Question about D-Link AirPlus DI-524 Wireless Router
Good afternoon, for last month I have problem with my wireless router. From time to time router withheld signal. If I unplug power cable and after that I plug this cable back, everything looks good
  • 50 Answers
Check your setting to see if you don't have "Connect-on-demand" turned on
Posted on May 23, 2011
Cant get wifi unless I am a couple of inches from router. All other wifi devices work perfectly. I even downloaded the latest driver directly from Intel and problem still exists.
Having a wireless Internet signal in your home allows multiple devices to use the same Internet connection without having to run lengths of Ethernet cable to each device. Given that the wireless network is transmitted over the air, the consistency of your Internet connection depends on the strength of the wireless signal. If wireless signal strength is not strong enough to give you a consistent Internet connection, there are a few simple steps for finding the problem and improving your signal strength.
Reset all devices. The majority of Internet issues, including poor wireless signal strength, are very often solved by a simple power cycle of all the devices in the network. Locate the power cords of both your modem and your wireless router and remove them (if you use a modem/router combination, simply unplug the power to that device). Leave them unplugged for a full 30 seconds, plug them back in and restart your computer. When your computer fully reboots, check your wireless signal strength to see if it has improved. If it has not, further troubleshooting is required. Move your computer closer to your router, or your router closer to your computer. Wireless routers do not have unlimited range. One reason your computer may be getting a weak signal strength from your wireless network could be because your computer is simply outside of the router's range. Typically, ISPs (Internet Service Providers) will install your modem in one specific location in the house and the modem will not work at other locations, so moving the modem or modem/router combination may not be a possibility. If this is the case, you may need to move the computer to a location that is within the range of the wireless router's broadcast. If you still get poor signal strength, your router may be experiencing a malfunction. Contact the technical support department of your router manufacturer. Router malfunctions often are not the result of a bad or broken router, but of something much simpler, such as the router's needing a firmware upgrade or an incorrect setting on the router's internal setup. If your router manufacturer is unable to improve your wireless signal strength, it may be time to purchase a new router. Purchase a new router. Wireless routers are priced in part based on how widely their wireless signal broadcasts (in other words, the more expensive the router you buy, the larger a wireless signal the router will broadcast). Included in the packaging of each wireless router is the approximated range, in square footage, of that router's wireless network. A good rule of thumb is to know the square footage of your house and buy a router that can accommodate that square footage. That way, as long as the router is functioning properly, you will have strong wireless signal strength throughout your entire home.
Mar 01, 2013 | Samsung 19628 NP300V5A-A0AUS NP300V5AI
My linksys router WRT120N is having power light stable but no other lights are neither blinking nor stable!!! need your help
At power up the device runs a self test, it take a minute or so. What is it connected to, what is sending the signal, a cable modem, DSL, etc.? If you have cables runing from the Cable modem or whatever, to the linksys, try another cable, OR, reboot the cable modem, unplug, remove battery, if applicable, remove power from the WRT120N, Insert battery into the modem, plug in, wait for the self test, plug in the Linksys, wait for self test. Connect a ethernet cable from the linksys to the computer. Does it connect? Try to connect wirelessly, Does it connect? Is the Linksys secured with a passcode? If you push the reset button , and hold for a minute, in the rear of the device, it will reset the Linksys to default settings. Try to connect. Did the Linksys work at one time? Did you set it up? Is it on a surge protector? Have you had any Electrical storms? Surges? It may be bad, hard to say until you verify all the steps. Who is your internet provider? Have you verified that they are sending a signal? Comcast will verify ,by phone, that the signal is good and run check on the cable modem.
Nov 22, 2012 | Cisco - Linksys Wireless-n Home Router -...
Low connectivity for d link 524 airplus g
Things That Affect Wireless Router Signals1. Many wireless routers are using the same wirelesschannel. Many manufacturers choose channel 6 as the default.2. Analogue video senders used to send audio and video toother TVs in the home.3. Microwave ovens emit interference in the 2.4GHz band.4. Wireless speakers and console controllers can causeinterference with the wireless router.5. Bluetooth devices, newer Bluetooth devices can jump todifferent frequencies if there is a connection problem.6. Power cables located near the wireless router can causedrop outs and speed reduction.7. Fish tanks will cause massive Wi-Fi shadow on the otherside of the tank from the wireless router. 8. Depending upon the location of large mirrors will reflectwireless signal away your computer.9. Building materials will block wireless signals such asplasterboards with metal foil, reinforced concrete walls and floors. Alsoobjects near the wireless router such as metal filing cabinets and otherelectrical appliances. 10. Blinking Christmas lights can reduce Wi-Fi performanceby 25% when it is close to the wireless router.
May 25, 2012 | D-Link AirPlus G DI-524 Wireless Router -...
I have a Linksys E1000 wireless router. It has been working fine. The power cord it is on was unplugged briefly last night. Now when I plug it back in, all the blue lights are flashing and I can't get...
have you tryed turning off computer, router, and modem if you have one. then unplug all connections from router (phone line, ethernet net cable and power cord). Then wait 2 min then plug all back in, and turn on modem, router, then computer. We lost power yesterday for 3 hrs and I needed to actually turn in all off and unplug power cords then turn it all back on to rest and reboot them to get them working properly. Hope it helps.
Sep 25, 2011 | Cisco Linksys E1000 WirelessN Broadband...
Hi, good afternoon! i am facing problem with my wireless connection. how can i connect on it? can you assist me?
Are you getting an error when you try to connect?
If you were able to connect w/ the same device before, unplug any other device that uses radio signal such as cordless phones.
Unplug your wireless router for 1 minute and plug it back in. Wait for another 2 minutes and connect again.
Aug 02, 2011 | Siemens Efficient Networks SpeedStream...
Netgear software, picks up wireless network then loses connection moments later
Netgear generally functions well. You may simply need to adjust the location of the router. Check the signal strength when you do have a signal. You may be losing a signal intermittently because the signal is weak. If your signal is "good" or better and the signal is lost without apparent reason, there could be a malfunction with the router itself. Check the router when the signal is lost and ensure the power light is on and the connection light is on.
If your signal is weak and you lose it intermittently, adjust the location of the router
If your signal is strong and you lose it intermittently, you may be experiencing a connection problem at the source or the power may be cutting out at the modem. The more likely answer is the source signal interruption. It is rare for a power supply to go bad in those.
Check the source connection INTO the router.
You can also reset the router. You'll want to unplug everything. Unplug the power supply from the wall AND from the modem and leave it unplugged for at least 2 minutes. There may also be a very small recessed reset button (the kind that you need to use the end of a paperclip to press). Press and hold that for 10-30 seconds to reset while it's still plugged in.
When you plug everything back in, plug the power in first (to the wall and modem), then connect the source cable. Wait until you have a signal confirmation light, then try to connect with your computer.
Last but not least, the connection problem could be with your computer. Try pluging directly into the source if possible and see how that works. Then try just moving close to the wireless modem and see how the signal strength is and if you lose the signal the same way. If there is a switch on your computer to turn on the wireless feature, make sure it's all the way on. Sometimes these are kind of stuck between 'on' and 'off' and that can cause problems.
I hope one of these suggestions helps you!
Jan 12, 2010 | NetGear RangeMax WPN824 Wireless Router...
Intermittent or slow internet connection
Go here and upgrade your Router's Firmware - you will need to choose your location on the site at top left hand corner of the screen
http://www.linksysbycisco.com/UK/en/support
Feb 27, 2009 | Linksys Wireless-G Broadband Router
Linksys Power cut problem
With regard to power cuts, i highly suggests you to buy a UPS (Uninterruptable Power Supply) to prevent further damage to your router. You can simply reconfigure the wireless settings of the router by accessing the router's Setup Page. Go to http://192.168.1.1, go to wireless tab and you can change the network name as well as enable the wireless security.
Jan 19, 2009 | Linksys Wireless-G WRT54G Router
Wireless router not working
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
if you are still having trouble configuring your device, call supportrix and use supportcall as your promo code for 1 free technical support.
Jun 10, 2008 | Linksys Wireless-G WRT54G Router
D-Link AirPlus DI-524 Wireless Router Logo
32 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
