My CPU has some problem with video transmitting to the Monitor, Monitor is fine I checked with my friend's CPU.. My system goes to safe mode display. Do you have a solution for this?
  • 50 Answers
That's probably related to the GPU and not the CPU.. Try to use your graphics card on another pc and see if it works
Posted on May 23, 2011
Monitor with lines and flickering but monitor is fine
It might have been caused by an outdated video card driver. To check that, go to safe mode and observe if you experience the same issue.
To go to safe mode, do the following:
Restart your computer and tap F8 until you see safe mode. Use the arrow keys to highlight safe mode and press enter. Once you're in, observe if you experience the same problem. If you still have the problem, then it's the connection between the monitor and the motherboard which causing the problem. You need to reset the connection or get it checked by a technician.
If there are no problems inside safe mode, then update the video card driver. You can also automate the updating mechanism of your computer's drivers to make sure that you won't be getting any problem in the future. You can use RadarSync to automate the updates.
I hope this helps!
David
Feb 24, 2013 | Acer Computers & Internet
My problem is my computer cannot open the display in the screen is "check the video cable"
Good Day Efren!
When you turn on your PC and your monitor displays "Check the Video Cable", it means that there is no signal coming out from the video card going to the monitor.
It just gives you the direction to check if the VGA cable is properly connected to the video card and to the monitor. There are two screws that need to be fixed to both ends of the cable to ensure its connection. You can also try other VGA cable to make sure that the one you are using is not faulty.
After you have made sure VGA connection is secured and restarting the PC did not fix it, the next suggestion might fix it.
Turn off your PC and unplug it. Disconnect VGA cable from the video card and open the casing cover. Disconnect the video card from the motherboard. Using a clean clothe moistened with alcohol, gently wipe the contact surface of the video card. Reseat the video card properly to the motherboard. Return the casing cover and connect the VGA cable.
Restart the PC and see if that fix the problem.
Good Luck Efren!
You can give some ratings if this fix your problem.
Thank you for asking Fixya.
Jun 09, 2011 | Computers & Internet
Hi I wonder if you can help me. I have the flatron L1918S monitor and it was working fine yesterday, however today when i turned on the pc, the monitor flashed the green light on and then goes into power...
When after power up the computer press num lock key if num lock led is flash on and off when you press num lock key then your cpu is working fine.But if it stay constant then open cpu cabinet cover then reconnect RAM memory and processor and it's fan pull cmos cell from motherboard for 10 minutes then reconnect it then check.Make sure motherboard is not ground with cabinet. If num lock led is on and off then when you power up the computer press F8 key 5 to 6 times so you can see safe mode and other menu then enter in "Enable vga mode" then go to display property ->settings change screen resolution to 1024*768 then apply and ok. then check. If everything are fine in cpu then your monitor need repairing. Let me know if you need further assistance. Thanks for using FixYa.
Aug 25, 2010 | LG Flatron L1919S LCD Monitor
Out of range no display
Try pressing F8 when starting the PC, but BEFORE Windows starts loading. In the menu, select Safe Mode. Windows now startd with a very low resolution. You can right0click your desktop, select properties, then the Settings tab, and drag the reslution slider all the way to the left in Windows XP, or for Vista and 7, rightclick the desktop, sleect the lowest option, go to screen settings, and drag the slider all the way to the left.
After that, click OK, then restart your PC. Now you can try to increase the resolution step by step, and if it goes wrong start in safe mode and set it back a step. That way you will achieve the highest possible resolutioon (and better image quality)
I hope this helps,
Yannick.
Dec 07, 2009 | Princeton Digital VL173 Monitor
I have a blank screen on my HPf1905 monitor. I have a HPm7330n computer. How do I know if its the monitor or the video card? Monitor shows a message no input signal,then goes to sleep mode.
if the message you recieve is no input signal if only means that you have a problem with your video card, the monitor is fine but you need to have your video card check
Nov 21, 2009 | Computers & Internet
Dell Inspiron 1525 Laptop..the screen goes almost black after 5 minutes.
The screen goes black while in normal mode right? So try to boot in safe mode (power on then keep tapping F8 then select safe mode). Check if still happens in safe mode.
If screen does not goes black in safe mode it means there might be a software or driver causes problem when running in normal mode. You can try the following (update your anti virus software then run a full system scan, uninstall the video driver then download and install the latest one, uninstall any previous windows update or you can system restore to the time when it was working fine).
If the screen goes black even in safe mode they try connecting the laptop to an external monitor if still goes black, if yes then absolutely no issues with the LCD panel. You can try (uninstall and reinstall the video driver if still persist then this might end up replacing video card or motherboard, but before doing that update the BIOS first).
If does not goes black in ext monitor then the LCD panel might causes the problem. Reseat the LCD cable or inverter if you can.
Oct 22, 2009 | Dell Inspiron 1525 Laptop
Monitor goes blank after seeing XP during boot up.
did u replace the video card with the same kind of model ? i guess yes ... when system starts hit the f8 key and than go in to safe mode ... mouse wont work so use arrow on the keyboard .. and in the safe mode just log in to admin account if available or login to ur account and see if that still happens .. and if it doesnt ... remove the drivers for the graphic card from add and remove programs and restart the system and go in the normal mode and than install the drivers again ... and if the display disappears in the safe mode or u have install a different graphic card than ... reseat the memory cards and that should resolve the issue .... if that doesnt work out when the system starts hit f1 and stay on the BIOS screen for 30 mins if the system doesnt loose display than u need to reinstall OS ... that will surely work out ... the resolutions given above if u follow them correctly u will have a working system in no time
Feb 07, 2009 | HP Pavilion a305w (DM181AR) PC Desktop
No VGA signal on AOpen EPC945-m8
From your description, it sounds like once Windows starts it's switching to a video mode your monitor doesn't support. Try starting in safe mode or in vga mode, then check your desktop settings. Set the monitor resolution for 800X600 or 1024X768 at 60Hz refresh and restart. All recent monitors will support those rates, so you'll be able to get back to Windows.
Jan 24, 2009 | AOpen EPC945-m8 (95EP4596B1) Barebone
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
