Question about Sharp AR-5320 Black and White Copier
The copier machine is not responding. - Sharp AR-5320 Black and White Copier
What do really mean its not responding? the keypad,or there is no power?
Posted on May 23, 2011
This machine hangs after a short while. no key responds to any command but its still on
try to clean the keys by opening the cover of the key pad clean it with alcohol and if it faults then replace the all key pad for the machine
Sep 05, 2015 | Gestetner DSm616 Printer
Pls . help me experts , i have kyocera km3050 copier but the lcd touchscreen is not responding but days past when it still responding its getting hard to respond. please help me with this experts
A hard reset can clear minor error codes. A lot of times you do not really need to call for your support contractor. Sometimes errors stop the function of a machine, but the machine could still function properly with a hard reset. Perhaps there is a better description than hard reset, as "reset disable function" is a little bit confusing and not a phrase you were likely look for.
Contact your service provider before following these instructions.
Use at your own risk. Perhaps there is a possibility of causing damage. Again, contact your provider.
From our copier service company:
This reset is used for two purposes:
1) reset any data that may be "hung up" in the hard drive.
2) reset an error code and attempt to continue use. (If the error recurs, then you should escalate to whomever supports the copier.
Hard Reset Procedure:
Press Status button
Enter 10871087 - You are now in Maintenance Mode
Enter 906 (do not enter any other numbers!)
Press Start
Press Execute
Press Start
Copier tells you to turn it off/on
Turn off power by switch on right side of copier (hard power off)
Turn on power by switch on right
I have seen to use code 163 instead of 906. I don't know what this does. Again, consult experts before using this code or any others.
Feb 03, 2015 | Kyocera Mita KM3050 Black Toner Cartridge...
Machine is not responding
Did you get a fix to this problem? I also have the same problem
Jan 03, 2014 | Roland GX-300 CAMM-1 Pro Vinyl Cutter
Keycera machin have problem keycounter massage are given
Go to the service mode by 1087 1087 press 020 then press 25%% or 400% to on it. then press start. after few seconds machine will restart. same process with 021 also. note: first take down the setting list from 000 by pressing start key. this features will get the machine to default factory setting.
Mar 11, 2013 | Kyocera Copystar CS-1635 Copier
Aficio 2045 sc670
engine respond error
fault:
after powering on the machine,a respond was not recived from the engine within the specific time
possible causes:
bicu board
controller board
Sep 03, 2010 | Ricoh Aficio 450 Copier
The fax on my sharp stopped working and made everything else on the unit quit, copier, printer etc... is this fixable or should I just junk the copier?
How do you know the fax is what is causing your dead machine? If the whole machine is dead then your problem could be as simple as a blown fuse or as bad as a bad board. If your copier turns on but is not responding then on of your options could be causing the machine to lock up. Depending on your make and model is what will depend on weather its worth fixing or not.
Sep 12, 2009 | Office Equipment & Supplies
SHARP AR-203 copier unusable after refill
Change the unit chip or reset him.
Sep 01, 2009 | Sharp AL 1631 Copier
Sharp AR 5316 E photocopier error clearing
Try reset by pressing [#] [interupt] [C] [interupt] [1] [6] [start]
May 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
Printer problems
assuming the drivers and cable are ok and latest it is the more likely going to be the formatter board.
Mar 06, 2008 | HP LaserJet 1500L Printer
Sharp AR-5320 Black and White Copier Logo
21 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
