Question about Zebra TLP 2844-Z Thermal Label Printer
HI We are using Zebra LP 2844 Printer (label Printer) we are able to print test lable by printer properties .Howver from VB code sending command to Zebra and we are not getting the print.For serial port we are using mscomm control in VB getting buffercount =0 after send data to serial port. is there any setting require for printer properties.?why we are unable to send lable print command to serial port when connected to Zebra LP2844 Printer.
SOURCE: How can I connect Zebra LP2844-Z to AS/400 as device ?
what interface are you using? also the 2844Z is a pagemode only printer so you need to send ZPL commands to the printer for it to work.
Posted on Nov 21, 2007
SOURCE: label printer
Try reseting the auto gap detection.
http://www.fixya.com/support/p257130-zebra_lp_2844_thermal_printer/manual-19245/page-15
Posted on Mar 30, 2008
SOURCE: Zebra LP2844 printer prints garbage
Sounds like you might be using a bad driver, or the printer is in dump mode.
Try hitting the green button and see if it says exiting dump.
If still having trouble, inside the printer it tells you that if you are having printing trouble:
  1. turn off the printer
  2. Hold down the feed button
  3. turn on the printer and at the third red flash release the feed button
  4. it will then feed some pagessome info and ask you to hit feed again to exit dump
  5. hit feed again and it will say exiting dump
This process re-reads the label length (so only do it with the labels you want to use in, or it will waste labels until you do it again with those in it) - but I'm suggesting it only because it enters and exits dump mode (which I have read can cause the garbage when you try to print).
Posted on Mar 11, 2009
  • 31 Answers
SOURCE: ZEBRA LP 2844 PRINTING PROBLEM IN USPS SHIPPING ASSISTANT
Are you sure that the page size is wrong, or are you just guessing because of the way that the label is printing? I would uninstall the driver - delete the printer from printers and faxes and remove the driver from Server Properties (in the file drop down in Printers and Faxes). Go to ups.zebra.com/ctp and get the latest driver - you have to have the UPS version of the driver in order to support pass-through printing. Go into your UPS Ship Asst application and make sure that the generic thermal is not checked.
Posted on Jan 31, 2010
davevipul197
  • 186 Answers
SOURCE: We are using zebra barcode printer TLP 2844 model
Please follow this link for download a driver http://www.zebra.com/id/zebra/na/en/index/products/printers/desktop/tlp2844.html and you should open youtube.com and type your question in search option then after you can see there are many video so you click on one by one video clip and learn how can you solve your problem?
thanking you
davevipul197
Posted on Dec 20, 2010
I have Zebra LP2844 printer and Windows Vista OS. I have installed Zebra LP2844 and ZDesigner LP 2844 drivers and I want to use ELP to print text, barcode etc. Printer is connected to computer via USB. How...
To send text to printer in dos command you should first install a driver from
www.seagullscientific.com
then in the properties you can use send file to printer.
To send the files from command :
Check if the program ssdal.exe has been correctly installed.
to have help use ssdel help send at dos prompt
to send the file
ssdal send filename printername should do the trick
hope it helps
Aug 01, 2011 | Zebra LP 2844 Thermal Printer
Long pause between labels
Go into printer properties then to the ports tab. Uncheck "enable bidirectional support" This seems to be defaulted to on in the latest drivers and creates a delay in printing while the printer waits to see if it gets a response back from the application printing. This works for 2844 and 2824.
Jun 11, 2010 | Zebra LP 2844 Thermal Printer
I want to print 2X4 labels without skipping 2 labels each time
obviously its your vb software. try using a real label program and end this issue.
Sep 05, 2017 | Zebra LP 2844 Thermal Printer
Zebra TLP 2844
Call BarcodeWarehouse.biz 1-888-422-9249 - they offer free tech support on Zebra printers even if you didnt buy it from them. They helped me fix mine in about 3 minutes when I had given up was calling to buy a new printer!
Jan 28, 2009 | Zebra LP 2844 Thermal Printer
Zebra TLP 2844-Z Test page print within Win XP
This printer requires special software to print labels with. It uses a unique PCL language to work with. Thats why when you use these printers with Fedex or UPS software, it typically downloads forms first before working.
Zebra used to see a label designer program to work with it. You might want to check with them to see if they still carry it.
Jul 28, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Help me with Zebra TLP 2844
The printer only understands EPL code. (Eltron Programming Language) If you are trying to print text from DOS it wont understand (interpret) the txt codes.
To verify that the printer is working.
Open a DOS box, start the dos editor. Type Edit. Dos editor will open.
Type a single capital letter U. and print. Send to printer. The printer will print a configuration label.
EPL code to reset printer is
^default.
If you want to print a text file. use the Zebra Universal Driver. Zebra TLP2844. Open any windows application. E,G, Notepad. type text and send it to printer. Print as normal.
Jul 24, 2008 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 label printer
I'm having the same problem and got the same result when trying the manual calibration on the 1st page...
Jul 14, 2008 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 fuzzy print
1. Clean the print head with cleaning pen.
2. Adjust print speed/darkness in software.
3. Check the media and verify that print surface is facing up.
4. Check that correct thermal media is in use.
Apr 23, 2008 | Zebra LP 2844 Thermal Printer
Zebra TLP 2844-Z Thermal Label Printer Logo
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
