Error 5100 occured during printing, what is d solution for this?
  • 113 Answers
- Clean the timing strip
- The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough . Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism
Posted on May 23, 2011
41.2 error hp laserjet 5200
41.2 error hp laser jet 5100
am from Ethiopia but when am check and replace the Formatter board ,beam not working but when am replacing the DC controller and all connecting cables to beam, then it was working god .
Feb 04, 2014 | HP Hewlett Packard LaserJet 5200 Printer
Error occured/error 5100
just reset your printer eeprop by software.type generaltool for canon mp160 and googlee it.run software,connect your printer and reset your printer eeprom.
Jun 17, 2012 | Canon PIXMA MP160 All-In-One Printer
Error - 5100 and 6A00 keep appearing. What should I do?
Error 5100 means an error occurred in the carriage encoder signal. Error 6A00 means an error occurred in the AP motor during purging operation. To fix these two errors you need to replace:
- Carriage unit (QM2-2922)
- Timing **** strip film (QC1-6394)
- Logic board ***'y (QM2-3078)
Before replacement of the logic board ***'y, check the waste ink amount (by service test print or EEPROM
information print). If the waste ink amount is 7% or more, also replace the ink absorber kit (QY5-0146) when
replacing the logic board ***'y.
- Carriage motor (QK1-1500)
-Sheet feed unit (QM2-2916)
-Purge unit (QM2-2925)
Feb 02, 2011 | Canon Office Equipment & Supplies
How to stop to print the journal after send fax everytime?
Sending Confirmation
This report shows the fax number, the number of pages, elapsed time of
the operation, the communication mode, and the communication results.
You can set up your machine to print the message confirmation report in
one of the following ways (see page 5.3):
• Automatically after each transmission (ON)
• Automatically only if an error occurs during transmission (ERR)
• No report printed at all (OFF). You can print this report manually at
any time you want.
SENDING CONFIRM - A confirmation report shows whether the
transmission was successful or not, how many pages were sent, etc.
Select ON to print a confirmation report automatically each time you
send a fax.
Select OFF to turn this feature off.
Select ERROR to print only when an error occurs and the transmission
was not successful.
Nov 27, 2010 | Samsung SF-5100 Plain Paper Laser Fax
An error 5100 always occur in my pixma iP1980 whenever i print a
This particular error has a lot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip.You can find the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display). Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corresponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on).
Thank you !!
May 25, 2010 | Canon Office Equipment & Supplies
Double images, error 5100 when printing, copying
5100 is a carriage error, check the timing strip for contamination(plastic strip about 1/4" in width)
The unit is not homing, check for obstructions.
Jan 02, 2010 | Canon PIXMA MX700 All-In-One InkJet...
Cannon mx 310 error 5100 Says chck printr with alarm light flashi
heres the problem from service manual: error 5100, a error occured in your encoder signal, it list 4 things in the serice manual.
carriage unit. carriage motor, logic board, timing **** film.
ok my first thing i would look at is the film that runs directly behind the print head i would think it is dirty. just turn on printer and get print head to the middle and turn off machine, gentle move print head to one side and gentle clean the film strip with a cloth with a little metho on it, move print head to other side and clean other part of ****.
i reckon that will fix your problem its a common problem they tend to get a bit of grease on the timming ****.
Canon Tech
May 30, 2009 | Office Equipment & Supplies
Canon Pixma MP150 service error 5100
sounds like an engine failure..from that code..is this under warranty, by chance?
Mar 25, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
