Question about Vivendi Universal Jurassic Park: Operation Genesis for Windows
Windowed mode for JPOG failed to work via the compatibility mode or the "options.ini" file. Currently running on a toshiba laptop with vista installed if that helps.
Windows update stops working, check for updates failed
I've found that re-registering the dlls has solved quite a lot of windows update issues. have you tried this?
see method 5 here:
http://support.microsoft.com/kb/326253
Dec 22, 2012 | Toshiba Satellite X205 Notebook
Yugioh power of chaos windows 7 problem
1. Right click on the Yugi, Kaiba, or Joey icon, go to properties, compatibility and check the "Disable desktop composition" box.
2. Once you're in game, go to options, drag the volume up and check "full screen".
This will automatically be applied to the other two games.
Jul 09, 2012 | Video Game Consoles & Games
My toshiba will not boot up
Restart laptop, press F8 to enter the Windows Advanced Options Menu. There are many options, try going to the computer via:
1. Last Known Good Configuration (advanced) - enter. If it fails to enter windows, restart - F8 - select
2. Directory Services Restore Mode - enter. If it fails to enter windows, restart - F8 - select
3. Debugging mode - enter.
Dec 04, 2011 | Toshiba Computers & Internet
When I open some games I have downloaded, "auto processing" shows and then the game is moved to the far right of the monitor and I am unable to play.
A common cause of this problem is that the monitor may not be able to handle the graphic requirements of the game.
  • Try running the game in windowed mode first,
  • To do this, find the program files folder for the game you are trying to run, right click on the icon for the game in that folder, click properties, compatibility, the select windowed mode.
If that still has the same problem, try doing the above again but in 256 colors.
Hope that helps at all.
Jul 18, 2011 | Computers & Internet
My ASUS UX50 laptop has problems starting windows. Every time I turn it on it says "windows failed to start" and gives me the option of choosing safe mode, safe mode w/ command prompt, last known...
Seems like there are Operating System files that got corrupted. Try to boot the PC into the Windows OS setup disk. Run the setup, choose the currently installed Operating System then select Repair. For more details please check this link - click here
Hope this help. Goodluck!
Mar 28, 2011 | ASUS UX50VRMSX05 Notebook
Try to run MS-DOS program in XP SP3 Laptop hp. Writing: this program must be run under Win32
Verify if the file is not corrupted.
If you are sure that the file works, try to adjust the compatibility mode. You can right click the file and you should see some options on lowering the compatibility mode.
Feb 24, 2011 | Computers & Internet
I play crossfire and i play one or 2 games and first i was like OK but every time i logging me out and shows a x trap code error [01-0400-00000000-706]
try to turn ur antivirus off and then run the game,if this doesn't work follow these steps:
in run command type dxdiag and then press enter
click on display tab and disable agp acceleration,then click ok.
and if the game has option to run in windowed mode then run it in windowed mode.
Mar 28, 2010 | Dell Dimension 2400 PC Desktop
What is ini file error: app path data fail? my laptop wont start
REstart your computer and keep pressing F8 till you get the option to boot in safe mode. IF this works then it means a driver or some piece of hardware you added is conflicting. If it still wont boot i would think bad RAM.
Dec 14, 2008 | Acer Aspire 3690-2196 Notebook
Vivendi Universal Jurassic Park: Operation Genesis for Windows Logo
382 people viewed this question
Top Vivendi Universal Video Game Consoles & Games Experts
James Wishart
Ankit Chandel
Ankit Chandel
Hanzu
Are you a Vivendi Universal Video Game Console and Game Expert? Answer questions, earn points and help others
