Question about Canon PowerShot S2 IS Digital Camera
Canon S2 is washed out pictures
I also had the dreaded black screen and after following the 15" trick elsewhere on this site, it started to work fine, only for indoors pictures ! Now, whenever I click pictures outdoor in sunlight, its completely white. I don't understand whats the problem. I spoke to Canon customer service and they said that I should send it in I'm quite clueless as to whats going on with this. Please help ! I even reset the camera but to no avail.. :(
  • Anonymous Aug 17, 2008
    My powershot S2IS takes good pictures indoors but outdoor pictures are bright white, it looks like total overexposure. Canon has no solution that I haven't already tried, they want me to send it in for repair, or take them up on a one time only offer on a refurbished camera-newer model. I would prefer to find out what is wrong with this one, it is my spare camera and I hate to give it up.
  • Anonymous Sep 03, 2008
    Just when I thought my camera was fixed I started experiencing the same problem with my S2 IS. Don't know if it is any help to finding the solution but the camera works fine outdoors when used in video mode.
Posted on Sep 03, 2008
Canon S2 IS LCD Screen Doesn't Work Correctly
Hi, Some leads from the display wires are cracked or broken, if you are accurate enough you can replace it by yourself otherwise bring it to an repairshop.
regards Rob Rotronica
Apr 16, 2009 | Canon PowerShot S2 IS Digital Camera
Black pictures when using flash
The black images with flash mean that the Iris mechanism in the lens is not working properly, and that needs a professional camera repair service.
Best regards,
Oct 19, 2008 | Canon PowerShot S2 IS Digital Camera
No image in viewfinder or on screen
I found this solution on a different page and it fixed my camera that was having the same problem.
In the case where you get a black image, the following may be of help:
This is a common problem in older Canon S2 IS cameras, especially ones that have not been regularly used. What happens is that the lens iris gets stuck at a small aperture. Most often you can get function back. Here's how:
Turn the camera on in shooting mode.
Turn the mode selector to shutter priority ("Tv").
Use the four-way button on the back to set the shutter speed to 15 seconds. That's right, 15 seconds. (To do this you keep pressing the left direction on the four-way button until it goes from 1/1600 or whatever it might be all the way to 15")
Press the shutter release. Count to seven, then pop open the battery compartment.
Wait several seconds, then close the battery compartment.
You may need to repeat the above sequence several times to unstick the iris. If that does not accomplish it, you will likely have to send the camera in for repair.
Once you have it working again, you should use the camera regularly to keep it from sticking again.
This sounds like a pretty ghetto solution but it worked for me and I know it has worked for others. So before you go wasting your time writing letters, give this a shot.
Oct 17, 2008 | Canon PowerShot S2 IS Digital Camera
Overexposure problem after the black screen
Given that the 15' batteries out trick is just a way of forcing the iris to get un stick i think your iris is probably still getting stuck (but this time open a bit).
you could try doing the 15' trick a few more times in the hope of loosening it a bit.
ultimately once you have had this issue i think you are living on borrowed time before it happens again unless you get it fixed by canon.
Aug 25, 2008 | Canon PowerShot S2 IS Digital Camera
CANON POWERSHOT S2 IS 5 MEGA PIXELS
I bought mine 2 1/2 yrs ago too. Found this solution on this site and tried it. It worked perfectly.
Turn to TV mode, set the exposure to 15 seconds by pushing the little "arrow dial" until you have 15"
Push the button to take the picture.
Wait 7 seconds from when you push the button, then turn over and open the battery door while it is "taking the picture."
Close the battery door and turn back on.
I did this three times and the last time, it worked and the iris became unstuck.
Then I took a million pictures to get the iris moving.
Jul 11, 2008 | Canon PowerShot S2 IS Digital Camera
Canon S2 IS black screen
Normal 0 BLACK SCREEN OF DEATH – FIXED AT LAST - After doing several hours of research on the internet, I have been able to eliminate the problem on my Powershot S2 IS. I started with the “fix” as suggested by guidofoc in a post on the “flickr” site. Thanks guidofoc! His procedure did fix the problem for me but it only lasted a day. The next day, back to the same old black screen. For the next few days/weeks, when I wanted to use my camera, I did the same procedure and it would come back to life but would be black again the next time I powered up the camera or a day later.
Back to internet research! On the “Fixya” site, I found a picture of the camera shutter and diaphragm blades. This picture was posted by “andyhutton” who was also having the same “black screen” problem. He had disassembled his camera and found what appeared to be an oil exuding on the shutter diaphragm blades. He disassembled the camera, cleaned it thoroughly, and reassembled it. This fixed his camera. Other information I found indicated that what appeared to be oil was a little “stiffer” than oil, almost hard. It was thought that this was happening after leaving in a hot car other high temperature environment.
All this made sense to me but I didn’t relish the thought of tearing the camera apart and reassembling it. This procedure reportedly took about 6-8 hours. And this was by a person who considered himself, to have a reasonable amount of mechanical ability. I definitely DON’T RECOMMEND this approach unless you have tried all else and are ready to junk your camera. Using this information I theorized that if I used the temporary fix procedure and then repeatedly activated the shutter, perhaps the “wiping action” may wear down the frictional areas and free up the shutter blades to move more freely. I tried it. Voila! It has worked now for the last 6-8 weeks without a failure. Here is my final procedure:
Set the camera in Tv mode, (delayed shutter mode) set the shutter at 15 sec, click to take a picture and during that 15 secs (like, after 7 seconds) open the battery, compartment which cuts contact with the battery circuit. Close the battery cover. At this point the camera works fine for me but only temporarily as noted above. Sometimes however, this procedure had to be performed more than once. Here is the key to the permanent fix. While the camera is working via the temporary fix, take many, many pictures. Hundreds! I probably snapped 400-600 pics. The idea is to wear down the little patches of hardened oil on the shutter blades. For the next three of days I took hundreds of pics each day. Basically, I just aimed the camera at the wall or whatever and snapped off several hundred pics.
Now that I seem to have my camera working permanently, my plan is to NOT leave my camera in a high temperature environment, and to try to use it regularly. Maybe, not unlike many other things, if it gets no regular use, it may start to deteriorate.
No guarantees but I do hope this helps someone.
Dec 12, 2007 | Canon PowerShot S2 IS Digital Camera
Canon S3 no display on LCD screen
This is a common problem that we ( in the camera repair game ) see a lot . The cause is faulty CCD sensor ( see enclosed pic from a Canon camera ) to see what I mean . Canon will repair this ( or replace the camera if they cannot repair it inside 4 weeks ) free of charge. Why does this happen ? Badly manufactured ( produced in 2002-2004 run ) sensor goes in the camera and starts outputting noise after 1 or 2 years instead of working properly for +- 10 years.8abdb4c.jpg
Dec 05, 2007 | Canon PowerShot S2 IS Digital Camera
From a similar solved problem: I have read of this problem (doing research before buying a Canon S2). Apparently it is a bad sensor and Canon will fix it for free if it's still under warranty (otherwise it will cost $119.00). and I have the same problem. Just got off the phone with Canon and have to send the camera to them. Repair takes ~2wks. Call them @1-800-828-4040 and follow the menus. Canon's site also addresses this for the S1 and others (but not the S2). Says heat and high humity can cause a connection to the sensor to come undone. Hope this helps.
Sep 29, 2006 | Canon PowerShot S2 IS Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
162 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
