Question about Gateway 7330GZ Notebook
A techie told me that the reason my Gateway 7330GZ notebook will not power on is a faulty power distribution IC on the motherboard. The part is impossible to find in my part of the globe (Nairobi, Kenya) Is this a replaceable part or must I purchase a motherboard?
  • Gateway Master
  • 32,281 Answers
You need to replace the motherboard. This may not be a cost effective solution.
It may be better to put your money towards a new laptop which will be faster and most likely slightly more than the cost of repairing the Gateway.
You can remove the hard disk from the Gateway and put it into an USB hard drive adapter case and then use it as an external USB hard drive for backups and data transfer.
Posted on May 23, 2011
Testimonial: "Thanks Geekman! I will certainly heed your advice on this! I feel like you have saved me a lot of trouble. "
ON a Gateway 7330gz why would it power up the moment you plug in the A/C adapter, yet not give any Video, and ignore the power button?
It seems that your AC adapter has no output. To confirm test it using the multitester. Check also the power cord for internal open due to frequent bending and pulling. Check the internal fuse of AC Adapter sometimes it fails due to power surge. If you confirmed that this is faulty you can check ebay.com, shopjimmy.com for replacement or on your local electronics supply.
Hope it may help you.
Have a nice day!
Thanks for using Fixya.
Feb 10, 2011 | Gateway 7330GZ (890552601318) PC Notebook
Laptop will not come on. Indicates that it is connected to power source although it is loose. What should I do? Is it the motherboard or the d/c adapter? I have a Gateway 7330 GZ.
Try another 19volts adapter. If problem still the same and the laptop not powering-on, there's something wrong with the motherboard circuit and not the DC JACK cause it indicates that you connect an adapter.
Apr 05, 2010 | Gateway 7330GZ Notebook
Gateway 7330gz will only run few seconds then turn off
Remove the battery and run off of the A/C power adapter without the battery installed.
If it works, the battery is just discharged too much. After Windows settles, insert the battery and let it charge.
Sep 09, 2009 | Gateway 7330GZ Notebook
I need to replace the backlight on my laptop
Majority of the time it's NOT the backlight, it's the inverter. Who told you that it was the backlight specifically?
Virtually every lcd is the same procedure. Just remove the screws around the lcd, some are hidden under the rubbers, and CAREFULLY pry the plastic surrounding the lcd. It's basically common sense. Just take it apart....CAREFULLY.
That's about it, really.
May 11, 2009 | Gateway 7330GZ Notebook
Screen brightness often flickers
Your problem could be a faulty backlighting panel or the power connector for the backlight needs reseating.
There are two connectors on the LCD that are connected to the motherboard, one for the video signal and the other for the backlight power supply, reseat this connector and hopefully your problem will be fixed.
Dec 31, 2008 | Gateway 7330GZ Notebook
7330GZ won't turn on
I had the same thing happen to my computer 7330 gz and all the trouble was caused by a faulty ac adaptor. Battery wasn't holding a charge either because it's 3 years old and worthless. I got a replacement adapter at best buy for 100 buck and it's universal. Fixed it up just fine and now I'm sharing my solution with you!
Nov 19, 2008 | Gateway 7330GZ Notebook
Notebook Gateway 7330GZ won't boot
Hm...That sounds like either the motherboard is dying/dead or a device is (such as the hard drive). I would suggest removing one piece at a time and see if you can get past that screen. The most annoying would be if it is the DVD drive since it's probably the most difficult device to remove from the laptop. (If memory serves it involves removing a certain screw from the bottom and then getting under the keyboard so you can push it out).
Do you have a second stick of RAM installed? Mine died a while ago and caused real heck with my 7330GZ.
Nov 16, 2008 | Gateway 7330GZ Notebook
Power jack repalcement Gateway 7330GZ Notebook
you have options....#1 send it out to gateway for an arm and a leg...(i have the same model and had the same problem), #2 find a local computer repair store...they will most likely charge about 30 for the part.(that's what i was charged + 60 an hour for labor took 2 hours...) or #3 do it yourself, if you can solder then i can talk you through most of the dis assembly..plus you can get the part remarkably cheaper
Nov 08, 2008 | Gateway 7330GZ Notebook
Numbers and backspace on Gateway 7330GZ not working
You might check and clean the keyboard connection to the motherboard. However, usually this indicates keyboard failure. It's most likely that you're have to replace the keyboard.
Aug 21, 2008 | Gateway 7330GZ Notebook
Screen problems
Try the power save options.
Nov 13, 2007 | Gateway 7330GZ Notebook
Gateway 7330GZ Notebook Logo
144 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
