Change time & date on the victor 1530-5 adding machine
How do I change the date & time on this machine?
thank you for your help
  • Anonymous Sep 09, 2008
    how do you change time and date on calculator
  • Jesus4evermy Oct 26, 2008
    I am able to set the time by pressing the "Time" key and holding it tdown and then pressing the time key again. But, it won't work that way for changing the date!
    sh
I recently solved this issue with my calculator
Press and hold the time key when the date is dispalyed. When the display flashes enter the date as a six digit date (example 110608 for November 6, 2008) Time needs to be entered in military time when changing time.
Posted on Nov 06, 2008
How do you set the date on a Victor 1560-6 Calculator. I held down the date button on the unit and the number is flashing. I entered 08232010 for Aug 23rd, 2010 and I am not sure of the sequence to lock...
Immediately after entering the year part of the date, the display should revert back to a blinking first digit (in this case, the 0 to the left of the 8) while retianing all the following digits just entered. Simply press the Time/Date key again to lock in that date and stop the blinking. The same process applies for the time.
To clear the display of the time/date when using the calculator to actually compute something, press the C or CE button. This will result in a 0 appearing on the display. The unit is now ready for data entry.
Aug 24, 2010 | Victor 1560-6 Calculator
How much would a water pump cost for a 1992 audi s100
here is a list from autozone depending on the engine model.
Warranty: 90 DAY REPLACEMENT IF DEFECTIVE $192.99 Part No. 8811 Warranty: 90 DAY REPLACEMENT IF DEFECTIVE $195.99
Edelbrock Victor Series Water Pumpadd_to_bag.png CI_ItemIDs[itemCounter] = '17140131_true_298221_1992|Audi|100 S'; itemCounter = itemCounter + 1; 17140139_edb_8851_pri_thmb.jpg Edelbrock Victor Series Water PumpPart No. 8851 Warranty: 90 DAY REPLACEMENT IF DEFECTIVE $203.29
Edelbrock Victor Series Water Pumpadd_to_bag.png CI_ItemIDs[itemCounter] = '17140139_true_298221_1992|Audi|100 S'; itemCounter = itemCounter + 1; 17140523_edb_8805_pri_thmb.jpg Edelbrock Victor Series Water PumpPart No. 8805 Warranty: 90 DAY REPLACEMENT IF DEFECTIVE $206.39
Apr 14, 2010 | 1992 Audi 100
Adding machine can't set date & time. When I press the = sign date starts flashing I can change it but I cannot lock it in. When I press the date time button it reverts to the old time.
My machine goes this way-
Hit time/date button.
then enter in date (ie) 11.16.2009--INCLUDE DECIMAL!!!
Then hit time/date button again,
I am still working on the time issue, I just cant seem to remeber, I know it is done off military time.
Oct 31, 2009 | Canon P170-DH Calculator
I can't seem to do simple subtraction with my Victor 1208-2. When I subtract say 5-4, I get a negative 9. Is there a setting or do I need to press something different to get simple subtraction to work?
When you want to complete a problem on an adding machine, such as "7 - 3," you would not key in "7," then the subtraction sign, then "3" and then an equal sign. If you do, then you will get an answer of "-4," and you know that is not the correct answer. Again, you have to think like an accountant when you are working with your adding machine. To figure this subtraction problem on an adding machine, you would need to key in "7," the addition sign, "3" and then the subtraction sign; you would get the answer of 4. You are actually working the problem as "7 + (-3)." This would be true on most modern day machines. In order to subtract, you have to add the negative number.
Sep 25, 2009 | Victor 1208-2 Calculator
Is there a way to get the time/day from being displayed? I just want 0.00 on the display. Also, I can get the time correct, but not the date. This machine does not have a time/date button, just a time...
press the CA button to get your time/day from being displayed. For your date... whenever you press the time button to edit your time, press it again & your date shouold come up. the time/date button are both done with the TIME key.
Jul 30, 2009 | Victor 1260-2 Calculator
Pitney bowes 1530 / INCOMING fax date/time stamp
For the UF-595 here's how you turn the fax stamp on:
Function + 7 + copy/set for enter
scroll to option 4 + copy/set
Hit 04 + copy/set and enter number 2 to turn the fax stamp on. 1 turns it off.
Scroll to or enter 28 and choose 2 to turn the fax stamp on for faxes stored in memory for later use.
You hit the "clear" button to wipe out the current number before you enter 2 or 1 for the new entry.
Jan 08, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
Showing incorrect date - how do I change the date?
Please change the Leithium battery fixed inside your fax machine, usually this the problem.
If the Date time is running in different date & time.
Please press Menu, then scrolle left of right arrow key. When you find set Date/Time enter the key mentioned in the Display key and change to your date & time.
After some time see if the date/time working normally. If not change the above mentioned battery.
regards.
Jan 07, 2008 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
1,115 people viewed this question
jasbo
jasbo
