshop the printer gives the same error please help
    Guru:
  • 731 Answers
Hi, Make sure that the fax header contains the full 10-digit telephone number of your HP fax product, including the area code.
  1. To modify the fax header, use the following steps:
    1. Press Setup on the product control panel.
    2. Press Basic Fax Setup , and then press Fax Header .
    3. Type personal or company information using the keypad, and then press OK .
    4. Type the phone number, including area code, for your HP fax product, and then press OK .
Regards,
Riztech
Posted on May 23, 2011
We have a receiving problem with our HP Color LaserJet CM2320nf . The exact issue is that, sometimes the machine is unable to receive a fax with any number of pages from different senders Also, the...
Error Code 223 (ECM error)
The receiving product has been unable to receive an entire page even after multiple attempts to rereceive the parts of the page that contain errors. This is usually due to extremely poor line conditions.
1. Reattempt the fax reception at a different time when telephone line conditions have improved.
2. If the error persists, disable ECM. Errors may still occur, and may result in degraded image quality on the received page. However, the ability to receive the entire document will be improved.
Error Code 420
V.34 negotiations have failed from the originating product during phase four, which occurs after V.8 and before the first T.30 frames are exchanged. Compatibility problems have been observed in this area when sending to non-HP units.
Reattempt the fax transmission at a different time when telephone line conditions have improved.
Error Code 421
V.34 negotiations have failed from the originating product during phase three, which occurs after V.8, before phase four, and before the first T.30 frames are exchanged. Compatibility problems have been observed in this area when sending to non-HP units.
Jul 20, 2011 | HP Laserjet CM2320nf All-In-One Color...
I need assistance with fax error codes # 322 and # 358. What do they mean?
Error code 322- There was a communication error with the receiving fax machine due to poor telephone line conditions.
Solution
Set the receiving machine to receive at a slower transmission speed
If the session fails after sending several pages of a large document, resend the document as several smaller documents.
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Error code 358--
The remote user pressed the Stop key,
The remote machine encountered a system problem such as no paper or a paper jam.
Try
Configure the local fax machine to use a slower reception speed.
Disable ECM mode on your machine.
Try sending a fax to another location.
Mar 03, 2010 | HP Officejet Pro L7680 All-In-One Printer
Receiving error 388. Can receive faxes but won't connect with other fax machines when trying to send
The reason for the error code:
4e5e48b.jpg Error Code: 386, 387, 388, 389, 390, 391, 392, 393, 394, 395 Definition
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Solution
Please Click here and follow the instructions to resolve the issue.
May 21, 2009 | HP Officejet 6310 All-In-One InkJet...
How do I fix an "error 442" on the fax part of my hp 6110 all-in-one
Per HP:
Definition
An error occurred during transmission after one or more partial pages were sent. The sending machine was unable to restart the control channel connection(handshake) before sending more data. This error typically occurs when the receiving fax disconnects after receiving part of a page. It can also be caused if the receiving fax is using a fax format incompatible with the HP fax (usually during color faxing).
Solution
Try the fax at a different time when telephone line conditions have improved.
Apr 19, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Hp officejet 5610 Wont scan . Print. Copy
your printer is dead and is uneconomical to repair. sorry
Jan 25, 2009 | HP OfficeJet 7310 All-In-One InkJet...
How do i retrieve fax report from hp 4215 all in one
1 Press Setup.
2 Press 1, then press 1.
This selects Print Report and then selects Automatic Reports Setup.
3 Press ! to scroll through the following report types:
– Every Error: prints whenever there is any kind of fax error (default).
– Send Error: prints whenever there is a transmission error.
– Receive Error: prints whenever there is a receiving error.
– Every Fax: confirms every time a fax is sent or received.
– Send Only: prints every time a fax is sent.
– Off: does not print fax reports.
Note: If you select Send Only, you will also receive error reports if there is
any kind of error generated.
4 Press OK to select a report
More information? you can download manual here
http://h10032.www1.hp.com/ctg/Manual/c00095626.pdf
Sep 05, 2008 | HP Officejet 4215v All-in-One Printer
Hp 5610 won't receive fax from lexmark fax
Are you able to receive faxes from others from the same location, if not just ask her to consult her service provider and ask to get the no checked of yours why is it that you she is not able to send fax to you only as your fax machine is capable of sending and receiving fax from others it should be dsome issue with her service provider.
If it was your All-In-One printer thrn you should not have received faxes from any one, not a specific number.
Good Luck
Aug 19, 2008 | HP Officejet 5610 All-In-One InkJet...
Fax
344 Error can be caused by a few things. One of the following is occurring:
The sending fax has failed to respond to a fax command from the receiving fax due to poor line quality or fax interruption.
The sender has pressed cancel button while the reception was in progess.
In rare conditions, incompatibility has been encountered by two faxes and causes the sending fax to abandon the fax call.
Solutions:
Fax session was using ECM. Check your fax settings under the fax set-up menu on the printer. Disable the ECM (Error Correction Mode).
Fax at a different time to see if line quality improves.
Try relocating the fax to a differnt phone plug.
Replace the phone cord attached to the fax/printer.
Aug 18, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP officejet 7210 fax error
HP Officejet 7210 All-In-One InkJet Printer
Error code: 405
When I send a fax I have a dial tone and the fax feeds through, I hear the other end answer it says it is sending and then I get the printed page that says: "A communication error occurred during the fax transmission."
Oct 29, 2007 | HP Officejet 7210 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
101 people viewed this question
Seeker5211
Seeker5211
