Question about Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite P200 doesn't boot
When the laptop was booting, my kid pressed some keys, and then the laptop screen stays black, it didn't boot at all. Power LCD light is on, fan is running, but hard-drive light is off and no hard-drive reading activity.
Press start key and hold, it shut down. Start again, the same thing happends. Hard-drive light on once and then off forever. Black screen, power light on, hard-drive light off.
  • 3 Answers
Try pressing FN/F5 keys simultaneously, or the key that toggles internal/external Display. Look for the double screen Icons on the keys.
Tap the Pause Key.
Restart and press and hold F8 key when Toshiba logo appears. When the boot Menu appears, select Last Known Good Configuration.
If all else fails ther should be a reset button on the side of the LT. Consult owners Manual for location
Posted on Aug 16, 2008
SOURCE:
Why Dell inspiron 6400 LCD screen goes blank when I unplug the ac adapter from laptop?
  1. Restart the computer.
  2. As the computer boots, press <F12>
  3. when the Dell Splash Screen appears.
  4. At the One Time Boot menu, press the <Down> arrow key to highlight Diagnostics and press <enter>
  5. A graphical menu listing all discovered devices in the system is now displayed and the express diagnostics should run (Takes about 4 minutes).
This will test the hardware on your computer.
I am thinking it could be the battery but this is just to be sure.
Aug 06, 2014 | Dell Inspiron Computers & Internet
R15d notebook screen black, fans running
either your backlight has failed or you have hit one of the function keys which selects external monitor- can you connect it to an external monitor to see what happens?
May 21, 2014 | Microsoft Computers & Internet
Toshiba Satellite not Booting (No post Screen)
you can't boot on safe mode under F8 function key?
Mar 30, 2014 | Computers & Internet
Laptop wont boot up
it sounds like the flexcable of your laptop lcd are not working.. so go to nearest pc store and try to replace it..
Aug 13, 2012 | Compaq Presario Computers & Internet
How can i get my sylvania netbook to work when i turn it on and it wont do anything all it does is stay at a black screen? Need help with my sylvania computer problems
When you plug in the power cord do you see any lights either on the power cord's adapter or on the computer that indicates that the power cord is plugged in? If not, your power cord might be bad. You might have been running off your battery for the last time you used it and since the power cord was bad it was not charging your battery so it eventually drained all battery power.
When you turn it on do you hear any fans running, any hard drive running, cd drive clicks once and you see the light on the cd drawer come on for a second or two, lights anywhere on the computer? If so these are signs that the computer is trying to boot. If not you might have a motherboard issue.
Static Charge Buildup can also cause the computer not to boot. Remove the power cord and battery from the laptop. Press and hold the power button for 30 seconds then put the power cord back in (leave the battery out) and try to reboot. If it boots, you had a static charge buildup and can put the battery back in now.
Is the computer actually up and running but the screen is black? If so take a flashlight and shine it on the black screen. If you can bearly see the icons on the desktop that means your lcd inverter is bad and needs to be replaced.
If the computer is actually up and running but the screen is black, try hooking an external monitor to the laptop. You can use any type of monitor, even the big fat crt monitors as long as it has a vga cable to plug into the laptops vga port. You might have to press the FN (Function Key) and one of the F1 thru F12 function keys to get the image to display. Normally the correct F1 thru F12 key will have CRT/LCD written on it or it will have an icon of a display. Press and Hold the FN key then hit the correct F1 thru F12 Key to display the image on the external monitor. If it shows, that means your Video Card is ok.
If the computer is on and running but the screen is black, you don't see any icons on the desktop when you use a flashlight then your lcd screen will probably need to be replaced. It might be something as simple as the lCD Cable is loose or just needs reseated (pulled aloose then plugged back).
You'll have to take the screen apart to get to the lcd inverter and the lcd cables.
Mar 24, 2012 | Sylvania G-Netbook
No display after reboot windows
If it seems like your system is running whereas you hear fans running, hear the hard drive running, see lights, heard the hard drive click during bootup, but there is nothing on the lcd screen then try the following:
1) Try hooking a external monitor to your laptop. It can be any type of monitor even one of the old style fat crt monitors as long as it has a vga cable to connect to the laptop. There is a sequence of keys you might have to hit to get the display to show on the external. Most times you hit the FN (Function key) and hold it while you hit the corresponding F1 thru F12 key that is for display. Usually the correct key will say CRT/LCD or it might have a display icon on it. If the image displays on the external monitor that means the video card is good.
2). Remove the external monitor and reboot the computer again. Now when it is done booting take a flashlight an shine it on the lcd screen. You are looking to see if you can faintly see the icons on the screen. If they are there but barely visible then the LCD Inverter is bad. The LCD Inverter is located at the bottom of the lcd screen just above the keyboard and the Strip around the lcd screen covers it. You'll have to take the lcd apart to get to it.
3) If you don't see anything when you shine a flashlight on the desktop, then the lcd screen has to be replaced. However, sometimes the cable on the back of the lcd screen has come aloose or just needs reseating, so unplug the cable and put it back then see if it shows an image.
Read Below if it is not booting at all when you press the power button.
Laptops don't boot for the following reasons: 1) Bad Power Cord. 2) Bad DC Power Jack where the power cord plugs into the laptop. 3) Static Charge Buildup. 4) Bad Motherboard.
The above 4 reasons are when you press the power button and absolutely nothing happens. You hear no fans running, no disk drive running, no one time clicking sound on the CD Drive and No light for a second or two when the CD drives click. In the case of a motherboard issue sometimes you will hear beep sounds or see blinking lights. Those beep sounds and blinking lights tells the technician what is going on with your motherboard and why it will not boot. If you see the blinking lights or hear beeps count them.
So you have a power light which means your power cord and dc power jack is good. So lets see if you have a static charge buildup.
Remove the Power Cord and the Battery from the laptop, then Press and Hold the Power Button for 30 seconds. After 30 seconds put the power cord back into the laptop, but leave the battery out. Press the power button to see if it boots. If it does you had a Static Charge Buildup and it's ok to put your battery back in. If it does not you more than likely have an issue with your motherboard.
Mar 23, 2012 | Computers & Internet
How to solve problem after reboot my notebook dell no displaY
Mar 23, 2012 | ASUS Eee Computers & Internet
My samsung r519 wont turn on. when i press the on button i here the fan going, yet the screen stay's black and only the power light comes on. what could the problem be?
Does the fan stay running? if it does! it is probably a motherboard issue, if the fan is working correctly it should wind down, and if the hard drive is working "hard drive light will flicker" hook a external monitor to the video output on the back of your laptop if you see windows boots up then it would indicate laptop screen problem, but if the fan and the power light are the only activity then the motherboard is the problem.
Dec 22, 2010 | Computers & Internet
Dell Inspiron 1545 Booting Problem [Black Screen].
Insert the original Windows CD-ROM into the DVD-drive, and see if the computer will "boot" from that disk. If so, then it could be your 'C:' drive which is having the problem, and thus not "booting" your computer from it.
Jun 15, 2010 | Dell Inspiron 1545 Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
662 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
