How long after an operation can I use my Face and Lift toner ? I had a back operation seven weeks agoe.
  • 50 Answers
I don't think you are posting you question in the right category..
Posted on May 23, 2011
Drops toner inside machine. I just changed yellow high yield toner cartridge two weeks ago and it just went out. Changed cartridge and their was yellow toner inside machine. HELP
It sounds as if the toner has leaked, maybe it was cracked or seated incorrectly. Toner is so fine that if you use a standard vacuum cleaner the toner may just fly out of the back.
It's still worth trying to vacuum out the spilt toner. Remove all other cartridges first
Inspect the Yellow cartridge for damage to determine if it was that or the printer at fault.
May 18, 2011 | Computers & Internet
How do i get the toner cartridge out of my brother HL-2170W printer?
Hi Lorne-
Here's the step in pulling out the cartridge of your printer:
1. Open the front of the face.
2. Pull out the catridge and drum assembly carefully.
3. Thier should be a yellow tab on the toner catridge press down and the lift the toner catridge out.
4. Replace cartridge and reseat in printer.
Hope this helps,
Good Luck!
Mar 10, 2011 | Office Equipment & Supplies
Brother 2040 yellow toner light on & won't print. Toner just replaced 8 weeks ago. Printer purchased 6 months ago.
You have a one year warranty with Brother if you need repair. You might shake the toner, or put a small electrical tape over the little round windows on the toner cart. to use the rest of the toner, and press the go button 3 times to print the report that tells you how many prints you've made, you could just be out of toner again...
Feb 03, 2010 | Brother HL-2040 Laser Printer
Toner cartridge problem
When you remove the drum & toner unit from the machine, there is a small round window where a beam beams through the toner. block it with a piece of paper. Put them back and print again.
Dec 08, 2009 | Brother MFC-7440N Laser Printer
The battery was changed two weeks ago. A week
Greg it sounds like you should take your watch to a propper watchmaker. (qualified) Most jewellers are not well educated in regard to watches and their servicing.
Jul 16, 2009 | Watches
My Phaser 6120 leaves light lines across the face
Lift out imaging unit and look down and back toward you, may need flash light, and you will see a 5" x 1/2" piece of glass. Carefully wipe it with soft cloth. Toner gets on this glass and creates the streaks. Often means a bad toner cartridge is leaking toner. Ron
Jun 28, 2009 | Xerox Phaser 6120N Printer
Remove toner catridge from Brother 2170W
Open the front of the face. Pull out the catridge and drum assembly carefully. Thier should be a yellow tab on the toner catridge press down and the lift the toner catridge out. Replace and reseat in printer.
Jun 04, 2009 | Brother HL-2170W Laser Printer
My xbox 360 just grinded my brand new Rockband 2 disc.
The Xbox 360 is known for this. I would contact Microsoft as soon as possible.
Assistance by phone seven days a week.
1-800-4MY-XBOX
International (direct dial to U.S.): 425-635-7180
Hearing Impaired (TDD device): 1-866-740-9269 or 425-635-7102 Hours of operation (every day):
9:00 A.M. to 1:00 A.M. Eastern Time
6:00 A.M. to 10:00 P.M. Pacific Time
Jan 02, 2009 | Microsoft Xbox 360 Console
Xerox phaser 7300 toner cartridge problems
Sometimes on this machine as there is a lot of loose toner around it can cover over the sensors in the machine, what I would advise is to remove all the toner cartridges and check for the copper contacts on both the machine and under the imagining unit (which the toner is placed in). Once you have cleaned that away slowly close the lid and reboot the machine and it should return to normal. Its just toner getting caught up in the sensors. Follow the instructions below, when you remove the unit, lift it over your head to find the copper contacts and clean them, be careful not to spill toner everywhere. Good luck!
Reseating the imaging unit
    Remove the toner cartridge:
  1. Open the top cover.
    caution_image88x30.gif The imaging units are sensitive to light. Do not expose the imaging units to light any longer than necessary to remove it and cover it. Failure to follow these instructions may damage the imaging units.
  2. Identify the color of the toner cartridge to be replaced (Cyan, Magenta, Yellow or Black).
  3. Move the orange lever on the toner cartridge to the right so that it unlocks.
  4. Lift on the back side of the toner cartridge first, then guide the cartridge out of the printer.
  5. Set the toner cartridge on paper to avoid any toner spilling.
    Reseat the imaging unit:
  6. Lift the imaging unit straight up out of the printer.
  7. Line up the guide pins with the printer's frame and lower the imaging unit back into the printer.
    Reinstall the toner cartridge:
  8. Install the toner cartridge by guiding the front onto the new imaging unit first then lowering the back.
  9. Move the orange lever on the toner cartridge to the left so it locks.
  10. Clean the LEDs with the supplied wipe.
  11. Close the top cover.
Sep 06, 2008 | Xerox Phaser 7300DN Laser Printer
Computers & Internet Logo
11 people viewed this question
David Payne
David Payne
